Toggle navigation
Categories
Discussions
About Us
Privacy Policy
Sign In
Home
Repetier-Host
Questions & Answers
Cut Objects
Lab2
June 2015
in
Questions & Answers
While playing with Repetier-Host V1.0.6 I turned on Cut Objects. Now I can't find how to turn it off
Repetier
June 2015
In the right top corner the "x" closes it just like the scale and rotate modes.
Lab2
June 2015
When I am seeing the "Cut Object" parameters, clicking the X hides the parameters, but leaves the view of the object still cut.
How do I get back to viewing the full, uncut object?
Repetier
June 2015
For me it also restores whole object. If not move position slider to the right, but should not be required.
Lab2
June 2015
Found my problem. It thought my object was too large, when I did a scale to maximum, it reduced the size and now behaves after cutting.
Is there a way to determine the dimensions of an object?
Lab2
June 2015
The reason it was too large is because the dimensions in the file were in millimeters. I had later read a file in inches, and forgot to change back before loading this one.
Thanks for your comments. I learned a few new things.
Repetier
June 2015
In the right tab with the stl names is a gear. Clicking it gives mor einfos about a object like size, surface, volume errors etc.
Lab2
June 2015
Thanks. Why does a simple cube have 12 faces rather than 6?
Repetier
June 2015
Faces are triangles. Enable edge drawing and you see it.
Sign In
or
Register
to comment.
