Print stops after a few seconds
Running Repetier-host connected to a smoothieware board. Got everything calibrated, started my first print (20mm cube), and it stopped after a few seconds of printing. Not only did the print freeze, but repetier host froze as well, all controls useless. Had to hit the reset button on my board and reconnect.
I figured it was a slicing problem, so I tried re-slicing, and even switching between Slic3r and CuraEngine, but both have the same problem. And it stops at a different point each time. Sometimes it starts the perimeter, sometimes it doesn't even finish the brim. So it sounds like a Repetier problem.
Any ideas what could be happening?
This is the last few lines of Gcode in the file before the last failure:
I know enough to know there's nothing funky going on there.
This is what was in the log for those same lines:
I don't know what some of those commands are. But anyway, that last line is the last one sent before failure. But again, it fails somewhere different each time. Just thought some code might be of use.
