RAMPS-FD + Geetech RAMPS-FD Adapter + RepRap Full Graphics Smart Controller
after fiddeling around I was able to run a RAMPS-FD + Geetech RAMPS-FD Adapter + RepRap Full Graphics Smart Controller.
Rotary, SD and Display works with RAMPS-FD and Due.
All I had to do was adding the right Pin configuration in configuration.h
////// Settings RAMPS Display
 // ramps-fd lcd adaptor
    #define LCD_PINS_RS         16
    #define LCD_PINS_ENABLE     17
    #define LCD_PINS_D4         23
    #define LCD_PINS_D5         25
    #define LCD_PINS_D6         27
    #define LCD_PINS_D7         29
    #define BEEPER            37
    #define BTN_EN1           33
    #define BTN_EN2           31
    #define BTN_ENC           35
    #define SDCARDDETECT      49
// ende Settings RAMPS Display
AND I had to rotate the plugs in the RAMPS-FD LCD Adapter from GeeTech 180 Deg.
Very professional by putting them in with force and ignore the nose :-D
Can you please add this configuration ? I'm pretty sure I forget these in 2 months again.
Greetings
Domi
  • I have added it to DisplayList.h at line 349 for next update (dev version) but your content is not for repetier-firmware. That is marlin pin naming. I have now added
    #elif MOTHERBOARD = 403 || MOTHERBOARD = 404
     // ramps-fd lcd adaptor needs to rotate connectors 180° to work!
    #define UI_DISPLAY_RS_PIN         16
    #define UI_DISPLAY_ENABLE_PIN     17
    #define UI_DISPLAY_D4_PIN         23
    #define UI_DISPLAY_D5_PIN         25
    #define UI_DISPLAY_D6_PIN         27
    #define UI_DISPLAY_D7_PIN         29
    #define BEEPER_PIN                37
    #define UI_ENCODER_A              33
    #define UI_ENCODER_B              31
    #define UI_ENCODER_CLICK          35
    #define UI_RESET_PIN              -1
    #define UI_DELAYPERCHAR 50
    #define UI_INVERT_MENU_DIRECTION   0
    #define UI_BUTTON_BACK            -1
    #undef SDCARDDETECT
    #undef SDCARDDETECTINVERTED
    #define SDCARDDETECTINVERTED   0
    #undef SDSUPPORT
    #define SDSUPPORT              1
    For the RRD GLCD display. Hope it works with that.
  • Ok, your right, my Marlin Defines did nothing.
    I downloaded 1.0.3 completly new and configured  only RAMPS-FD and the Full Graphics Display in the web configuration and it worked out of the box.
    Nothing to change for Rotary or display. Only rotate the display cables did the trick.
    Temp sensors work also directly out of the box.
    Only the MOSFETs (headbed and heaters) are per default on instead off. Also the 2 additional mosfets for fans.
    In the image above you can see that all LEDs for the mosfets are on.
    Is there a possibility to invert the pins ?
    Should be D9 till D12 and additionally D2.
  • Ok, I found this in the code:
    #if MOTHERBOARD == 403
    #define HEATER_PINS_INVERTED 1  // only old boards had the output inverted
    #define HEATER_PINS_INVERTED 0
    #endif
    and configuration.h board is set to 404.
    So I assume I bought this old version that is extremly dangerous because on bootup, or crash the heaters are full fired.
  • Yes, that sounds like the bad behaviour of the first batch. So make sure to at least have watchdog enabled for safety.
  • To dangerous, ordered a Smart RAMPS and a Rearm (normal RAMPS Boards I have a mass) instead.
    Rearm looks nice but I assume it will not work with repetier ? I use repetier since a year and I love it. Especially the security features like decouple and or EEPROM and so on.
    Is there a plan to support none arduino due arm boards ? Is not so easy to find atm good hardware with arduino due.
    btw: I checked all ali and bay links, all of them sell the old Ramps FD v1 Rev A bricks :-(
  • I personally like the RADDS boards whcih is also what I use for development of due.
    Non arduino is currently not planned.
