Extruder 0 not working
Hi everyone
i am new to diy 3d printer
As i configure through online Repetier Host
i config y_dual motor as Y2 motor to E1
my prob is i cant run the extruder0 motor
even if i interchange the x and extruder motor,motor is working good
But i cant find possible solution for my E0 pins are not enable
in eeprom they is nothing as EXTRUDER0
they is some software issue can anyone guide me
i am using Repetier 0.92 and 1.0
Extruders only extruder then hotend is hot or you enable cold extrusion using M302 S1. That is the normal mistake in testing condition. Also make sure dry run is not enabled or it will also ignore extrusions.
even though i cant run extruder motor
I am using A4988 driver, its in good condition
but motor is not getting energies
G1 E10 F200
the extruder just tricks as lik energing but not rotating
- Current to low
- Only one coil gets power preventing rotation
when i assign the E0 port to X-axis
intially its not rotating,later i tried by manual input
G1 X20 F200
after few sec that means after 10-15sec
X-axis(E0 port) Motor starts with clicking sound,A4988 driver became very Hot and Motor too became very Hot.
I have attached X-axis configuration
I solved issue
