supports not showing
Hi I can't get to add the supports what is the deal with that? I tested many different overhang angles and no supports added I even downloaded a support test, and try to add supports, no supportes are added to my piece after slicing, tested on ultimaker cura and it works, is there any fix ? using v2.1.3
  • Did you also select Support Type on the right side when slicing? What are your support settings? Just sliced with support and it worked, so i guess you are missing one parameter or it is set wrong.
  • hi im having  the same  problem supports not showing using cura engine works on all third party slicers but not in repetier host .... im sure it used to  :/  using v2.1.6   also tried various angles but .. no cigar ...  i have even tried uninstalling and reinstalling and using default settings ,, and still supports are not showing .... theres a glitch somewhere .. which i cant find ..
