Server to Server Communication
I have two printers setup each with there own instance if Repetier-Server running on Pi. Is there a convenient way to access both servers in a single frontend. Ideally i could access one server through the web address and see both printers listed.
I need each printer to have its own pi server because I have a touch screen installed on each printer.
  • you can do that with iframes in a web page
    Thanks,
    I wasn't familiar with iframes, but I did a little digging and it might be a viable solution.
    I created a little html file that pulls in the two server webpages side by side. its not perfect, but at least I can manage two printers.
