Wrong thermistor value reading
Hi, upgraded my Wanhao Duplicator I3 V1 with e3d v6 and repetier firmware.
Room temp for the bed is arround 25C which is okay but the hotend says 40 degrees. Not sure if this is okay or if the sensor should be more precise.
Have set sensor to type 8
https://3dprinterwiki.info/wanhao/part-specifications/
https://3dprinterwiki.info/wanhao/wanhao-duplicator-i3/
https://e3d-online.dozuki.com/Wiki/V6_Parts
They say the thermistor is this?
https://e3d-online.com/thermistor-cartridge
firmware guide (Repetier)
https://e3d-online.dozuki.com/Guide/V6+Repetier+Configuration/24?lang=en
Hope it helps
