I was so done that I started packing the shit board, when I thought: "Okay everything is loose and what do I have to lose"; I hooked it up directly to my computer, wrote the whole sketch and connected the DUE with RADDS on top and EEPROM 1...
At least eeprom seems to work and communication pins. You can not say more from this, e.g. if all pins are still functional is not possible to say. But let's hope they are.
Com::config(PSTR("RetractionLength:"),EEPROM_FLOAT(RETRACTION_LENGTH));
sketch\Printer.cpp: In static member function 'static void Printer::showConfiguration()':
Printer.cpp:1867: error: call of overloaded 'config(const char [18], double)' is ambiguous
sketch\Printer.cpp:1867:74: note: candidates are:
In file included from sketch\Repetier.h:396:0,
from sketch\Printer.cpp:19:
sketch\Communication.h:391:13: note: static void Com::config(const char*, int)
static void config(FSTRINGPARAM(text),int value);
sketch\Communication.h:393:13: note: static void Com::config(const char*, int32_t)
static void config(FSTRINGPARAM(text),int32_t value);
sketch\Communication.h:394:13: note: static void Com::config(const char*, uint32_t)
static void config(FSTRINGPARAM(text),uint32_t value);
sketch\Communication.h:395:13: note: static void Com::config(const char*, float, uint8_t)
static void config(FSTRINGPARAM(text),float value,uint8_t digits=2);
exit status 1
Info:PowerUp
11:35:31.048 : N1 M110*34
11:35:31.048 : N2 M115*36
11:35:31.048 : N3 M105*36
11:35:31.048 : N4 M114*35
11:35:31.048 : N5 M111 S6*98
11:35:31.064 : N6 T0*60
11:35:31.064 : N7 M20*22
11:35:31.064 : N8 M80*19
11:35:31.064 : N9 M105*46
11:35:32.142 : Info:PowerUp
11:35:34.094 : N10 M105*22
11:36:14.112 : Communication timeout - reset send buffer block
11:36:14.112 : N11 M105*23
11:36:16.971 : N12 M105*20
22:02:45.950 : start
22:02:46.138 : N1 M110*34
22:02:46.138 : N2 M115*36
22:02:46.138 : N3 M105*36
22:02:46.138 : N4 M114*35
22:02:46.153 : N5 M111 S6*98
22:02:46.153 : N6 T0*60
22:02:46.153 : N7 M20*22
22:02:46.153 : N8 M80*19
22:02:46.153 : N9 M105*46
22:02:47.219 : Info:PowerUp
22:02:48.034 : Free RAM:83732
22:02:48.050 : FIRMWARE_NAME:Repetier_0.92.3 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:2 REPETIER_PROTOCOL:3
22:02:48.050 : N10 M220 S100*80
22:02:48.050 : N11 M221 S100*80
22:02:48.050 : N12 M111 S6*84
22:02:48.050 : N13 T0*8
22:02:48.050 : Printed filament:0.00m Printing time:0 days 0 hours 0 min
22:02:48.065 : X:-0.03 Y:-0.03 Z:-0.006 E:0.0000
22:02:48.065 : Begin file list
22:02:48.065 : End file list
22:02:48.600 : extruder 0: temp sensor defect
22:02:48.600 : extruder 1: temp sensor defect
22:02:48.600 : heated bed: temp sensor defect
22:02:48.600 : Error:Printer set into dry run mode until restart!
22:02:49.196 : N14 M105*18
22:02:52.268 : N15 M105*19
22:02:55.322 : N16 M105*16
22:02:58.399 : N17 M105*17
22:03:01.456 : N18 M105*30
22:03:03.714 : N19 G1 Z0.994 F100*23
22:03:04.530 : N20 M105*21
22:03:07.588 : N21 M105*20
22:03:10.661 : N22 M105*23
22:03:12.950 : N23 M205*21
22:03:12.950 : EPR:2 75 250000 Baudrate
22:03:12.966 : EPR:3 129 0.000 Filament printed [m]
22:03:12.966 : EPR:2 125 0 Printer active [s]
22:03:12.966 : EPR:2 79 900000 Max. inactive time [ms,0=off]
22:03:12.966 : EPR:2 83 360000 Stop stepper after inactivity [ms,0=off]
22:03:12.981 : EPR:3 3 640.0000 X-axis steps per mm
22:03:12.981 : EPR:3 7 640.0000 Y-axis steps per mm
22:03:12.981 : EPR:3 11 3200.0000 Z-axis steps per mm
22:03:12.981 : EPR:3 15 200.000 X-axis max. feedrate [mm/s]
22:03:12.997 : EPR:3 19 200.000 Y-axis max. feedrate [mm/s]
22:03:12.997 : EPR:3 23 20.000 Z-axis max. feedrate [mm/s]
22:03:12.997 : EPR:3 27 40.000 X-axis homing feedrate [mm/s]
22:03:12.997 : EPR:3 31 40.000 Y-axis homing feedrate [mm/s]
22:03:13.013 : EPR:3 35 10.000 Z-axis homing feedrate [mm/s]
22:03:13.013 : EPR:3 39 10.000 Max. jerk [mm/s]
22:03:13.013 : EPR:3 47 0.300 Max. Z-jerk [mm/s]
22:03:13.013 : EPR:3 133 0.000 X min pos [mm]
22:03:13.028 : EPR:3 137 0.000 Y min pos [mm]
22:03:13.028 : EPR:3 141 0.000 Z min pos [mm]
22:03:13.028 : EPR:3 145 200.000 X max length [mm]
22:03:13.044 : EPR:3 149 200.000 Y max length [mm]
22:03:13.044 : EPR:3 153 180.000 Z max length [mm]
22:03:13.044 : EPR:3 51 1000.000 X-axis acceleration [mm/s^2]
22:03:13.044 : EPR:3 55 800.000 Y-axis acceleration [mm/s^2]
22:03:13.059 : EPR:3 59 100.000 Z-axis acceleration [mm/s^2]
22:03:13.059 : EPR:3 63 1000.000 X-axis travel acceleration [mm/s^2]
22:03:13.059 : EPR:3 67 800.000 Y-axis travel acceleration [mm/s^2]
22:03:13.059 : EPR:3 71 100.000 Z-axis travel acceleration [mm/s^2]
22:03:13.075 : EPR:0 880 0 Autolevel active (1/0)
22:03:13.075 : EPR:0 106 3 Bed Heat Manager [0-3]
22:03:13.075 : EPR:0 107 255 Bed PID drive max
22:03:13.075 : EPR:0 124 80 Bed PID drive min
22:03:13.091 : EPR:3 108 7.000 Bed PID P-gain
22:03:13.091 : EPR:3 112 33.000 Bed PID I-gain
22:03:13.091 : EPR:3 116 290.000 Bed PID D-gain
22:03:13.091 : EPR:0 120 255 Bed PID max value [0-255]
22:03:13.106 : EPR:0 1020 0 Enable retraction conversion [0/1]
22:03:13.106 : EPR:3 992 1.900 Retraction length [mm]
22:03:13.106 : EPR:3 996 13.000 Retraction length extruder switch [mm]
22:03:13.122 : EPR:3 1000 40.000 Retraction speed [mm/s]
22:03:13.122 : EPR:3 1004 0.000 Retraction z-lift [mm]
22:03:13.122 : EPR:3 1008 0.000 Extra extrusion on undo retract [mm]
22:03:13.122 : EPR:3 1012 0.000 Extra extrusion on undo switch retract [mm]
22:03:13.122 : EPR:3 1016 20.000 Retraction undo speed
22:03:13.138 : EPR:3 200 784.000 Extr.1 steps per mm
22:03:13.138 : EPR:3 204 50.000 Extr.1 max. feedrate [mm/s]
22:03:13.138 : EPR:3 208 20.000 Extr.1 start feedrate [mm/s]
22:03:13.153 : EPR:3 212 5000.000 Extr.1 acceleration [mm/s^2]
22:03:13.153 : EPR:0 216 3 Extr.1 heat manager [0-3]
22:03:13.153 : EPR:0 217 230 Extr.1 PID drive max
22:03:13.153 : EPR:0 245 40 Extr.1 PID drive min
22:03:13.169 : EPR:3 218 5.0000 Extr.1 PID P-gain/dead-time
22:03:13.169 : EPR:3 222 2.0000 Extr.1 PID I-gain
22:03:13.169 : EPR:3 226 40.0000 Extr.1 PID D-gain
22:03:13.169 : EPR:0 230 240 Extr.1 PID max value [0-255]
22:03:13.184 : EPR:2 231 -18 Extr.1 X-offset [steps]
22:03:13.184 : EPR:2 235 -18 Extr.1 Y-offset [steps]
22:03:13.184 : EPR:2 290 -18 Extr.1 Z-offset [steps]
22:03:13.184 : EPR:1 239 1 Extr.1 temp. stabilize time [s]
22:03:13.200 : EPR:0 254 255 Extr.1 extruder cooler speed [0-255]
22:03:13.200 : EPR:3 300 784.000 Extr.2 steps per mm
22:03:13.200 : EPR:3 304 50.000 Extr.2 max. feedrate [mm/s]
22:03:13.200 : EPR:3 308 20.000 Extr.2 start feedrate [mm/s]
22:03:13.216 : EPR:3 312 5000.000 Extr.2 acceleration [mm/s^2]
22:03:13.216 : EPR:0 316 3 Extr.2 heat manager [0-3]
22:03:13.216 : EPR:0 317 230 Extr.2 PID drive max
22:03:13.216 : EPR:0 345 40 Extr.2 PID drive min
22:03:13.231 : EPR:3 318 5.0000 Extr.2 PID P-gain/dead-time
22:03:13.231 : EPR:3 322 2.0000 Extr.2 PID I-gain
22:03:13.231 : EPR:3 326 40.0000 Extr.2 PID D-gain
22:03:13.231 : EPR:0 330 240 Extr.2 PID max value [0-255]
22:03:13.247 : EPR:2 331 0 Extr.2 X-offset [steps]
22:03:13.247 : EPR:2 335 0 Extr.2 Y-offset [steps]
22:03:13.247 : EPR:2 390 0 Extr.2 Z-offset [steps]
22:03:13.263 : EPR:1 339 1 Extr.2 temp. stabilize time [s]
22:03:13.263 : EPR:0 354 255 Extr.2 extruder cooler speed [0-255]
22:03:13.725 : N24 M105*17
22:03:16.807 : N25 M105*16
22:03:19.880 : N26 M105*19
22:03:22.970 : N27 M105*18
22:03:26.047 : N28 M105*29
22:03:29.116 : N29 M105*28
22:03:32.174 : N30 M105*20
22:03:35.247 : N31 M105*21
22:03:38.319 : N32 M105*22
22:03:41.378 : N33 M105*23
22:03:44.450 : N34 M105*16
https://imgur.com/a/A6SfueJ
the board makes contact with the little rings. after that it immediately stops connecting
https://i.imgur.com/Huv43xg.jpg
Edit:
extruder 0: working
heated bed: working
So a defect temp sensor; Does it ever end with the problems?
so thermistor hotend or heater hotend?
