File Management
I want to be able to load .gcode files to the server for all printers to use from the same pool. I have found that I can load them for a single printer and point all printers to the printer I load them for. Is there a way to have a global location that isn't tied to a specific server? The problem is if I remove the printer all of the files are under, I have to leave it in the list as a disabled printer or all the files go away. Is there a better solution for file management?
