view slicer result
When I installed Repetier Host 1.06 the first time and launched it as the last stage of the install, it loaded the tablet
I was able to slice it with Slic3r and view the picture of each slice layer.
After I exited it and ran it again, I was unable to view the slice result picture even though it generated lots of G code.
What did I screw up?
Yes, there was nearly 130000 lines of g-code loaded and toggling show/hide filament made no difference.
Fixed the problem by going to configuration (for Slic3r) from slicer tab
on Printer Settings tab changed from My Settings to -default- then saved as My Settings
What ever I had previously done to My Settings messed it up. I now have it working, but don't know yet what I did.
