Radds 1.6 or due not initializing/booting correctly on 1.0.2
Hi, first of all apologies if this is the wrong category.
Quick rundown of my hardware.
Wanhao i3 plus base printer
Radds 1.6 from youprintin3d.de
Radds 4x20 display
TMC2130 steppers from watterott
Arduino Due (Currently clones from Amazon.co.uk)
Quick history
I burned my first two (genuine) arduinos because my printer had a PCB on the hotend sent 24v into ground of hotend thermistor. (burned ADC and shorted some analog pins to gnd and 3.3v)
Then i skipped trying to keep the default cable and hot end PCB setup and went for RC silicone wires and ethernet cable for fans ziptied together. Expensive lesson as I spent about 50euro on each of them.
I have soldered SPI for the TMC2130 on the underside and it worked for some test prints.
Now. The problem.
Long story.
I've had the problem that the firmware wont boot or the UI wont boot properly 90% of the time see image above. My highest successrate of booting is just running the arduino via USB. then it boots 60% of the time. Previously it never booted first try and would always boot when reset. Now reset does not help.
This affects both my arduinos, happens on basically stock firmware aswell.
So I am currently alternating between two different firmwares (both 1.0.2), one I call "stock" and one I have my settings and such in.
Config.h "Stock"
Config.h "WIP"
Full download
I included the full download because I also did some changes in pinter.cpp as two z stepper drivers thing was a bit broken, something something z2_stepper instead of ext1_stepper.
Honestly "WIP" is still very much a work in progress, I think I've disabled a few things while troubleshooting and honestly this is now my last resort as I don't want to bother people with my uneducated questions. I should have researched more before opting to upgrade my printers motherboard instead of just replacing the one that broke.
Edit: forgot the usual apologies for any misspellings and such, I am not a native speaker but I still should be able to do better than this. I'm also tired from a lot of troubleshooting.
Radds 4x20 display
Quick history
Now. The problem.
Short story, I boot printer and display shows this 90% of the time.
Long story.
Config.h "Stock"
Config.h "WIP"
Full download
That worked!
If you don't mind, could you explain a bit more what you mean with "TMC special drivers"
Now (later) i am gonna try changing the CL pins, i have no real reasoning behind that though.
My SPI and CL things are soldered so that may have caused some part of the errors. I'll redo the solderwork, I only had multi-cored copper wire and i will redo it with some single-cored cable (and use some glue to keep em tidy)
Anyway, thank you for your helpful comments, this one test gave me more information than most of my tinkering these last few weeks (ive mostly done config.h iterations)
But only when:
No stepperdrivers are on the board
0.92 is flashed
1.0.2 w/o TMC is flashed
Drivers in with drivers enabled crashes.
In pins.h there is a segment with HW and SW SPI. Does this need to be changed to be compatible with the TMC2130 resolder?
"// 10 if using HW SPI. 53 if using SW SPI
Do I need to configure it to use the pins on the SDcard connectors for SPI or is that already how it should be?
Honestly I've gone through so many different test builds lately to gain more information I can share that I am starting to dream about the Arduino IDE and code.
Also I just want to thank you for all your help so far. I very much appreciate it
That is not part of radds board definition, so ignore it.
You should be using hardware spi and there is only one hardware spi. All you need is a CS pin per device so you talk to the right spi device.
Please try first without display. Not sure if the sd card configuration can make trouble. Should not be a problem because without sd card it will simply use the sd card from the radds, but it adds cable length and all share same MISO/MOSI/CLOCK cable, so that might catch up interference.
Maybe you should try 1.0.3dev - I reduced spi frequency there. Maybe with the 4mhz spi frequency it works better. Just a try, configuration is the same.
Since the author of the extension uses a radds for development I wonder that it is so problematic.
Just tried those two versions of dev fw and still no response. I did disable SDSupport in both configs though so that may be an error source. I'm gonna keep trying stuff, will update if I find something that works.
Just figured i should mention, if I have "mirror Z to other driver" as in I have Z2 I need to change EXT1 to Z2 in Printer.CPP
Like so:
But I looked at the sport and see that the drivers get initialized before firmware sends "start". So there is a simple test to check where and what exactly fails.
A bit below add after
Com::printFLN(Com::tStart);
HAL::showStartReason();
this line:
HAL::delayMilliseconds(100);
it will wait so the "start" message will appear in host log when you connect. At least if initialization works. So if you see "start" in the log you know that the init was ok. If not disable one by one by commenting out the new TMC2130Stepper line together with the following configTMC2130... line . Maybe it is just one driver that is making problems during init. Then you know wiring is bad for that one or it is defect if all others work. Since motors do not get used at startup I think one of these lines causes the blocking. The other parts are only used on special moves or commands but would not prevent start of firmware.Okay so I've spent a few hours troubleshooting. So with some tinkering I got it to boot, i got drivers to move (+ only still need to change some settings i think)
However i do believe something is still fubar. Its slow to boot. Like we are talking 40+ seconds. sometimes boardering on 5min boot times.
After flashing it again a few times, now it wont boot again. I am now pretty sure either my RADDS may be damaged or one of the drivers are the cause.
Sep 12.
I added your command and further troubleshooting has it in the FW, but it does not seem to have had an effect.
Sep 13.
Okay, a few more hours and I'm pretty sure I have something... Maybe.
Basically. It seems LCD encoder position affects boot chance.
SOMETIMES (not always, not often but many times) turning the encoder while on "frozen" screen (/w 2 bars as pictured in earlier comment) it starts up
NOTE. Does not boot w/o screen. May be due to not flashing a FW without screen though.
Also! removing one stepper driver (the one placed on E1, E1 wiring is okay though and E2 which is connected THROUGH E1 causes no issues.) has increased boot success to around 70% along with the above technique. No steppers give 100% (dont know if it fails 1 in a 100 or not. not that inclined to test)
Also, don't know if it matters or it is correct behaviour or not.
While connected to my RADDS pins 50, 48 measure GND (aka ENC_P and ENC_B)
Tomorrow I will look into removing a resistor and doing a solder join on the stepper motors instead as they said on page 5 here.
Rep-Host logs
All drivers connected, wont boot (via only USB), not much to look at
One stepper removed, wont boot via USB so booted via PSU then connected
Sorry if the comment is rather long. I've spent a lot of hours the last two days troubleshooting and collecting information. Tomorrow I will also be attempting a dialog with Alexsomesan, but I'm not sure what to hope for as he is probably a busy man.
Again. Many thanks
Boot time is normally a few seconds never more or watchdog would trigger. Do you have it disabled? Otherwise it might also explain the high time if oyu are in a reboot loop. Maybe initializing the tmc takes long. The only other thing that would block is reading eeprom on radds. But since it works without tmc enabled I think the tmc init takes so long. Maybe it verifies settings and when something goes wrong it retries until it succeeds.
Hopefully alex has some time and can say more.
Where do I see if watchdog is enabled, I want it enabled but when I load my config.h into the configurator watchdog isnt on so I assume its not enabled in config.h.
Ill look into the booting difficulties but meanwhile I'll take this time to see if I can get it stable.
There seems to be a bit of SW SPI code in the tmc2130 library now so I'll have to check later if that is functional or experimental.
/* A watchdog resets the printer, if a signal is not send within predefined time limits. That way we can be sure that the board
is always running and is not hung up for some unknown reason. */
#define FEATURE_WATCHDOG 1
1 is on 0 is off.Good that it working now also such difference in boot time is strange.
Boot time may be something like some capacitator or such hasnt discharged completely. i dont know. Would kinda explain my previous weirdness with the encoder boot.
Turning off watchdog did nothing for boot times, atleast first time. First boot took about 1 min 20 sec. Then second about 20 sec, third 9 sec.
Now it consistenltly boots in about 4 seconds
Does it take a few boots to "flush" out the old flash?
Ill flash again with watchdog and see if that was a cause.
Flashed with watchdog back turned on
1st boot: 19 sec. 2nd: 9 sec. 3rd: 30 sec.
After this its back to consistently booting in 4 sec.
Maybe also bootloop until perfect storm conditions allows it to boot.
Also, is the movespeed for "move z fast" set anywhere? I increased max feedrate and homing feedrate from 2 to 20(max) 10(home) yet it still moves INCREADIBLY slow. Homing from around 3 cm up takes about a minute or so.
Takes about 3 seconds to turn 1/4th rotation of stepper
is max feedrate mm/s or steps?
What is your definition of boot time? Until you see "start" in log?
Regarding speed did you check settings in eeprom? They do not get overwritten with new flashing so it may contain older values.
Speeds are in mm/s in configuration.
As for Z move. I missed EEPROM
Here is a vid of printer boot. Only thing I do off camera is switching PSU on.
(skip to 00:45 if you don't want to wait)
EEPROM::initBaudrate();
HAL::serialSetBaudrate(baudrate);
Extruder::initExtruder();
// sets auto leveling in eeprom init
EEPROM::init(); // Read settings from eeprom if wanted
UI_INITIALIZE;
for(uint8_t i = 0; i < E_AXIS_ARRAY; i++) {
currentPositionSteps[i] = 0;
currentPosition[X_AXIS] = currentPosition[Y_AXIS] = currentPosition[Z_AXIS] = 0.0;
//Commands::printCurrentPosition();
#if DISTORTION_CORRECTION
distortion.init();
#endif // DISTORTION_CORRECTION
updateDerivedParameter();
Commands::checkFreeMemory();
Commands::writeLowestFreeRAM();
HAL::setupTimer();
#if FEATURE_WATCHDOG
HAL::startWatchdog();
#endif // FEATURE_WATCHDOG
You see it writes start, inits display then starts watchdog. That is why you do not get a watchdog loop with this long boot time. So it really looks like it is the stepper initialization that is taking that long. I have now a prusa MK3 which also has these stepper drivers, but it starts much faster. So no idea what is so problematic, but I guess we should be happy that it works at least.
I might try getting new stepper motors... These have been through a lot of seating, reseating and changes.
I mean ive killed 2 arduinos and reflashed 3 arduinos countless times.
Anyway! Video is withou sound, but it does not matter since THERE IS NO SOUND. Not the first time I got it moving but its the first time ive been able to move it
Super many thanks
The printer moves, ill post my finished FW sometime tomorrow. Im able to answer any questions if anyone in the future have. I am no expert but I've learned a lot and currently my printer works so there is that.
Summary of what is done:
1.0.4 dev
Wanhao i3 plus (from 2016/17 somewhere)
Radds 1.6 (1.5 with a bugfix IIRC) + due with TMC2130 WITH SPI (soldered on the back, correct pins to your solderjob)
microswiss hotend
DIFFERENT Z axis SCREWS, not stock wanhao steps/mm
bl touch
mosfet for bed (moved from bed port to hot end port because i at some time suspected the built in mosfet to be dead, was wiring issue)
Some extra fans
From stock repetier I also have changed to have 2 z steppers with individual drivers
current for steppers isnt correctly tuned, they get very warm and Extruder can click sometimes but that is somewhat fixable
Fans are not correctly set up ATM, mostly because RADDS SWITCHES FANS ON AND OFF ON THE NEGATIVE, meaning for controlling the fans, the board pushes a CONSTANT +12v out the +port. And simply controlls on/off my opening/closing ground(negative), PWM is pulsing negative open/closed. I originally set up my fans with individual buck/boost conv for 24->12v on the positive with a shared negative. Have not changed it so every fan is permanently on when the hotend reaches 50c.
I have not gotten mesh-bed leveling to work (with octoprint atleast) but I am a master of manual leveling and my screws are stiff AF so I dont even level Z at the begining of prints (with glass bed)
Tweaked thermal runaway settings so that printer doesnt shut off if its cooling down from previous print and I start a new one (start heating from maybe 150c to 210, takes a while for heater to affect temp, causing thermal runaway alarm to trigger)
Last of all, HEAVILY MODIFIED CHASSI. 450 (minimum, more like 650) Z height, only 165 X because I messed up the design cuz i borked, and 205-ish Y (in slicer)
notes. stepper motor and cable can introduce EMI in temp sensor wire, causing wildly varying temp and watchdog.
Might have some more mods in the firmware and on the printer that I simply dont remember, I have some issues with ringing. Sorry for the rambling and that it took a year to upload, Project was on ICE for a long time since I was rebuilding the printer monstrosity and severe ADHD causes many, many delays.
Like so:
