+5 / -5 °c
Hello,
It would be super cool if we could set the temperature to rise/lower by 5 degrees instead of one in the UI :)
  • One is what most users need but you can also enter values directly with keyboard or use the slider to set it to any value you want.
  • Sure, but I hope that you will consider adding 2 new buttons for quick +5/-5 :)
  • Where should I get the space for that? And then users want +/- 10 :-)
  • How about a setting to set how many degree the button changes?
