Z probe configuration and endstop
Hello,
I use an inductive sensor as my z-min-endstop. I would like to continue using it, but I can't print because of it.
When I do my z homing, the extruder ends up 2.3mm higher than my bed. Then when it starts printing, it starts 2.3mm in the air.
I tried to change the endstop distance after homing to -2.3 but it doesn't go lower than 0.
Also, as it is with this problem, I can't map my bed to correct any imperfections in the flatness of the table.
I'm also sending a picure of my z probe with my extruder.
Can anyone help me, please?
Thanks!
  • How shall that work? your probe is closer to bed than nozzle so even if  you would come closer to bed your probe will touch the bed and nozzle is still in the air.
    Think that Probe should be located higher than nozzle
  • The nozzle is about one mm lower than the z probe. But the problem is still there. :)
  • so referring the Picture  the left gap is bigger than the right one?
  • your configuration.h would be helpful to see your settings
  • edited August 2018
    I hope it helps:
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
       generator: http://www.repetier.com/firmware/v092/
       as you expect.
    #define NUM_EXTRUDER 1
    #define MOTHERBOARD 33
    #include "pins.h"
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define FAN_THERMO_PIN -1
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 0
    #define XAXIS_STEPS_PER_MM 84.882636
    #define YAXIS_STEPS_PER_MM 84.882636
    #define ZAXIS_STEPS_PER_MM 400
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 153.667
    #define EXT0_INVERSE 0
    #define EXT0_ENABLE_ON 0
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 5
    #define EXT0_MAX_START_FEEDRATE 2
    #define EXT0_MAX_ACCELERATION 2
    #define EXT0_HEAT_MANAGER 1
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_I 2
    #define EXT0_PID_D 40
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 2
    #define RETRACTION_Z_LIFT 0
    #define RETRACTION_UNDO_SPEED 1
    #define JAM_STEPS 70
    #define JAM_SLOWDOWN_STEPS 100
    #define JAM_SLOWDOWN_TO 50
    #define JAM_ERROR_STEPS 30
    #define JAM_MIN_STEPS 5
    #define JAM_ACTION 2
    #define PID_CONTROL_RANGE 5
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 100
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define HEATED_BED_MAX_TEMP 300
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_SENSOR_PIN TEMP_2_PIN
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
    #define HEATED_BED_PID_IGAIN   33
    #define MIN_EXTRUDER_TEMP 150
    #define MAXTEMP 275
    #define MIN_DEFECT_TEMPERATURE -5
    #define MAX_DEFECT_TEMPERATURE 300
    // ##                             Laser configuration                                      ##
    automatically disabled.
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define ENDSTOP_X_MAX_INVERTING true
    #define ENDSTOP_Y_MAX_INVERTING true
    #define ENDSTOP_Z_MAX_INVERTING true
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 2
    #define ENDSTOP_X_BACK_ON_HOME 10
    #define ENDSTOP_Y_BACK_ON_HOME 10
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 1
    #define INVERT_Y_DIR 0
    #define INVERT_Z_DIR 0
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR -1
    #define X_MAX_LENGTH 150
    #define Y_MAX_LENGTH 150
    #define Z_MAX_LENGTH 200
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define DISTORTION_START_DEGRADE 0.02
    #define DISTORTION_XMIN 0
    #define DISTORTION_YMIN 26
    #define DISTORTION_XMAX 150
    #define DISTORTION_YMAX 150
    // ##                           Movement settings                                          ##
    #define BABYSTEP_MULTIPLICATOR 0.25
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_HOME_ON_POWER 0
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 40
    #define MAX_FEEDRATE_Y 40
    #define MAX_FEEDRATE_Z 10
    #define HOMING_FEEDRATE_X 40
    #define HOMING_FEEDRATE_Y 40
    #define HOMING_FEEDRATE_Z 10
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 0
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 20
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 20
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 10
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 20
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 20
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 10
    #define MAX_JERK 20
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define EXTRUDER_SWITCH_XY_SPEED 0
    #define DUAL_X_AXIS 0
    #define X2_STEP_PIN   ORIG_E1_STEP_PIN
    #define X2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Y2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Y2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z3_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z3_DIR_PIN    ORIG_E2_DIR_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 115200
    #define POWER_INVERTING 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 2
    #undef PS_ON_PIN
    #define PS_ON_PIN -1
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
    #define FEATURE_SERVO 0
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define UI_SERVO_CONTROL 0
            #define FEATURE_WATCHDOG 0
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 1
    #define Z_PROBE_PULLUP 1
    #define Z_PROBE_ON_HIGH 1
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET -26
    #define Z_PROBE_SPEED 1
    #define Z_PROBE_XY_SPEED 10
    #define Z_PROBE_SWITCHING_DISTANCE 5
    #define Z_PROBE_REPETITIONS 2
    #define Z_PROBE_HEIGHT 0
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 0
    #define Z_PROBE_Y1 26
    #define Z_PROBE_X2 150
    #define Z_PROBE_Y2 26
    #define Z_PROBE_X3 0
    #define Z_PROBE_Y3 124
    #define BED_LEVELING_METHOD 1
    #define BED_LEVELING_GRID_SIZE 4
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 1
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 1
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #endif
    #define SD_EXTENDED_DIR 0 /** Show extended directory including file length. Don't use this with Pronterface! */
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 2
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 0
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 1
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 0
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 0
    #define LANGUAGE_TR_ACTIVE 0
    #define UI_PRINTER_NAME "A Impressionadora"
    #define UI_PRINTER_COMPANY "Lab Hein"
    #define UI_ANIMATION 0
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 1
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 1
    #define CASE_LIGHTS_PIN -1
    #define UI_SET_PRESET_EXTRUDER_TEMP_PLA   190
    #define UI_SET_PRESET_EXTRUDER_TEMP_ABS   240
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define UI_SET_MAX_EXTRUDER_TEMP   260
    #define NUM_MOTOR_DRIVERS 0
    #endif
        "editMode": 1,
        "processor": 0,
        "baudrate": 115200,
        "bluetoothSerial": -1,
        "bluetoothBaudrate": 115200,
        "xStepsPerMM": 84.882636,
        "yStepsPerMM": 84.882636,
        "zStepsPerMM": 400,
        "xInvert": "1",
        "xInvertEnable": 0,
        "eepromMode": 2,
        "yInvert": "0",
        "yInvertEnable": 0,
        "zInvert": "0",
        "zInvertEnable": 0,
        "extruder": [
                "id": 0,
                "heatManager": 1,
                "pidDriveMin": 40,
                "pidDriveMax": 230,
                "pidMax": 255,
                "sensorType": 1,
                "sensorPin": "TEMP_0_PIN",
                "heaterPin": "HEATER_0_PIN",
                "maxFeedrate": 5,
                "startFeedrate": 2,
                "invert": "0",
                "invertEnable": "0",
                "acceleration": 2,
                "watchPeriod": 1,
                "pidP": 7,
                "pidI": 2,
                "pidD": 40,
                "advanceK": 0,
                "advanceL": 0,
                "waitRetractTemp": 150,
                "waitRetractUnits": 0,
                "waitRetract": 0,
                "stepsPerMM": 153.667,
                "coolerPin": -1,
                "coolerSpeed": 255,
                "selectCommands": "",
                "deselectCommands": "",
                "xOffset": 0,
                "yOffset": 0,
                "zOffset": 0,
                "xOffsetSteps": 0,
                "yOffsetSteps": 0,
                "zOffsetSteps": 0,
                "stepper": {
                    "name": "Extruder 0",
                    "step": "ORIG_E0_STEP_PIN",
                    "dir": "ORIG_E0_DIR_PIN",
                "advanceBacklashSteps": 0,
                "decoupleTestPeriod": 12,
                "jamPin": -1,
                "jamPullup": "0",
                "mirror": "0",
                "invert2": "0",
                "stepper2": {
                "preheat": 190
        "uiLanguage": 0,
        "uiController": 0,
        "xMinEndstop": 1,
        "yMinEndstop": 1,
        "zMinEndstop": 3,
        "xMaxEndstop": 1,
        "yMaxEndstop": 1,
        "zMaxEndstop": 1,
        "motherboard": 33,
        "driveSystem": 0,
        "xMaxSpeed": 40,
        "xHomingSpeed": 40,
        "xTravelAcceleration": 20,
        "xPrintAcceleration": 20,
        "yMaxSpeed": 40,
        "yHomingSpeed": 40,
        "yTravelAcceleration": 20,
        "yPrintAcceleration": 20,
        "zMaxSpeed": 10,
        "zHomingSpeed": 10,
        "zTravelAcceleration": 10,
        "zPrintAcceleration": 10,
        "xMotor": {
            "name": "X motor",
            "step": "ORIG_X_STEP_PIN",
            "dir": "ORIG_X_DIR_PIN",
            "enable": "ORIG_X_ENABLE_PIN"
        "yMotor": {
            "name": "Y motor",
            "step": "ORIG_Y_STEP_PIN",
            "dir": "ORIG_Y_DIR_PIN",
            "enable": "ORIG_Y_ENABLE_PIN"
        "zMotor": {
            "name": "Z motor",
            "step": "ORIG_Z_STEP_PIN",
            "dir": "ORIG_Z_DIR_PIN",
            "enable": "ORIG_Z_ENABLE_PIN"
        "enableBacklash": "0",
        "backlashX": 0,
        "backlashY": 0,
        "backlashZ": 0,
        "stepperInactiveTime": 360,
        "maxInactiveTime": 0,
        "xMinPos": 0,
        "yMinPos": 0,
        "zMinPos": 0,
        "xLength": 150,
        "yLength": 150,
        "zLength": 200,
        "alwaysCheckEndstops": "0",
        "disableX": "0",
        "disableY": "0",
        "disableZ": "0",
        "disableE": "0",
        "xHomeDir": "-1",
        "yHomeDir": "-1",
        "zHomeDir": "-1",
        "xEndstopBack": 10,
        "yEndstopBack": 10,
        "zEndstopBack": null,
        "deltaDiagonalRod": 445,
        "deltaAlphaA": 210,
        "deltaAlphaB": 330,
        "deltaAlphaC": 90,
        "deltaDiagonalCorrA": 0,
        "deltaDiagonalCorrB": 0,
        "deltaDiagonalCorrC": 0,
        "deltaMaxRadius": 150,
        "deltaRadiusCorrA": 0,
        "deltaRadiusCorrB": 0,
        "deltaRadiusCorrC": 0,
        "deltaXOffsetSteps": 0,
        "deltaYOffsetSteps": 0,
        "deltaZOffsetSteps": 0,
        "deltaSegmentsPerLine": 24,
        "stepperHighDelay": 0,
        "directionDelay": 0,
        "allowQuadstepping": "0",
        "doubleStepDelay": 0,
        "maxJerk": 20,
        "maxZJerk": 0.3,
        "moveCacheSize": 16,
        "moveCacheLow": 10,
        "lowTicksPerMove": 250000,
        "enablePowerOnStartup": "1",
        "echoOnExecute": "1",
        "sendWaits": "1",
        "ackWithLineNumber": "1",
        "killMethod": 1,
        "useAdvance": "0",
        "useQuadraticAdvance": "0",
        "powerInverting": 0,
        "mirrorX": 0,
        "mirrorXMotor": {
            "name": "Extruder 1",
            "step": "ORIG_E1_STEP_PIN",
            "dir": "ORIG_E1_DIR_PIN",
        "mirrorY": 0,
        "mirrorYMotor": {
        "mirrorZ": "0",
        "mirrorZMotor": {
        "mirrorZ3": "0",
        "mirrorZ3Motor": {
            "name": "Extruder 2",
            "step": "ORIG_E2_STEP_PIN",
            "dir": "ORIG_E2_DIR_PIN",
        "dittoPrinting": "0",
        "featureServos": "0",
        "servo0Pin": 11,
        "servo1Pin": -1,
        "servo2Pin": -1,
        "servo3Pin": -1,
        "featureWatchdog": "0",
        "hasHeatedBed": "1",
        "enableZProbing": "1",
        "extrudeMaxLength": 100,
        "homeOrder": "HOME_ORDER_XYZ",
        "featureController": 2,
        "uiPrinterName": "A Impressionadora",
        "uiPrinterCompany": "Lab Hein",
        "uiPagesDuration": 4000,
        "uiAnimation": "0",
        "uiDisablePageswitch": "1",
        "uiAutoReturnAfter": 30000,
        "featureKeys": "0",
        "uiEncoderSpeed": 1,
        "uiReverseEncoder": "0",
        "uiKeyBouncetime": 10,
        "uiKeyFirstRepeat": 500,
        "uiKeyReduceRepeat": 50,
        "uiKeyMinRepeat": 50,
        "featureBeeper": "1",
        "uiPresetBedTempPLA": 60,
        "uiPresetBedABS": 110,
        "uiPresetExtruderPLA": 190,
        "uiPresetExtruderABS": 240,
        "uiMinHeatedBed": 30,
        "uiMaxHeatedBed": 120,
        "uiMinEtxruderTemp": 170,
        "uiMaxExtruderTemp": 260,
        "uiExtruderFeedrate": 2,
        "maxBedTemperature": 300,
        "bedSensorType": 1,
        "bedSensorPin": "TEMP_2_PIN",
        "bedHeatManager": 0,
        "bedUpdateInterval": 5000,
        "bedPidDriveMin": 80,
        "bedPidDriveMax": 255,
        "bedPidP": 196,
        "bedPidI": 33,
        "bedPidD": 290,
        "bedPidMax": 255,
        "bedDecoupleTestPeriod": 300,
        "caseLightPin": -1,
        "caseLightDefaultOn": "1",
        "bedSkipIfWithin": 3,
        "gen1T0": 25,
        "gen1R0": 100000,
        "gen1Beta": 4036,
        "gen1MinTemp": -20,
        "gen1MaxTemp": 300,
        "gen1R1": 0,
        "gen1R2": 4700,
        "gen2T0": 25,
        "gen2R0": 100000,
        "gen2Beta": 4036,
        "gen2MinTemp": -20,
        "gen2MaxTemp": 300,
        "gen2R1": 0,
        "gen2R2": 4700,
        "gen3T0": 25,
        "gen3R0": 100000,
        "gen3Beta": 4036,
        "gen3MinTemp": -20,
        "gen3MaxTemp": 300,
        "gen3R1": 0,
        "gen3R2": 4700,
        "userTable0": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable1": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable2": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "tempHysteresis": 0,
        "pidControlRange": 5,
        "skipM109Within": 2,
        "extruderFanCoolTemp": 50,
        "minTemp": 150,
        "maxTemp": 275,
        "minDefectTemp": -5,
        "maxDefectTemp": 300,
        "arcSupport": "1",
        "forceChecksum": "0",
        "sdExtendedDir": "0",
        "featureFanControl": "1",
        "fanPin": "ORIG_FAN_PIN",
        "featureFan2Control": "0",
        "fan2Pin": "ORIG_FAN2_PIN",
        "fanThermoPin": -1,
        "fanThermoMinPWM": 128,
        "fanThermoMaxPWM": 255,
        "fanThermoMinTemp": 45,
        "fanThermoMaxTemp": 60,
        "fanThermoThermistorPin": -1,
        "fanThermoThermistorType": 1,
        "scalePidToMax": 0,
        "zProbeBedDistance": 10,
        "zProbePullup": "1",
        "zProbeOnHigh": "1",
        "zProbeXOffset": 0,
        "zProbeYOffset": -26,
        "zProbeWaitBeforeTest": "0",
        "zProbeSpeed": 1,
        "zProbeXYSpeed": 10,
        "zProbeHeight": 0,
        "zProbeStartScript": "",
        "zProbeFinishedScript": "",
        "featureAutolevel": "1",
        "zProbeX1": 0,
        "zProbeY1": 26,
        "zProbeX2": 150,
        "zProbeY2": 26,
        "zProbeX3": 0,
        "zProbeY3": 124,
        "zProbeSwitchingDistance": 5,
        "zProbeRepetitions": 2,
        "sdSupport": "1",
        "sdCardDetectPin": -1,
        "sdCardDetectInverted": "0",
        "uiStartScreenDelay": 1000,
        "xEndstopBackMove": 5,
        "yEndstopBackMove": 5,
        "zEndstopBackMove": 2,
        "xEndstopRetestFactor": 3,
        "yEndstopRetestFactor": 3,
        "zEndstopRetestFactor": 3,
        "xMinPin": "ORIG_X_MIN_PIN",
        "yMinPin": "ORIG_Y_MIN_PIN",
        "zMinPin": "ORIG_Z_MIN_PIN",
        "xMaxPin": "ORIG_X_MAX_PIN",
        "yMaxPin": "ORIG_Y_MAX_PIN",
        "zMaxPin": "ORIG_Z_MAX_PIN",
        "deltaHomeOnPower": "0",
        "fanBoardPin": -1,
        "heaterPWMSpeed": 0,
        "featureBabystepping": "1",
        "babystepMultiplicator": 0.25,
        "pdmForHeater": "0",
        "pdmForCooler": "0",
        "psOn": -1,
        "mixingExtruder": "0",
        "featureAxisComp": "1",
        "axisCompTanXY": 0,
        "axisCompTanXZ": 0,
        "axisCompTanYZ": 0,
        "retractOnPause": 2,
        "pauseStartCommands": "",
        "pauseEndCommands": "",
        "distortionCorrection": "1",
        "distortionCorrectionR": 100,
        "distortionPermanent": "1",
        "distortionStartDegrade": 0.02,
        "distortionEndDegrade": 1,
        "distortionXMin": 0,
        "distortionXMax": 150,
        "distortionYMin": 26,
        "distortionYMax": 150,
        "sdRunOnStop": "",
        "featureRetraction": "1",
        "autoretractEnabled": "0",
        "retractionLength": 3,
        "retractionLongLength": 13,
        "retractionSpeed": 2,
        "retractionZLift": 0,
        "retractionUndoSpeed": 1,
        "filamentChangeXPos": 0,
        "filamentChangeYPos": 0,
        "filamentChangeZAdd": 2,
        "filamentChangeRehome": 1,
        "fanKickstart": 200,
        "servo0StartPos": -1,
        "servo1StartPos": -1,
        "servo2StartPos": -1,
        "servo3StartPos": -1,
        "uiDynamicEncoderSpeed": "1",
        "uiServoControl": 0,
        "killIfSensorDefect": "0",
        "jamSteps": 70,
        "jamSlowdownSteps": 100,
        "jamSlowdownTo": 50,
        "jamErrorSteps": 30,
        "jamMinSteps": 5,
        "jamAction": 2,
        "primaryPort": 0,
        "numMotorDrivers": 0,
        "motorDrivers": [
                "t": "None",
                "s": "",
                "invertDirection": "0",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "invertEndstop": "0",
                "minEndstop": "1",
                "endstopPullup": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
        "manualConfig": "",
        "zHomeMinTemperature": 0,
        "zHomeXPos": 999999,
        "zHomeYPos": 999999,
        "zHomeHeatHeight": 20,
        "zHomeHeatAll": "1",
        "zProbeZOffsetMode": 0,
        "zProbeZOffset": 0,
        "uiBedCoating": "1",
        "langEN": "1",
        "langDE": "0",
        "langNL": "0",
        "langPT": "1",
        "langIT": "0",
        "langES": "0",
        "langFI": "0",
        "langSE": "0",
        "langFR": "0",
        "langCZ": "0",
        "langPL": "0",
        "langTR": "0",
        "accelerationFactorTop": 100,
        "bendingCorrectionA": 0,
        "bendingCorrectionB": 0,
        "bendingCorrectionC": 0,
        "supportLaser": "0",
        "laserPin": -1,
        "laserOnHigh": "1",
        "defaultPrinterMode": 0,
        "supportCNC": "0",
        "cncWaitOnEnable": 300,
        "cncWaitOnDisable": 0,
        "cncEnablePin": -1,
        "cncEnableWith": "1",
        "cncDirectionPin": -1,
        "cncDirectionCW": "1",
        "startupGCode": "",
        "jsonOutput": "0",
        "bedLevelingMethod": 1,
        "bedCorrectionMethod": 0,
        "bedLevelingGridSize": 4,
        "bedLevelingRepetitions": 5,
        "bedMotor1X": 0,
        "bedMotor1Y": 0,
        "bedMotor2X": 200,
        "bedMotor2Y": 0,
        "bedMotor3X": 100,
        "bedMotor3Y": 200,
        "zProbeRequiresHeating": "0",
        "zProbeMinTemperature": 150,
        "adcKeypadPin": -1,
        "sharedExtruderHeater": "0",
        "extruderSwitchXYSpeed": 0,
        "dualXAxis": "0",
        "boardFanSpeed": 255,
        "x2Invert": 0,
        "y2Invert": 0,
        "z2Invert": 0,
        "z3Invert": 0,
        "z4Invert": 0,
        "x2MinEndstop": 0,
        "y2MinEndstop": 0,
        "x2MaxEndstop": 0,
        "y2MaxEndstop": 0,
        "mirrorZ4": "0",
        "mirrorZ4Motor": {
            "name": "Extruder 3",
            "step": "ORIG_E3_STEP_PIN",
            "dir": "ORIG_E3_DIR_PIN",
        "uiHeadline": "",
        "bedPreheat": 55,
        "zProbeDisableHeaters": "0",
        "zProbeEveryPoint": "",
        "x2MinPin": -1,
        "y2MinPin": -1,
        "x2MaxPin": -1,
        "y2MaxPin": -1,
        "jamMethod": 1,
        "zProbeDelay": 0,
        "laserWarmupTime": 0,
        "laserPwmMax": 255,
        "laserWatt": 2,
        "cncPwmMax": 255,
        "cncRpmMax": 8000,
        "cncSafeZ": 150,
        "keepAliveInterval": 2000,
        "moveXWhenHomed": "0",
        "moveYWhenHomed": "0",
        "moveZWhenHomed": "0",
        "preheatTime": 30000,
        "multiZEndstopHoming": "0",
        "z2MinMaxPin": -1,
        "z2MinMaxEndstop": 0,
        "extruderIsZProbe": "0",
        "boardFanMinSpeed": 0,
        "doorPin": -1,
        "doorEndstop": 0,
        "zhomePreRaise": 2,
        "zhomePreRaiseDistance": 10,
        "dualXResolution": "0",
        "x2axisStepsPerMM": 100,
        "coolerPWMSpeed": 0,
        "maxFanPWM": 255,
        "raiseZOnToolchange": 0,
        "distortionLimitTo": 2,
        "automaticPowerup": 0,
        "hasTMC2130": "0",
        "TMC2130Sensorless": "0",
        "TMC2130Steathchop": "1",
        "TMC2130Interpolate256": "1",
        "TMC2130PWMAmpl": 255,
        "TMC2130PWMGrad": 1,
        "TMC2130PWMAutoscale": "1",
        "TMC2130PWMFreq": 2,
        "TMC2130CSX": -1,
        "TMC2130CSY": -1,
        "TMC2130CSZ": -1,
        "TMC2130CSE0": -1,
        "TMC2130CSE1": -1,
        "TMC2130CSE2": -1,
        "TMC2130CurrentX": 1000,
        "TMC2130CurrentY": 1000,
        "TMC2130CurrentZ": 1000,
        "TMC2130CurrentE0": 1000,
        "TMC2130CurrentE1": 1000,
        "TMC2130CurrentE2": 1000,
        "microstepX": 16,
        "microstepY": 16,
        "microstepZ": 16,
        "microstepE0": 16,
        "microstepE1": 16,
        "microstepE2": 16,
        "parkPosX": 0,
        "parkPosY": 0,
        "parkPosZ": 10,
        "hasMAX6675": false,
        "hasMAX31855": false,
        "hasGeneric1": false,
        "hasGeneric2": false,
        "hasGeneric3": false,
        "hasUser0": false,
        "hasUser1": false,
        "hasUser2": false,
        "numExtruder": 1,
        "version": 92.9,
        "primaryPortName": ""
    as i never used zmin homing it´s just a guess.
    did you try to Change #define Z_MIN_POS 0
    from 0 to 2.3 ?   (distance you have when probe Triggers)
  • I'm gonna try it in a few minutes and then I post the results
  • Well, it doesn't go lower because it triggers the endstop.. One thing that I saw is that the maximum endstop doesnt work. It tries to go further, even with the endstops turned on. I made it home to the Zmin, because it didn't stop when the probe was activated. This problem goes for every axis, the opposite endstop from homing doesn't stop the extruder, nor the table.
    for the second issue you should search
    Change from 0 to 1
  • I'm gonna change it, thanks. Now it'll check both endstops at homing? is that it?
    Yes, I read, and I did my best to configure it properly. I confess that I'm not a pro, and I have my doubts...
    I did the mapping of my table once using the z probe and I didn't know if it was going to correct the imperfections of the table or not... it gave me a matrix of the highs and I didn't know what to do with it.
    Even doing so, it doesn't print in the right spot, it doesn't get near the extruder because it triggers the inductive endstop.
  • so as i wrote before,never tried zmin homing    and to be honest i just have 3 endstops installed .(xmin ymax and z max) may be i´ll find the time tomorrow to do some tests.sorry but for now i have no more suggestions
    Thanks for the help. I'll wait to see if someone can help me too!
    This line sets the distance from the bed to the nozzle when the probe triggers, in your case it should be set to 2.3
    Then when you home Z and send a G1 Z0 the nozzle should just touch the bed.
    So you dont try probing the edge of the bed(not a good idea with inductive probe) i would change
    too
    #define Z_PROBE_X1 10
    #define Z_PROBE_Y1 36
    #define Z_PROBE_Y2 36
    #define Z_PROBE_X3 10
  • Nice, I'm gonna try it! Thanks
    too
    It worked! Thaks!
    It worked at homing... When I tried to print, the extruder came back to be 2.3mm higher than the table. What should I do?
  • Did you make the changes in the config.h or direct in eeprom ?
    changes done in config.h need to be updated to eeprom with M502 M500.
    Do you have any Z offsets set in the slicer ?
    maybe post the first 30 lines of a g-code you are trying to print might show something.
