Toggle navigation
Categories
Discussions
About Us
Privacy Policy
Sign In
Home
Repetier-Server
Connect Repetier Server to Klipper firmware
1
Dimitar
August 2018
Also it seems the Klipper Extended G-Code Commands are not working.
Repetier
August 2018
Did you prefix them with a #? I guess you mean the gcodes that do not follow gcode syntax and therefore are no gcodes. In server if you prefix a line with
The content will be send 1:1 without checksum etc. That should work on all firmwares.
Dimitar
August 2018
Yes. It works. Thanks !
1
Sign In
or
Register
to comment.
