Confusing Z-Probe Settings
Hello,
I´m a bit confused about the Z-Probe settings.
1. There are the settings for the Z-correction.
2. There are the settings for the Z-probe
Both settings influence each other.
I´m not sure how to setup the x and y (min/max on Z-correction) and (P1,P2,P3) on Z-probe.
My Probe is located on (-43/5) (x/y)
Who knows the right settings.
1. Z-correction size. (XMin,YMin/XMax,YMax).
Then the System know where are the ranges for the Probe
2. X/Y-offset of the Probe and GridSize
with this Information it should be done. P1-P3 can be calculated from the system.
Are you sure the z-probe is realy working ?
https://www.repetier.com/documentation/repetier-firmware/z-probing/
Also the configuration tool explains a bit more about probing and physical settings.
after autoleveling i have this values.
Why is Z-Probe 5.x or 6.x. I would expect that it is Z_Probe_height(0.8) + tollerance.
i give up with Z-Probe. For me it looks like it don´t work at all.
After i made bed-leveling the extruder is more hiegh as i don´t use it.
without bed-leveling: extruder distance 0.06 mm.
with bed-leveling: extruder distance 0.3 mm.
even i correct the Z_PROBE_HEIGHT, it don´t change anything
