Z probe settings
Now that I finally got Repetier up and running, I need a bit of help setting up a Z probe. so far I have it attached and wired, the led lights up as expected, but, it is not stopping, there are so many settings in there I get lost.
The probe is an IR probe.
Here is what I have set, I am sure it is all wrong ,but at least the printer still runs.
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 0
#define FEATURE_Z_PROBE 0
#define Z_PROBE_BED_DISTANCE 1.99
#define Z_PROBE_PIN -1
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 30
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 40
#define Z_PROBE_START_SCRIPT ""G32
#define Z_PROBE_FINISHED_SCRIPT "" G28 10
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 20
#define Z_PROBE_Y1 20
#define Z_PROBE_X2 280
#define Z_PROBE_Y2 280
#define Z_PROBE_X3 100
#define Z_PROBE_Y3 160
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 300
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 200
#define BED_MOTOR_3_Y 300
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
1) why it is set to raise up 40 mm after it homes.
2) and how to set it for print height.
I press print, it homes Z as expected buy only momentarily then continues to go down into the bed, the X and Y do not hope, I can home the individually . It is not probing
Before making these changes the endstops worked as they should.
Here are the changes made
#define Z_PROBE_MIN_TEMPERATURE 0 //so the extruder does not heat during probing.
It make me wonder if it is all worth the effort, I have been over a week trying to set this thing to print, still not there.
For heating I guess you get a decoupling error. Happens if you are heating a different part then you measure temperature or if heater pin is wrong. Check closely all temperatures and log if you enable a printer.
Making a printer on your own requires some knowledge or much research. Once you know how all is connected it is quite easy, but for first timers with not much programming experience it can be a bit demanding.
I am getting a bit worried that I will burn something out.
Hope you can put we straight here.
these are the settings I have set.
#define FEATURE_Z_PROBE 1
Then you can check if values amke sense e.g. M119 to see if z probe is giving correct signals.
If you use z min homing I assume z probe is used as z min endstop, so use homing order with preheat and set preheat temperature 0 and homing position x > 30 e.g. 50.
Most of the things you mention here I cannot find.
So I m going to scrap the idea of the Z probe and go back to using the mechanical endstop.
One thing I must say regarding the firmware, it is not intuitive enough there are no comments to help people like me.But thanks for trying.
https://www.repetier.com/documentation/repetier-firmware/rffirst-tests/
https://www.repetier.com/documentation/repetier-firmware/z-probing/
https://www.repetier.com/documentation/repetier-firmware/rftroubleshooting/
Thank you very much, for taking the time.
