Delta printer calibration with V1.0dev
Hi Repetier,
Spent two days trying to solve this problem, ...now completely lost
I just upgraded from .92 to 1.0.0dev version and recalibrated my delta printer using
https://www.repetier.com/documentation/repetier-firmware/z-probing/
- M321 S2
- G28
- G131
- M99 X0, M99 Y0, M99 Z0
- G132 S1
- M320 S2
- G32 S2
Calibration is OK except the area opposite to A tower
in this zone, the extruder is 0.25mm over the plate
I tested my glass bed (D200mm) and it is not warped, so I shouldn't use G33
Is there a setting to raise/lower a specific region of the bed
Kindly let me know what I am doing wrong
TIA
Thanks for your for your prompt response
>> changing b or c angle will help here
Just to make sure, are you referring to Alpha A, Alpha B and Alpha C parameters ??
Considering the specific area to trim, which angle should I try to adjust first ??
You are doing a great job by the way
That did the trick, thanks
My new setup:
Alpha A 210.500
Alpha B 329.500
Alpha C 90.500
This is my Delta printer calibration workflow:
- M322 S3 Reset auto level matrix permanently
- G33 R0 Delete distortion map
- G28 Home
- G131 Remove any extruder offset
- M99 X0,Y0,Z0 Adjust sliders using a stick
- G132 S1 Measure tower endstop offsets & stores
- M320 S2 Activate auto level permanently
- G32 S2 3 mesures, fix rotation of bed & store
- G33 S2 3 mesures, fix distorsion of bed & store
- M323 S1 P1 Enable distortion correction permanently
Is there any missing commands ??
Is there any useless commands ??
Finally 'Z-probe speed' EEPROM setting seems to have no effect on G32 & G33 process (was OK with V0.92)
Thanks again for your help
Is it possible to make donation using PayPal ??
https://www.repetier.com/download-software/
Note that
is normally only done once per printer unless you change endstops. No need to repeat this on recalibrations.
>> For donation use this link:
Done
I was already on this page and didn't donate at that time because I only saw credit cards logos,
and didn't want to enter my cards details
I admit I was too lazy to read the whole text, but I may not have been the only one
One suggestion: just add a PayPal logo to clear this matter
