RPi - Touch UI not loading, at CLI
Installed from SD card latest image onto Pi 3B+ with 7" touchscreen and was all working great.
I then did a full package update (apt-get upgrade)
WebUI still works fine but touchscreen is at CLI
How do I set the UI to auto load / where are the logs I need to check whats gone wrong ?
The .bashrc file does contain the xinit element at the end to see if it needs to start the GUI with Chrome.
syslog does not indicate any errors I can see - anything else to check ?
Could it be when I changed the default password I broke some auto login ?
sudo rpiconfig
i think it is named. There is menu entry to enable commandline start screen with autologin, maybe you need to redo because of the password change.
BTW so far I'm loving repetier and its been worth every penny - keep up the great work !
