radds 1.6 arduino due extruder sound like working but not spinning
I tried to configure radds 1.6 arduino due, without success
my printer corexy
x, y, z are drived by 2dm542 with nema23
extruder is rasp128 nema 17
motors x, y, z are working
extruder sound like working but is not spinning
I tried  STEP_DOUBLER_FREQUENCY like 50000 but nothing happend
any suggestions ?
my config attached
  • #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
       This file is optimized for version 1.0.2
       as you expect.
    #define NUM_EXTRUDER 1
    #define MOTHERBOARD 402
    #define RFSERIAL Serial
    #include "pins.h"
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN ORIG_FAN_PIN
    #define BOARD_FAN_SPEED 255
    #define BOARD_FAN_MIN_SPEED 0
    #define FAN_THERMO_PIN -1
    #define FAN_THERMO_THERMISTOR_TYPE 0
    #undef X_MAX_PIN
    #define X_MAX_PIN -1
    #undef Y_MAX_PIN
    #define Y_MAX_PIN -1
    #undef Z_MAX_PIN
    #define Z_MAX_PIN -1
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 2
    #define XAXIS_STEPS_PER_MM 160
    #define YAXIS_STEPS_PER_MM 160
    #define ZAXIS_STEPS_PER_MM 80
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define KILL_IF_SENSOR_DEFECT 1
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 835
    #define EXT0_INVERSE 0
    #define EXT0_ENABLE_ON 1
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_HEAT_MANAGER 3
    #define EXT0_PREHEAT_TEMP 10
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_I 2
    #define EXT0_PID_D 40
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 1
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define JAM_METHOD 1
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define NUM_TEMPS_USERTHERMISTOR0 20
    #define USER_THERMISTORTABLE0 {{3,8064},{29,7640},{42,7216},{52,6792},{60,6368},{67,5944},{74,5520},{79,5096},{85,4672},{91,4248},{98,3824},{104,3400},{111,2976},{119,2552},{128,2128},{139,1704},{153,1280},{173,856},{208,432},{609,8}}
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define COOLER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define HEATED_BED_PREHEAT_TEMP 10
    #define HEATED_BED_MAX_TEMP 150
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_SENSOR_TYPE 5
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
    #define MIN_EXTRUDER_TEMP 10
    #define MAXTEMP 285
    #define MIN_DEFECT_TEMPERATURE -15
    #define MAX_DEFECT_TEMPERATURE 295
    // ##                             Laser configuration                                      ##
    automatically disabled.
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    #define LASER_WARMUP_TIME 0
    #define LASER_PWM_MAX 255
    #define LASER_WATT 2
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define CNC_PWM_MAX 255
    #define CNC_RPM_MAX 8000
    #define CNC_SAFE_Z 150
    #define ENDSTOP_PULLUP_Y_MIN false
    #define X2_MIN_PIN -1
    #define X2_MAX_PIN -1
    #define Y2_MIN_PIN -1
    #define Y2_MAX_PIN -1
    #define Z2_MINMAX_PIN -1
    #define DOOR_PIN -1
    #define DOOR_PULLUP 1
    #define DOOR_INVERTING 1
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 2
    #define MOVE_X_WHEN_HOMED 0
    #define MOVE_Y_WHEN_HOMED 0
    #define MOVE_Z_WHEN_HOMED 0
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 0
    #define INVERT_X2_DIR 0
    #define INVERT_Y_DIR 1
    #define INVERT_Y2_DIR 0
    #define INVERT_Z_DIR 0
    #define INVERT_Z2_DIR 0
    #define INVERT_Z3_DIR 0
    #define INVERT_Z4_DIR 0
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR -1
    #define X_MAX_LENGTH 380
    #define Y_MAX_LENGTH 330
    #define Z_MAX_LENGTH 500
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define PARK_POSITION_X 0
    #define PARK_POSITION_Y 10
    #define DISTORTION_LIMIT_TO 2
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 190
    #define DISTORTION_YMAX 190
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_HOME_ON_POWER 0
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 200
    #define MAX_FEEDRATE_Y 200
    #define MAX_FEEDRATE_Z 2
    #define HOMING_FEEDRATE_X 40
    #define HOMING_FEEDRATE_Y 40
    #define HOMING_FEEDRATE_Z 2
    #define ZHOME_PRE_RAISE 0
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define ENABLE_BACKLASH_COMPENSATION 1
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 3
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define MAX_JERK 20
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define DUAL_X_RESOLUTION 0
    #define Z4_STEP_PIN   ORIG_E3_STEP_PIN
    #define Z4_DIR_PIN    ORIG_E3_DIR_PIN
    #define USE_ADVANCE 0
    #define ENABLE_QUADRATIC_ADVANCE 1
    #define BAUDRATE 250000
    #define ENABLE_POWER_ON_STARTUP 0
    #define POWER_INVERTING 0
    #define AUTOMATIC_POWERUP 1
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 2
    #undef PS_ON_PIN
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    #define FEATURE_SERVO 0
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define UI_SERVO_CONTROL 0
    #define MAX_FAN_PWM 255
            #define FEATURE_WATCHDOG 1
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 1
    #define EXTRUDER_IS_Z_PROBE 0
    #define Z_PROBE_DISABLE_HEATERS 1
    #define Z_PROBE_PIN ORIG_Z_MAX_PIN
    #define Z_PROBE_PULLUP 1
    #define Z_PROBE_ON_HIGH 1
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET 0
    #define Z_PROBE_SPEED 2
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_REPETITIONS 1
    #define Z_PROBE_HEIGHT 40
    #define Z_PROBE_DELAY 0
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 20
    #define Z_PROBE_Y1 20
    #define Z_PROBE_X2 160
    #define Z_PROBE_Y2 20
    #define Z_PROBE_X3 20
    #define Z_PROBE_Y3 160
    #define BED_LEVELING_METHOD 0
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 1
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 1
    #undef SDCARDDETECT
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 7
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 0
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 0
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 0
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 0
    #define LANGUAGE_TR_ACTIVE 0
    #define UI_PRINTER_NAME "sz3bbylA"
    #define UI_PRINTER_COMPANY "nos30"
    #define UI_SPEEDDEPENDENT_POSITIONING 1
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 1
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 1
    #define CASE_LIGHTS_PIN -1
    #define UI_SET_MIN_HEATED_BED_TEMP  10
    #define UI_SET_MAX_HEATED_BED_TEMP 140
    #define UI_SET_MIN_EXTRUDER_TEMP   10
    #define UI_SET_MAX_EXTRUDER_TEMP   285
    #define NUM_MOTOR_DRIVERS 0
  • Invert enable on for extruder. I think the raps enable on low signal. Otherwise how does a extruder sound that is not working. A high pitch sound would mean you are loosing steps, normally happens when steps per mm are too high, so in that case check what is stored in eeprom or try with very low speed for testing.
  • I already done this, I hear motor but not spinning, look like I have one coil in opposite directions, I will check again this but connection was taken from old mega + ramps and fit in radds+due Arduino
  • Ok one coil only will not move. Also low current will not move. Sound shows that config is at least correct.
  • ok, fixed, the jack on extruder was in opposite direction on controller.
    but one think remain unclear for me
    with jack in opposite direction means red is in black and blue in green, that means the motor must spin in opposite direction
    but i was surprised to realised that an coil was in wrong direction and motor just spin and turn back, doing this forever
    also when i changed motor test 1.8 degree with e3d 0.9 degree must swap red with green,
    thank you .
    two more problem i got with my controller
    after few writings on arduino due,  display begin to show me strange characters instead of x, y z, ext temp and bed temp
    on radds i saw an ttl converter (i think from 3.3v to 5 v -> display )and maybe is broke
    or second variant is arduino to chose something like new library for printing chars on display, wich is not compatible with firmware
    i don't think that HCT365 2L5E401 can be broke so fast and i don't know any method to verify this
    any suggestions ?
    i will try to upload a picture but until now all I uploaded not show me in post
    i marked with thin red line that ttl converter
    and second problem is I use atx power supply , green wire on atx pin on controller
    if i close machine display begin flashing like source try to start many times
    i put a normal diode on green wire which solve problem partial
    now display is flashing every time i put something in plug and after is quiet
    i don't thing is a good solving of my problem
    any suggestions ?
  • Garbage chars happen when display gets wrong signals, normally it starts good and at on point it goes wrong. Check that the cable does not cross heater cables. I can reproduce this if i‘m close to bed wires. There is an option to reinit display every second if it happens on a regular basis.
