Slic3r PE doesn't work in Repetier
I’ve installed the last version of Repetier Host (2.1.2), I’m triying to slice a model with Slic3r Prusa Edition but I am getting few troubles:
When I try to slice with Sli3r PE, I can’t choose any print seetings in Repetier, they doesn’t appear in the tabs. ¿Any idea why is this happening?
If I press “Configuration” it opens Slic3r PE v 1.40.0 –beta, but I want to use Slic3er PE v 1.40.0. (the one I have installed) Is Repetier installing beta version? How can I redirect it to v 1.40.0?
I'm newbie using Repetier Host so probably this is easy to solve but I have no idea how to do it. I appreciate if someone could help me.
Regards,
I’ve installed the last version of Repetier Host (2.1.2) with Slic3rPE v1.40.1-rc+win64
If there are no configs make sure to use the right directory and check log for error messages. If config dir is correct and has entries, please send us the directory for testing if something crashes for unknown reasons.
It seems Repetier is slicing but I have no idea which settings is taking for that.
Slic3rPE default is $HOME/AppData/Roaming/SlicerPE
I think. See if the subfolders contain files. Start configuration to see the native gui and see if that shows configurations.
The subfolders : filament, print and printer don't have any file.
If I start configuration the native gui shows the configurations
I replaced the empty folders in the data directory with the ones I download from Prusa https://github.com/prusa3d/Slic3r-settings and now it's working. <span>
