Incomplete preview on files sliced with KISSlicer
Just started using Repetier and my models all appear to be OK for the first ~39 layers and then my paths no longer seem to show correctly. The files print correctly with other g-code senders.
Files are sliced with KISSlicer64.
Is there a setting I'm missing somewhere?
Screenshot of the model and paths are found below, as well as my g-code.
Thank you.
https://www.dropbox.com/sh/qiv1ggzrmc4qcqa/AABhA_sDczK2WJedRsavgkB5a?dl=0
~Andrew
Thank you.
~Andrew
Seems to just be gcode output from KISslicer, but despite manually browsing the file I can't tell why the preview fails. Everything looks OK to me...
The filament usage doubles, which is an error. Will fix that for next release.
The E0.0001 was a legacy extrude value to fix an old firmware bug. Removing that seems to have solved the display problem. Pretty sure that bug has been fixed...
