Homing failed on miniKossel
I Repetier,
I have upgrade firmware on my mini Kossel printer dual extruder from an old dev version ( 03-05-2017 1.0 dev) to the new dev version that I have download after conversion using configuration toll at http://www.repetier.com/firmware/dev.
I can no longer perform axis homing. A pop-up window opens on Repetier host and shows the following message:
Hint: You are allowed to move the extruder around and to extrude filament in order to change the filament or refill the nozzle if oozing occured. The host will restore the position at the start of the pause for you.
and on the log windows on the bottom of Repetier Host :
21:40:25.646 : N25 G28*36
21:40:25.653 : Info:Autoleveling disabled
21:40:25.803 : N26 M539 P1*89
21:40:25.806 : RequestPause:Homing failed!
21:40:26.244 : SelectExtruder:0
21:40:26.247 : X:0.00 Y:0.00 Z:190.700 E:0.0000
21:40:26.252 : Info:Autoleveling enabled
What could be the problem ? keep in mind that I have updated the firmware many times using the same methods. Obviously if I reload the old firmware everything works correctly.
Below is the new Configuration.h file I use
Alberto Senni
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
   This file is optimized for version 1.0.0dev
   as you expect.
#define NUM_EXTRUDER 2
#define MOTHERBOARD 33
#include "pins.h"
#undef FAN_PIN
#define FAN_PIN 11
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define BOARD_FAN_SPEED 255
#define BOARD_FAN_MIN_SPEED 0
#define FAN_THERMO_PIN -1
#define FAN_THERMO_THERMISTOR_TYPE 0
#undef X_MIN_PIN
#define X_MIN_PIN -1
#undef Y_MIN_PIN
#define Y_MIN_PIN -1
#undef Z_MIN_PIN
#define Z_MIN_PIN -1
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL  -1
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 3
#define ZAXIS_STEPS_PER_MM 100
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 981.558
#define EXT0_TEMPSENSOR_TYPE 8 // alsen 8 per semtec e3dv6 e 1 per E3dv6 compatibile
#define EXT0_INVERSE 0
#define EXT0_ENABLE_ON 0
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 200
#define EXT0_MAX_ACCELERATION 500
#define EXT0_HEAT_MANAGER 1
#define EXT0_PREHEAT_TEMP 190
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define EXT1_X_OFFSET 0
#define EXT1_Y_OFFSET 0
#define EXT1_Z_OFFSET 0
#define EXT1_STEPS_PER_MM 370
#define EXT1_TEMPSENSOR_TYPE 1
#define EXT1_INVERSE 0
#define EXT1_ENABLE_ON 0
#define EXT1_MIRROR_STEPPER 0
#define EXT1_INVERSE2 0
#define EXT1_MAX_FEEDRATE 50
#define EXT1_HEAT_MANAGER 1
#define EXT1_PREHEAT_TEMP 190
#define EXT1_WATCHPERIOD 1
#define EXT1_PID_I 2
#define EXT1_PID_D 40
#define EXT1_PID_MAX 255
#define EXT1_ADVANCE_K 0
#define EXT1_ADVANCE_L 0
#define EXT1_JAM_PIN -1
#define EXT1_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define JAM_METHOD 1
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 0
#define COOLER_PWM_SPEED 0
#define HAVE_HEATED_BED 1
#define SKIP_M190_IF_WITHIN 3
#define HEATED_BED_SENSOR_TYPE 2
#define HEATED_BED_SENSOR_PIN   TEMP_1_PIN  // alsen era  7
#define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 275
// ##                             Laser configuration                                      ##
automatically disabled.
#define SUPPORT_LASER 0
#define LASER_PIN -1
#define LASER_ON_HIGH 1
#define LASER_WARMUP_TIME 0
#define LASER_PWM_MAX 255
#define LASER_WATT 2
// ##                              CNC configuration                                       ##
#define SUPPORT_CNC 0
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN -1
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
#define CNC_PWM_MAX 255
#define CNC_RPM_MAX 8000
#define CNC_SAFE_Z 150
#define X2_MIN_PIN -1
#define X2_MAX_PIN -1
#define Y2_MIN_PIN -1
#define Y2_MAX_PIN -1
#define Z2_MINMAX_PIN -1
#define min_software_endstop_z true
#define DOOR_PIN -1
#define DOOR_PULLUP 1
#define DOOR_INVERTING 1
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 5
#define ENDSTOP_Z_BACK_ON_HOME 1
#define MOVE_X_WHEN_HOMED 0
#define MOVE_Y_WHEN_HOMED 0
#define MOVE_Z_WHEN_HOMED 0
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 1
#define INVERT_X2_DIR 0
#define INVERT_Y_DIR 1
#define INVERT_Y2_DIR 0
#define INVERT_Z_DIR 1
#define INVERT_Z2_DIR 0
#define INVERT_Z3_DIR 0
#define INVERT_Z4_DIR 0
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR 1
#define X_MAX_LENGTH 200
#define Y_MAX_LENGTH 200
#define Z_MAX_LENGTH 197
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define PARK_POSITION_X 0
#define PARK_POSITION_Y 10
#define DISTORTION_LIMIT_TO 2
#define DISTORTION_CORRECTION_R 60 // alsen era 100 me per una minikossel non va bene
#define DISTORTION_EXTRAPOLATE_CORNERS 1
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_DIAGONAL_ROD 217 // mm
#define DELTA_ALPHA_A 210
#define DELTA_ALPHA_B 330
#define DELTA_ALPHA_C 90
#define DELTA_MAX_RADIUS 150
#define ROD_RADIUS 117
#define PRINTER_RADIUS 117
#define DELTA_HOME_ON_POWER 0
#define STEP_COUNTER
//#define SOFTWARE_LEVELING
#define DELTASEGMENTS_PER_PRINTLINE 20 // 20 alsen era 24 risparmio memoria
#define STEPPER_INACTIVE_TIME 3600L
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 200
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 200
#define HOMING_FEEDRATE_X 40
#define HOMING_FEEDRATE_Y 40
#define HOMING_FEEDRATE_Z 40
#define ZHOME_PRE_RAISE 0
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define ENABLE_BACKLASH_COMPENSATION 1
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 0
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 100
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 100
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define DUAL_X_RESOLUTION 0
#define Z4_STEP_PIN   ORIG_E3_STEP_PIN
#define Z4_DIR_PIN    ORIG_E3_DIR_PIN
#define USE_ADVANCE 0
#define BAUDRATE 115200
#define POWER_INVERTING 0
#define AUTOMATIC_POWERUP 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 1
#undef PS_ON_PIN
#define JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
#define FEATURE_SERVO 0
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define UI_SERVO_CONTROL 0
#define MAX_FAN_PWM 255
        #define FEATURE_WATCHDOG 1
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define EXTRUDER_IS_Z_PROBE 0
#define Z_PROBE_PIN 63
#define Z_PROBE_PULLUP 1
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET -20
#define Z_PROBE_Y_OFFSET -10
#define Z_PROBE_SPEED 5
#define Z_PROBE_XY_SPEED 280  // alsen 280 era 200
#define Z_PROBE_SWITCHING_DISTANCE 2
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 5
#define Z_PROBE_DELAY 0
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 -70
#define Z_PROBE_Y1 -40
#define Z_PROBE_X2 70
#define Z_PROBE_Y2 -40
#define Z_PROBE_X3 0
#define Z_PROBE_Y3 80
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 1
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#define SDSUPPORT 0
#undef SDCARDDETECT
#define SDCARDDETECT -1
#undef SDCARDDETECTINVERTED
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 11
#define ADC_KEYPAD_PIN -1
#define LANGUAGE_EN_ACTIVE 1
#define LANGUAGE_DE_ACTIVE 0
#define LANGUAGE_NL_ACTIVE 0
#define LANGUAGE_PT_ACTIVE 0
#define LANGUAGE_IT_ACTIVE 0
#define LANGUAGE_ES_ACTIVE 0
#define LANGUAGE_FI_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 0
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 0
#define LANGUAGE_TR_ACTIVE 0
#define UI_PRINTER_NAME "Delta e3dv6"
#define UI_PRINTER_COMPANY "A.Senni1.0.1dev"
#define UI_SPEEDDEPENDENT_POSITIONING 1
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 1
#define UI_REVERSE_ENCODER 1
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 0
#define CASE_LIGHTS_PIN -1
#define UI_START_SCREEN_DELAY 2000
#define UI_SET_MIN_HEATED_BED_TEMP  15
#define UI_SET_MIN_EXTRUDER_TEMP   170
#define UI_SET_MAX_EXTRUDER_TEMP   290
#define NUM_MOTOR_DRIVERS 0
// configurazione del 27 maggio 2018 con 2 estrusori ma usato solo uno
// version 1.0.1dev
    "editMode": 2,
    "processor": 0,
    "baudrate": 115200,
    "bluetoothSerial": -1,
    "bluetoothBaudrate": 115200,
    "xStepsPerMM": 100,
    "yStepsPerMM": 100,
    "zStepsPerMM": 100,
    "xInvert": "1",
    "x2Invert": 0,
    "xInvertEnable": 0,
    "eepromMode": 1,
    "yInvert": "1",
    "y2Invert": 0,
    "yInvertEnable": 0,
    "zInvert": "1",
    "z2Invert": 0,
    "z3Invert": 0,
    "z4Invert": 0,
    "zInvertEnable": 0,
    "extruder": [
            "id": 0,
            "heatManager": 1,
            "pidDriveMin": 40,
            "pidDriveMax": 230,
            "pidMax": 255,
            "sensorType": 1,
            "sensorPin": "TEMP_0_PIN",
            "heaterPin": "HEATER_0_PIN",
            "maxFeedrate": 200,
            "startFeedrate": 20,
            "invert": "0",
            "invertEnable": "0",
            "acceleration": 500,
            "watchPeriod": 1,
            "pidP": 7,
            "pidI": 2,
            "pidD": 40,
            "advanceK": 0,
            "advanceL": 0,
            "waitRetractTemp": 150,
            "waitRetractUnits": 0,
            "waitRetract": 0,
            "stepsPerMM": 981.558,
            "coolerPin": -1,
            "coolerSpeed": 255,
            "selectCommands": "",
            "deselectCommands": "",
            "xOffset": 0,
            "yOffset": 0,
            "zOffset": 0,
            "xOffsetSteps": 0,
            "yOffsetSteps": 0,
            "zOffsetSteps": 0,
            "stepper": {
                "name": "Extruder 0",
                "step": "ORIG_E0_STEP_PIN",
                "dir": "ORIG_E0_DIR_PIN",
            "advanceBacklashSteps": 0,
            "decoupleTestPeriod": 12,
            "jamPin": -1,
            "jamPullup": "0",
            "mirror": "0",
            "invert2": "0",
            "stepper2": {
            "preheat": 190
            "id": 1,
            "heatManager": 1,
            "pidDriveMin": 40,
            "pidDriveMax": 230,
            "pidMax": 255,
            "sensorType": 1,
            "sensorPin": "TEMP_2_PIN",
            "heaterPin": "HEATER_2_PIN",
            "maxFeedrate": 50,
            "invert": "0",
            "acceleration": 5000,
            "watchPeriod": 1,
            "pidP": 7,
            "pidI": 2,
            "pidD": 40,
            "advanceK": 0,
            "advanceL": 0,
            "waitRetract": 0,
            "stepsPerMM": 370,
            "coolerPin": -1,
            "coolerSpeed": 255,
            "xOffset": 0,
            "yOffset": 0,
            "zOffset": 0,
            "xOffsetSteps": 0,
            "yOffsetSteps": 0,
            "zOffsetSteps": 0,
            "stepper": {
                "name": "Extruder 1",
                "step": "ORIG_E1_STEP_PIN",
                "dir": "ORIG_E1_DIR_PIN",
            "jamPin": -1,
            "jamPullup": "0",
            "mirror": "0",
            "invert2": "0",
            "stepper2": {
            "preheat": 190
    "uiLanguage": 0,
    "uiController": 0,
    "xMinEndstop": 0,
    "yMinEndstop": 0,
    "zMinEndstop": 0,
    "xMaxEndstop": 2,
    "yMaxEndstop": 2,
    "zMaxEndstop": 2,
    "x2MinEndstop": 0,
    "y2MinEndstop": 0,
    "x2MaxEndstop": 0,
    "y2MaxEndstop": 0,
    "motherboard": 33,
    "driveSystem": 3,
    "xMaxSpeed": 200,
    "xHomingSpeed": 40,
    "xTravelAcceleration": 100,
    "xPrintAcceleration": 1000,
    "yMaxSpeed": 200,
    "yHomingSpeed": 40,
    "yTravelAcceleration": 100,
    "yPrintAcceleration": 1000,
    "zMaxSpeed": 200,
    "zHomingSpeed": 40,
    "zTravelAcceleration": 100,
    "zPrintAcceleration": 100,
    "xMotor": {
        "name": "X motor",
        "step": "ORIG_X_STEP_PIN",
        "dir": "ORIG_X_DIR_PIN",
        "enable": "ORIG_X_ENABLE_PIN"
    "yMotor": {
        "name": "Y motor",
        "step": "ORIG_Y_STEP_PIN",
        "dir": "ORIG_Y_DIR_PIN",
        "enable": "ORIG_Y_ENABLE_PIN"
    "zMotor": {
        "name": "Z motor",
        "step": "ORIG_Z_STEP_PIN",
        "dir": "ORIG_Z_DIR_PIN",
        "enable": "ORIG_Z_ENABLE_PIN"
    "enableBacklash": "1",
    "backlashX": 0,
    "backlashY": 0,
    "backlashZ": 0,
    "stepperInactiveTime": 3600,
    "maxInactiveTime": 0,
    "xMinPos": 0,
    "yMinPos": 0,
    "zMinPos": 0,
    "xLength": 200,
    "yLength": 200,
    "zLength": 197,
    "alwaysCheckEndstops": "1",
    "disableX": "0",
    "disableY": "0",
    "disableZ": "0",
    "disableE": "0",
    "xHomeDir": "-1",
    "yHomeDir": "-1",
    "zHomeDir": 1,
    "xEndstopBack": 1,
    "yEndstopBack": 1,
    "zEndstopBack": 1,
    "deltaDiagonalRod": 217,
    "deltaHorizontalRadius": 117,
    "deltaAlphaA": 210,
    "deltaAlphaB": 330,
    "deltaAlphaC": 90,
    "deltaDiagonalCorrA": 0,
    "deltaDiagonalCorrB": 0,
    "deltaDiagonalCorrC": 0,
    "deltaMaxRadius": 150,
    "deltaRadiusCorrA": 0,
    "deltaRadiusCorrB": 0,
    "deltaRadiusCorrC": 0,
    "deltaXOffsetSteps": 0,
    "deltaYOffsetSteps": 0,
    "deltaZOffsetSteps": 0,
    "deltaSegmentsPerLine": 24,
    "stepperHighDelay": 0,
    "directionDelay": 0,
    "allowQuadstepping": "0",
    "doubleStepDelay": 0,
    "maxJerk": 20,
    "maxZJerk": 0.3,
    "moveCacheSize": 16,
    "moveCacheLow": 10,
    "lowTicksPerMove": 250000,
    "enablePowerOnStartup": "1",
    "echoOnExecute": "1",
    "sendWaits": "1",
    "ackWithLineNumber": "1",
    "killMethod": 1,
    "useAdvance": "0",
    "useQuadraticAdvance": "0",
    "powerInverting": 0,
    "mirrorX": 0,
    "mirrorXMotor": {
    "mirrorY": 0,
    "mirrorYMotor": {
    "mirrorZ": 0,
    "mirrorZMotor": {
    "mirrorZ3": "0",
    "mirrorZ3Motor": {
        "name": "Extruder 2",
        "step": "ORIG_E2_STEP_PIN",
        "dir": "ORIG_E2_DIR_PIN",
    "mirrorZ4": "0",
    "mirrorZ4Motor": {
        "name": "Extruder 3",
        "step": "ORIG_E3_STEP_PIN",
        "dir": "ORIG_E3_DIR_PIN",
    "dittoPrinting": "0",
    "featureServos": "0",
    "servo0Pin": 11,
    "servo1Pin": -1,
    "servo2Pin": -1,
    "servo3Pin": -1,
    "featureWatchdog": "1",
    "hasHeatedBed": "1",
    "enableZProbing": "1",
    "extrudeMaxLength": 160,
    "featureController": 11,
    "uiPrinterName": "Delta e3dv6",
    "uiPrinterCompany": "A.Senni dev1.00",
    "uiPagesDuration": 4000,
    "uiHeadline": "",
    "uiDisablePageswitch": "1",
    "uiAutoReturnAfter": 30000,
    "featureKeys": "0",
    "uiEncoderSpeed": 1,
    "uiReverseEncoder": "1",
    "uiKeyBouncetime": 10,
    "uiKeyFirstRepeat": 500,
    "uiKeyReduceRepeat": 50,
    "uiKeyMinRepeat": 50,
    "featureBeeper": "0",
    "uiMinHeatedBed": 15,
    "uiMaxHeatedBed": 120,
    "uiMinEtxruderTemp": 170,
    "uiMaxExtruderTemp": 290,
    "uiExtruderFeedrate": 2,
    "uiSpeeddependentPositioning": "1",
    "maxBedTemperature": 120,
    "bedSensorType": 2,
    "bedSensorPin": "7",
    "bedHeatManager": 1,
    "bedPreheat": 55,
    "bedUpdateInterval": 5000,
    "bedPidDriveMin": 80,
    "bedPidDriveMax": 255,
    "bedPidP": 196,
    "bedPidI": 33,
    "bedPidD": 290,
    "bedPidMax": 255,
    "bedDecoupleTestPeriod": 300,
    "caseLightPin": -1,
    "caseLightDefaultOn": "1",
    "bedSkipIfWithin": 3,
    "gen1T0": 25,
    "gen1R0": 100000,
    "gen1Beta": 4036,
    "gen1MinTemp": -20,
    "gen1MaxTemp": 300,
    "gen1R1": 0,
    "gen1R2": 4700,
    "gen2T0": 25,
    "gen2R0": 100000,
    "gen2Beta": 4036,
    "gen2MinTemp": -20,
    "gen2MaxTemp": 300,
    "gen2R1": 0,
    "gen2R2": 4700,
    "gen3T0": 25,
    "gen3R0": 100000,
    "gen3Beta": 4036,
    "gen3MinTemp": -20,
    "gen3MaxTemp": 300,
    "gen3R1": 0,
    "gen3R2": 4700,
    "userTable0": {
        "r1": 0,
        "r2": 4700,
        "temps": [],
        "numEntries": 0
    "userTable1": {
        "r1": 0,
        "r2": 4700,
        "temps": [],
        "numEntries": 0
    "userTable2": {
        "r1": 0,
        "r2": 4700,
        "temps": [],
        "numEntries": 0
    "tempHysteresis": 0,
    "pidControlRange": 20,
    "skipM109Within": 2,
    "extruderFanCoolTemp": 50,
    "minTemp": 150,
    "maxTemp": 275,
    "minDefectTemp": -10,
    "maxDefectTemp": 290,
    "arcSupport": "1",
    "forceChecksum": "0",
    "sdExtendedDir": "1",
    "featureFanControl": "1",
    "fanPin": 11,
    "featureFan2Control": "0",
    "fan2Pin": "ORIG_FAN2_PIN",
    "fanThermoPin": -1,
    "fanThermoMinPWM": 128,
    "fanThermoMaxPWM": 255,
    "fanThermoMinTemp": 45,
    "fanThermoMaxTemp": 60,
    "fanThermoThermistorPin": -1,
    "fanThermoThermistorType": 0,
    "scalePidToMax": 0,
    "zProbePin": 63,
    "zProbeBedDistance": 10,
    "zProbeDisableHeaters": "0",
    "zProbePullup": "1",
    "zProbeOnHigh": "0",
    "zProbeXOffset": -20,
    "zProbeYOffset": -10,
    "zProbeWaitBeforeTest": "0",
    "zProbeSpeed": 5,
    "zProbeXYSpeed": 200,
    "zProbeHeight": 5,
    "zProbeStartScript": "",
    "zProbeFinishedScript": "",
    "featureAutolevel": "1",
    "zProbeX1": -70,
    "zProbeY1": -40,
    "zProbeX2": 70,
    "zProbeY2": -40,
    "zProbeX3": 0,
    "zProbeY3": 80,
    "zProbeSwitchingDistance": 2,
    "zProbeRepetitions": 1,
    "zProbeEveryPoint": "",
    "sdSupport": "0",
    "sdCardDetectPin": -1,
    "sdCardDetectInverted": "0",
    "uiStartScreenDelay": 2000,
    "xEndstopBackMove": 5,
    "yEndstopBackMove": 5,
    "zEndstopBackMove": 5,
    "xEndstopRetestFactor": 3,
    "yEndstopRetestFactor": 3,
    "zEndstopRetestFactor": 3,
    "xMinPin": -1,
    "yMinPin": -1,
    "zMinPin": -1,
    "xMaxPin": "ORIG_X_MAX_PIN",
    "yMaxPin": "ORIG_Y_MAX_PIN",
    "zMaxPin": "ORIG_Z_MAX_PIN",
    "x2MinPin": -1,
    "y2MinPin": -1,
    "x2MaxPin": -1,
    "y2MaxPin": -1,
    "deltaHomeOnPower": "0",
    "fanBoardPin": -1,
    "heaterPWMSpeed": 0,
    "featureBabystepping": "1",
    "babystepMultiplicator": 1,
    "pdmForHeater": "0",
    "pdmForCooler": "0",
    "psOn": "ORIG_PS_ON_PIN",
    "mixingExtruder": "0",
    "featureAxisComp": "1",
    "axisCompTanXY": 0,
    "axisCompTanXZ": 0,
    "axisCompTanYZ": 0,
    "retractOnPause": 2,
    "pauseStartCommands": "",
    "pauseEndCommands": "",
    "distortionCorrection": "1",
    "distortionCorrectionR": 100,
    "distortionPermanent": "1",
    "distortionEndDegrade": 1,
    "distortionExtrapolateCorners": "1",
    "distortionXMin": 10,
    "distortionXMax": 190,
    "distortionYMin": 10,
    "distortionYMax": 190,
    "sdRunOnStop": "",
    "featureRetraction": "1",
    "autoretractEnabled": "0",
    "retractionLength": 3,
    "retractionLongLength": 13,
    "retractionSpeed": 40,
    "retractionZLift": 0,
    "retractionUndoSpeed": 20,
    "filamentChangeXPos": 0,
    "filamentChangeYPos": 0,
    "filamentChangeZAdd": 2,
    "filamentChangeRehome": 1,
    "fanKickstart": 200,
    "servo0StartPos": -1,
    "servo1StartPos": -1,
    "servo2StartPos": -1,
    "servo3StartPos": -1,
    "uiDynamicEncoderSpeed": "1",
    "uiServoControl": 0,
    "killIfSensorDefect": "0",
    "jamSteps": 220,
    "jamSlowdownSteps": 320,
    "jamSlowdownTo": 70,
    "jamErrorSteps": 500,
    "jamMinSteps": 10,
    "jamAction": 1,
    "jamMethod": 1,
    "primaryPort": 0,
    "numMotorDrivers": 0,
    "motorDrivers": [
            "t": "None",
            "s": "",
            "invertDirection": "0",
            "stepsPerMM": 100,
            "speed": 10,
            "dirPin": -1,
            "stepPin": -1,
            "enablePin": -1,
            "endstopPin": -1,
            "invertEndstop": "0",
            "minEndstop": "1",
            "endstopPullup": "1",
            "maxDistance": 20
            "t": "None",
            "s": "",
            "stepsPerMM": 100,
            "speed": 10,
            "dirPin": -1,
            "stepPin": -1,
            "enablePin": -1,
            "endstopPin": -1,
            "minEndstop": "1",
            "maxDistance": 20
            "t": "None",
            "s": "",
            "stepsPerMM": 100,
            "speed": 10,
            "dirPin": -1,
            "stepPin": -1,
            "enablePin": -1,
            "endstopPin": -1,
            "minEndstop": "1",
            "maxDistance": 20
            "t": "None",
            "s": "",
            "stepsPerMM": 100,
            "speed": 10,
            "dirPin": -1,
            "stepPin": -1,
            "enablePin": -1,
            "endstopPin": -1,
            "minEndstop": "1",
            "maxDistance": 20
            "t": "None",
            "s": "",
            "stepsPerMM": 100,
            "speed": 10,
            "dirPin": -1,
            "stepPin": -1,
            "enablePin": -1,
            "endstopPin": -1,
            "minEndstop": "1",
            "maxDistance": 20
            "t": "None",
            "s": "",
            "stepsPerMM": 100,
            "speed": 10,
            "dirPin": -1,
            "stepPin": -1,
            "enablePin": -1,
            "endstopPin": -1,
            "minEndstop": "1",
            "maxDistance": 20
    "manualConfig": "\/\/ configurazione del 27 maggio 2018 con 2 estrusori ma usato solo uno\n\/\/ version 1.0.1dev",
    "zHomeMinTemperature": 0,
    "zHomeXPos": 999999,
    "zHomeYPos": 999999,
    "zHomeHeatHeight": 20,
    "zHomeHeatAll": "1",
    "zProbeZOffsetMode": 0,
    "zProbeZOffset": 0,
    "zProbeDelay": 0,
    "uiBedCoating": "1",
    "langEN": "1",
    "langDE": "0",
    "langNL": "0",
    "langPT": "0",
    "langIT": "0",
    "langES": "0",
    "langFI": "0",
    "langSE": "0",
    "langFR": "0",
    "langCZ": "0",
    "langPL": "0",
    "langTR": "0",
    "accelerationFactorTop": 100,
    "bendingCorrectionA": 0,
    "bendingCorrectionB": 0,
    "bendingCorrectionC": 0,
    "supportLaser": "0",
    "laserPin": -1,
    "laserOnHigh": "1",
    "laserWarmupTime": 0,
    "defaultPrinterMode": 0,
    "laserPwmMax": 255,
    "laserWatt": 2,
    "supportCNC": "0",
    "cncWaitOnEnable": 300,
    "cncWaitOnDisable": 0,
    "cncEnablePin": -1,
    "cncEnableWith": "1",
    "cncDirectionPin": -1,
    "cncDirectionCW": "1",
    "cncPwmMax": 255,
    "cncRpmMax": 8000,
    "cncSafeZ": 150,<
  • #define ENDSTOP_Z_BACK_ON_HOME 1
    is a bit low for delta. 10 or 20mm is normally better to prevent problems. For deltas homing failing means normally the endstops did not switch as expected, e.g. one is still triggered after going back. Then homing is aborted.
  • Hi Repetier,
    I've been out for work only now I'm back on my printer and I have not yet solved with your suggestion.
    I try to describe better: I turn on the kossel with the axes at about 80% of their travel and then I send the command G28: only the axis of the tower Z and tower Y are moving downwards of about 1 cm and the axis of the tower X remains still and on Repetier Host I get the message that I have already reported to you.
    Thanks as always
    Alberto
  • Test first endstop status M119. The error makes not much sense except if endstops are triggered before homing. Also check eeprom for unusual values or refresh eeprom with configuration.h values using
    M502
    M500
    NaN or wrong values can also have strange results. And as always check what the log says when you do it.
  • I discovered the problem, my kossel limit switches must have ENDSTOP_ <x, y, z> _MAX_INVERTING equal to true while they were all false.
    The tools https://www.repetier.com/firmware/dev/ do not keep this value from the old configuration.h file loaded and must therefore be forced by hand.
    Why are these values ​​not retained by the initial configuration.h file? Am I wrong?
    Alberto
  • They are retained. But my guess is that you changed the define afterwards. The tool does not read the defines but the json string at the end of the file. So never change these values manually if you want them to stay on next config tool upload.
