Upgrade 2.1.2. Configuration
Just upgraded to the latest repitier host for windows and now the config menu for the prusa slicer no loger opens the configuration program. Gives a
<Slic3rPE> Loading an application config file failed:
<Slic3rPE> <unspecified file>(7): key expected
<Slic3rPE> Slic3r installed in a loclized path. Using an 8.3 path: “C:\PROGA~1\REPETI~1\Slic3rPE
Anyone else have this problem?
Solutions???
Since the error mentions a config file it might be unable to read the old config files. Had the same with some configs. You could try copy $HOME/AppData/Slic3rPE and delete old content so it creates new valid config. When it works you can copy back old configs and see when it starts crashing, then you know the config has problems.
