Extruder doesn't move when linear advance is activated
I'm experimenting with the linear advance feature. When i activated the linear advance and set a K value the extruder doesn't move anymore. Is there a manual how to set up linear advance?
Best Regards
Best Regards
- M232 - Read and reset max. advance values
Should output maximum steps used (limited to 32000). So what does it show and what are your extruder steps per mm and L that it is so much? L 40 would be normal for direct extruder. As I already said, do not use K.
