UI Bug (?) - Print Button greyed out after completion of a print job
In 2.0.x I could load a new file or just start the existing gcode again. In 2.1.2 - whenever a print is finished the "Print" button stays greyed out. I have to disconnect from the repetier server (Pro V 0.86.2) once before I can start a new print, no matter wether I loaded a new file or want to print the loaded gcode again.
  • Yes, others have reported that as well. We will test and fix with next release.
