Repetier Server does not start UI interface after Touchscreen installation
Hi all,
today I tried to install a 5" Waveshare touchscreen on my Repetier Server and in principal it is working, but after installing the touchscreen driver the UI interface on my Pi isn't starting. Means it shows just the console. I can also reach it through the web interface but I would like to get the touch interface running. Does anybody has an Idea how to start the Repetier application again?
Many thanks in advance,
Oli
Oli
Put one of these screens on the Pi 3 install:
https://www.waveshare.com/wiki/3.5inch_RPi_LCD_(A)
and was able to get the driver installed and screen working, but like olifunke it now just boots to console mode instead of Repetier GUI. After digging through the forums for a while, seems to be that the problem is Linux not setting the correct display type when called by the xserver command.
does anybody know which file has the setting for defining the display previous to the xserver call?
Other than that, really liking the Server running on Pi
-SJ
I was not able to get it running with the Waveshare driver even not with the xserver hint. Finally, I've made it by using the driver from a different company (Elecrow) which seems to be compatible. Here is what I used:
Using this driver it works perfectly for me. Unfortunately I had to completely re-install the Repetier image for that.
Hope this helps you too.
Best regards,
olifunke
Not really a deal breaker since using the Web GUI to control the printers is just as easy, but would be a fun extra to have the small touchscreen.
You didn't state which version of Repetier Server you are running on Pi. Did you get it to work? This discussion is from May and June so I'm assuming that it was using a more recent build?
I'm currently running on RS version 0.80.3 and I can install my Waveshare 35B driver and everything works fine. But, if I upgrade to the newest version 0.90.7 and then install the driver, I can't even get my Pi to boot to console. It hangs at
I've tried different cards but end up with the same results. If I reinstall 0.80.3 everything works fine.
Is there a way to update to the newest version without over-writing everything on the SD card?
I think between 0.80 and 0.90.7 there was a update of the debian distribution to stretch from jessie. This came along with newer kernel update that also supports Raspberry Pi 3+. Maybe the waveshare drivers do not work on that kernel/distribution?
