Ultimaker 2 and LED light control.
I have an Ultimaker 2 printer with the Marlin firmware. From the printer menu, I can control the light, tell me how to make the Light button work in the Repetier Server interface? I know which pin on the board Mega is responsible for the light.
M355: Turn case lights on/off
Every call or change over LCD menu sends a state change for connected hosting software like:
Alternative solution is to define named script to do so in Printer Settings->G-Codes then you can select them in the console tab as command.How can I assign this command to a button in the web interface?
in the marlin.xml firmware description for next release. If your version does not support this, you can replace this with your M42 codes instead. The firmware descriptions are in install dir/firmwares.
