dual extruder and Repetier-Firmware configuration tool for version 0.92.8
hello
dual extruder and Repetier-Firmware configuration tool for version 0.92.8 you can not run a second heater (Heater pin: 2 heater normally used for extruder 1)
Hardware:
ramps 1.4 and LCD2004
can someone have a similar problem?
version of 07/12/2015 everything works
Hardware:
how i make sure that the fan use a different pin or how i could disable the fan usage?
best regards
//#define FAN_PIN 4 // Extruder 2 uses the default fan output, so move to an other pin"
as"
could you please help?
best regards
