How to retrieve slicer (printing parameters) config from a hard-drive?
Hello, the motherboard of my laptop is gone. However the hard-disk seems fine. I used this laptop for my printer for a long time and developed printing parameters /slicing parameters using Slic3r. Is there anyway that I can retrieve the config files of slic3r. I used Repetier-Host along with built-in slic3r for printing. I badly need those configurations. Can anybody advice me, please? Thanks in advance.
  • Slic3r configs are stored as files on harddisk so can easily be copied. They are in homedir/AppData/Roaming/Slic3r
    AppData is a hidden file so make sure you can see them!
  • Wow, it worked. Many many thanks for your help. thank you.
