Smoothieboard and repetier
17:57:22.599 : "C:\Program Files\Repetier-Host\plugins\RepetierServerConnector\RepetierServerStarter.exe" start
18:05:04.713 : Repetier-Server successfully connected.
18:05:04.719 : M20
18:05:04.723 : M20
18:05:04.738 : Begin file list
18:05:04.738 : firmware.cur
18:05:04.738 : backup-firmware/
18:05:04.739 : M115
18:05:04.741 : M20
18:05:04.841 : documentation/
18:05:04.841 : drivers/
18:05:04.841 : source/
18:05:04.841 : software/
18:05:04.841 : models/
18:05:04.841 : readme.txt
18:05:04.841 : system volume information/
18:05:04.841 : config
18:05:04.842 : End file list
18:05:04.842 : Begin file list
18:05:04.942 : firmware.cur
18:05:04.942 : backup-firmware/
18:05:04.942 : documentation/
18:05:04.942 : drivers/
18:05:04.942 : source/
18:05:04.942 : software/
18:05:04.942 : models/
18:05:04.942 : readme.txt
18:05:04.942 : system volume information/
18:05:04.942 : config
18:05:04.942 : End file list
18:05:04.942 : Begin file list
18:05:04.992 : documentation/
18:05:04.993 : drivers/
18:05:04.993 : source/
18:05:04.993 : software/
18:05:04.993 : models/
18:05:04.993 : readme.txt
18:05:04.993 : system volume information/
18:05:04.993 : config
18:05:04.993 : End file list
18:05:53.374 : Slic3r command:C:\Program Files\Repetier-Host\Slic3r\slic3r.exe --load "slic3r_settings.ini" --print-center 92.50,93.50 -o "composition.gcode" "composition.amf"
18:05:54.372 : <Slic3r> => Processing triangulated mesh
18:05:54.840 : <Slic3r> => Generating perimeters
18:06:03.305 : <Slic3r> => Preparing infill
18:06:04.938 : <Slic3r> => Infilling layers
18:06:06.249 : <Slic3r> => Generating skirt
18:06:06.253 : <Slic3r> => Generating brim
18:06:06.261 : <Slic3r> => Exporting G-code to composition.gcode
18:06:34.140 : <Slic3r> Done. Process took 0 minutes and 39.768 seconds
18:06:34.140 : <Slic3r> Filament required: 58732.6mm (141.3cm3)
18:08:10.413 : Slic3r command:C:\Program Files\Repetier-Host\Slic3r\slic3r.exe --load "slic3r_settings.ini" --print-center 92.50,93.50 -o "composition.gcode" "composition.amf"
18:08:11.579 : <Slic3r> => Processing triangulated mesh
18:08:12.035 : <Slic3r> => Generating perimeters
18:08:19.466 : <Slic3r> => Preparing infill
18:08:21.029 : <Slic3r> => Infilling layers
18:08:22.925 : <Slic3r> => Generating skirt
18:08:22.929 : <Slic3r> => Generating brim
18:08:22.937 : <Slic3r> => Exporting G-code to composition.gcode
18:08:51.037 : <Slic3r> Done. Process took 0 minutes and 39.458 seconds
18:08:51.037 : <Slic3r> Filament required: 58732.6mm (141.3cm3)
18:12:21.437 : Uploading to http://localhost:3344/printer/model/AluTransformer?a=upload
18:12:34.110 : B:42.0 /65.0 @255
18:15:57.117 : B:64.9 /65.0 @255
18:17:21.983 : Warning: Communication timeout - resetting communication buffer.
18:17:21.983 : Connection status: Buffered:28, Manual Commands: 2, Job Commands: 5000
18:17:21.983 : Buffer used:28 Enforced free byte:37 lines stored:1
18:17:21.983 : Printing layer 1 of 599
18:54:34.476 : Printing layer 2 of 599
19:11:12.271 : Printing layer 3 of 599
19:27:27.716 : Printing layer 4 of 599
19:30:11.579 : Printing layer 5 of 599
19:40:13.935 : Printing layer 6 of 599
19:50:26.037 : Printing layer 7 of 599
20:03:28.664 : Printing layer 8 of 599
20:06:08.455 : Printing layer 9 of 599
20:08:49.830 : Printing layer 10 of 599
20:11:17.405 : Printing layer 11 of 599
20:13:58.189 : Printing layer 12 of 599
20:16:40.957 : Printing layer 13 of 599
20:19:37.744 : Printing layer 14 of 599
20:23:14.718 : Printing layer 15 of 599
20:26:45.528 : Printing layer 16 of 599
20:30:12.795 : Printing layer 17 of 599
20:33:42.047 : Printing layer 18 of 599
20:37:08.422 : Printing layer 19 of 599
20:40:32.403 : Printing layer 20 of 599
20:44:01.610 : Printing layer 21 of 599
20:47:26.190 : Printing layer 22 of 599
20:50:46.696 : Printing layer 23 of 599
20:53:39.511 : Printing layer 24 of 599
20:56:03.884 : Printing layer 25 of 599
20:58:24.983 : Printing layer 26 of 599
21:00:45.174 : Printing layer 27 of 599
21:03:05.576 : Printing layer 28 of 599
21:05:23.731 : Printing layer 29 of 599
21:07:39.410 : Printing layer 30 of 599
21:10:03.786 : Printing layer 31 of 599
21:12:22.798 : Printing layer 32 of 599
21:14:41.891 : Printing layer 33 of 599
21:17:05.775 : Printing layer 34 of 599
21:19:20.651 : Printing layer 35 of 599
21:21:41.498 : Printing layer 36 of 599
21:23:55.331 : Printing layer 37 of 599
21:26:10.809 : Printing layer 38 of 599
21:28:31.158 : Printing layer 39 of 599
21:30:47.977 : Printing layer 40 of 599
21:33:00.566 : Printing layer 41 of 599
21:35:15.348 : Printing layer 42 of 599
21:37:32.168 : Printing layer 43 of 599
21:39:48.290 : Printing layer 44 of 599
21:41:58.646 : Printing layer 45 of 599
21:44:13.117 : Printing layer 46 of 599
21:46:23.728 : Printing layer 47 of 599
21:48:35.477 : Printing layer 48 of 599
21:50:45.045 : Printing layer 49 of 599
21:52:58.420 : Printing layer 50 of 599
21:55:05.940 : Printing layer 51 of 599
21:57:18.488 : Printing layer 52 of 599
21:59:31.721 : Printing layer 53 of 599
22:01:39.488 : Printing layer 54 of 599
22:03:51.243 : Printing layer 55 of 599
22:05:55.733 : Printing layer 56 of 599
22:08:07.177 : Printing layer 57 of 599
22:10:16.736 : Printing layer 58 of 599
22:12:25.896 : Printing layer 59 of 599
22:14:36.655 : Printing layer 60 of 599
22:16:45.566 : Printing layer 61 of 599
22:18:51.196 : Printing layer 62 of 599
22:21:00.063 : Printing layer 63 of 599
22:23:09.826 : Printing layer 64 of 599
22:25:12.819 : Printing layer 65 of 599
22:27:21.577 : Printing layer 66 of 599
22:29:25.822 : Printing layer 67 of 599
22:31:30.854 : Printing layer 68 of 599
22:33:37.498 : Printing layer 69 of 599
22:35:44.427 : Printing layer 70 of 599
22:37:46.929 : Printing layer 71 of 599
22:39:53.100 : Printing layer 72 of 599
22:41:55.252 : Printing layer 73 of 599
22:43:58.705 : Printing layer 74 of 599
22:46:07.260 : Printing layer 75 of 599
22:48:07.876 : Printing layer 76 of 599
22:50:09.387 : Printing layer 77 of 599
22:52:17.252 : Printing layer 78 of 599
22:54:33.671 : Warning: Communication timeout - resetting communication buffer.
22:54:33.671 : Connection status: Buffered:39, Manual Commands: 2, Job Commands: 5000
22:54:33.671 : Buffer used:39 Enforced free byte:39 lines stored:1
22:55:04.697 : Warning: Communication timeout - resetting communication buffer.
22:55:04.697 : Connection status: Buffered:48, Manual Commands: 2, Job Commands: 5000
22:55:04.697 : Buffer used:48 Enforced free byte:39 lines stored:3
