Can't login when ussing HTTPS
I've installed repetier server on a raspberry pi B+.
Everything works fine except when I try to connect using HTTPS.
The Pi is behind a reverse proxy. I've enable user account in repetier server.
I access to the Pi's local IP address (HTTP or HTTPS) I can enter my login/password and use repetier but if I access to the Pi public address using (only available with HTTPS) only the top navbar is available.
Here is a screenshot when using local IP address : https://drive.google.com/file/d/1CVhUFHn-EdkdTfHJS7a-J-oKIkf8Ae1e/view?usp=sharing
and here is a screenshot using public address : https://drive.google.com/open?id=1jlnx6d_uL0ljFvXab97m1HRPDGo39BYt
Repetier server is v0.86.2 installed using image Repetier-Server-Image_0_86_2_v7.img.
Does anyone have an idea what's wrong ?
https://www.repetier-server.com/webserver-access-repetier-server/
But when I wan't to access the RPi from the public web through the reverse proxy (i.e. https://3dprinter.mydomain.com) it does not work. (screenshot: https://drive.google.com/open?id=1ABjpi3HUy3c9xpD73FCbL2oLvxIwUQM7 )
As shown by the screenshot, the main page is not fully displayed, the login windows is not displayed, only the top navbar.
The SSL certificate is OK.
So anyidea why I can reach the RPi but only the top navbar is displayed ?
talk about it to the network admin, he changed it on the reverse proxy and now it's fixed.
Thanks for your help
