Extruder Temperature Does Not Show
The current temperature for the extruder does not show up anywhere on the page. The heated bed temp is displayed at the top next to the flow, feed rate and fan speed, but there is no extruder.  Also, under the control tab it does not show any extruder, only the graph for the bed. Am I missing anything?
http://https//imgur.com/YoR5IpB
  • In printer settings you need to define how many extruders you have. Only then will you see the extruder temperatures.
    Your bed sensor looks very noisy, btw. Or did you change temperature all the time.
  • Many thanks!!! I feel quite silly, and what wonderful user service!
    Not sure about the noise in the bed temp, though it may be because I am changing/messing around with firmware.
    Thanks Again
