SET TO ORIGIN not working
I am trying to change the 0,0,0 starting point to another one (not the endstops point). So, i am moving it somewhere, then press "Set to origin" in quick settings menu and nothing changes. It still starts for the previous (original) starting point. I made a test g-code, which is:
G0 X0
G0 X100
After setting new origin a printer should immediately implement the second command, but unfortunatelly it firstly return back to zero and the goes to 100.
What is wrong?
Best regards!
G0 X0
G0 X100
What is wrong?
Best regards!
case UI_ACTION_SET_ORIGIN:
if(!allowMoves) return UI_ACTION_SET_ORIGIN;
Printer::setOrigin(-Printer::currentPosition[X_AXIS], -Printer::currentPosition[Y_AXIS], -Printer::currentPosition[Z_AXIS]);
break;
Originally it had setOrigin(0,0,0) but the function sets offsets so 0 is wrong here.
