New printer keeps giving errors when z probe starts
i have tried G30 and i get
i tried G29
im not sure whats going on i have a 400X400 Bed the config is attached
i want it to test 3 points in each corner can someone please help
Error:Activating z-probe would lead to forbidden xy position: 0.000000, -20.00
i tried G29
T:22.44 /0 B:21.39 /0 B@:0 @:0 T0:22.44 /0 @0:0 T1:22.44 /0 @1:0
fatal:G29 leveling failed! - Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
Same with the 3 points for autoleveling (which is G32 S2 not G29 like in marlin) - these must be reachable with active probe. So omit borders in offset direction.
i tried G1 X30 Y10 it didnt and didnt help
then i type in G1 X30 Y10
and it dont move but i have typed in G1 X30 Y20
then it did so I assume once it homes its already at G1 X30 Y10
Probing fails if it was triggered before going down, so maybe you start at a too low level?
What does M119 after homing say? Any endstops triggered that prevent the move.
And since G1 X30 Y20 does move - in which direction?
Does not really make sense at the moment.
also config file attached
