Encoder stop working after print
I'm printing from SD. The encoder works great, the display and the SD too. When the print finishes the rotary action of encoder stop working but the button works fine. If I reset the board it start to work again. I dont know if it's a bug in the firmware or a configuration problem. I didn't found anything similar in the forum or github.
I'm using the firmware 1.0.0 generated with the Configuration Tool web and modified the settings for display, encoder and buttons.
This is part of my uiconfig.h
void uiInitKeys() {Thanks!
#if UI_HAS_KEYS!=0
UI_KEYS_INIT_CLICKENCODER_LOW(31,33); // click encoder on pins 31 and 33. Phase is connected with gnd for signals.
UI_KEYS_INIT_BUTTON_LOW(35); // push button, connects gnd to pin
UI_KEYS_INIT_BUTTON_LOW(41); // push button, connects gnd to pin
#endif
void uiCheckKeys(uint16_t &action) {
#if UI_HAS_KEYS!=0
UI_KEYS_CLICKENCODER_LOW_REV(31,33); // click encoder on pins 31 and 33. Phase is connected with gnd for signals.
UI_KEYS_BUTTON_LOW(35,UI_ACTION_OK); // push button, connects gnd to pin
UI_KEYS_BUTTON_LOW(41,UI_ACTION_EMERGENCY_STOP); // push button, connects gnd to pin
#endif
The only reason I can see is that one of the encoder pins or both are not set as input anymore or pullup is not enabled for it.
Are you printing with server or from sd card? In first case there is not much for firmware to do as it just executes commands. Then it would make sense that one of the commands near end causes this to happen and if you can find out which command it should be easy to find the reason. But even from sd card it just stops reading the file and there is no apparent reason to do such a thing.
Also, the scroll in between files on SD it's slow. Tried 3 SD cards of different sizes but the same problem. I don't know if it's a SPI low speed problem (as DUE have to use software SPI and maybe it's slower than hardware) or a encoder speed multiplier or something like that. Another problem it's that the save on EEPROM (on SD card) in display doesn't save anything but from Repetier Host it does.
Edit: I found the problem. My GCode had a line at end with "M42 P33 S255" because thes case has the lights in that pin. Anyways the SD card problem is still there. I'll try to figure out how to resolve it.
Thanks for the reply!
On arm it can happen that some pins are used also for special functions. That is why a thought finding the gcode that makes it unfunctional should help finding which function changes pin definition. Normally pin direction is only set during setup, so I even wonder why it happens so late. Temperatures, heaters etc are already initalized and it was still working, so what could start using the pin.
The question is, I'm the only one with this problem? If not, I'll open an issue in the repository and try to fix it.
By the way, the encoder problem it's because if the pin is an input (signals A and B of encoder) with internal pull-up and you write a 0 in that pin, the pull-up will be disabled.
I hope this help someone.
ui.h
#define UI_KEYS_INIT_CLICKENCODER_LOW(pinA,pinB) SET_INPUT(pinA);SET_INPUT(pinB); PULLUP(pinA,HIGH);PULLUP(pinB,HIGH);
In HAL.h you seewhich would enable pullup just as required.
Just tested sd card scrolling and it was fast, but I use hardware SPI for it, so that might make a difference. Guess for going through directory you need to read much sectors, especially if it was long. Not sure if it reduces to 1 sector if all files are deleted since I already know that deleting is just marking the directory entry as deleted.
Have you tried with the sd card reader on the RADDS board directly? That can use hardware SPI as well.
I didn't knew that Arduino DUE has hardware SPI. As I said, I'm using a RAMPS 1.4 modified and the SPI pins of SD cards connect to the SPI pins in Arduino Mega 2560 so I have to re-wire the conections and check if hardware SPI solves my problem. Where are the SPI pins in DUE?
Thanks!
https://forum.arduino.cc/index.php?topic=132130.0
shows the pinout.
Thanks!
