Problems with z-distortion on my printer
Hello.
I am new to this forum, but I have used the repetier firmware for a few months now on my new printer.
Over the holiday I have tried to get z-distortion to work, but I have some problems with the result. If I make a height map in repetier-host, it looks really good (+0.01mm), but when I'm printing something, it does not look good. Each line segment starts low and moves slowly upwards. As I can see it, the line starts at the right height but ends in the uncorrected height.
I use a CoreXY layout on my printer, with a 200 x 280 mm bed. I have saved my distortion map in my EEPROM and my configuration looks like this:
#define DISTORTION_CORRECTION_POINTS 10
#define DISTORTION_UPDATE_FREQUENCY 10
#define DISTORTION_EXTRAPOLATE_CORNERS 1
#define DISTORTION_XMIN 0
#define DISTORTION_YMIN 0
#define DISTORTION_XMAX 180
#define DISTORTION_YMAX 260
My Z-probe configuration looks as follows:
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define Z_PROBE_BED_DISTANCE 6
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET -35
#define Z_PROBE_Y_OFFSET -3
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 120
#define Z_PROBE_SWITCHING_DISTANCE 5
#define Z_PROBE_REPETITIONS 3
#define Z_PROBE_HEIGHT 0
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 20
#define Z_PROBE_Y1 20
#define Z_PROBE_X2 180
#define Z_PROBE_Y2 0
#define Z_PROBE_X3 20
#define Z_PROBE_Y3 260
My z-probe is 1.45mm higher than my hotend, but I always compensate it manually after the printer has auto-leveled the bed with the g-codes:
G00 z-1.45
G92 Z0
I have attached a picture of the problem.
Is there anyone who can help me with my problem?
/Hans
/Hans
is better. That was meant for deltas that can not reach edges of a rectangle.
You also provided the answer to the problem:
That is ugly and most likely causes problems with everything and completely not needed. Just set
#define Z_PROBE_HEIGHT 1.45
or do it in eeprom editor which you must override otherwise. Redo G32 S2 and G33 and see ho wit works then.
Thank you
I've only set the z-probe height to 0 temporarily, as I'm still working on the printer, and have already experienced a height change after I made a change to the printer. After which the printer tried to make the first layer 0.5mm down into my aluminum bed. That was not good for either the bed nor the extruder nozzle.
/Hans
No, the values were good.
Start degrade is when it should start reducing and you want at least one layer with full correction. Above end height it will do no correction at all.
I simply could not figure out what the problem was, and my bed is too uneven to avoid distortion correction. I worked with the problem over a few weeks, and tried, what I think was everything. That's why I eventually switched to another firmware.
I'm sorry that I can not be of more help.
