Prusa Edition Prime Tower problems
I just set up a chimera on my hictop prusa clone and I'm having issues getting Slic3r Prusa Edition to generate a prime tower properly. I checked prime tower and left the default parameters. Use relative E-distance is checked. Extruders are set to 2 and single extruder multi material is checked (which confuses me why it needs to be checked because I have 2 extruders and 2 nozzles; if i uncheck it it gives me no tower at all)
here's what i get when i slice:
https://drive.google.com/open?id=1KEfpi61wwRCjB7FzGEI0khRVVkq1s4UF
it only shows the bottom half of the print, the tower looks strange, and it shows a floating line at the top of where the tower should end.
has anyone had this problem? i tried searching for help and i come up with nothing
bear in mind i am a novice with all of this, so maybe i'm missing something obvious. any help or advice is appreciated.
Some computers have problems showing full gcode especially over terminal viewer this seems to be a problem.
I am facing the same Problem.
i set up a Diamond hotend on a Anet A8. Slic3r PE will only slice as expected, as Long as i do not use the prime Tower. When i do, it Looks like this: I really do not know, what to do. I opened the gcode in another program to verify. The gcode Looks exactly like this.
V1.39.1 does the same. By the way, the Print starts below z 0.00 !
If it is at the computer, can you offer a download of the file to check.
