Server Cannot Connect to Printer but Host Can
Before I explain my problem, here is my setup:
Windows 8.1 computer
PrintrBot Jr v1Repetier Host 1.0.6Repetier Server 0.50.3
PrintrBoard rev D with Marlin Firmware
The printer registers as COM3 on the computer and when I'm using Repetier-Host, I'm able to connect to the printer just fine; I'm able to control it manually, do prints, etc. But when I try to use Repetier-Server using the same COM port, baud rate, etc., the Server website only shows a orange colored connected image. I realize I have to disconnect / close Host when I try to use Server and have the printer deactivated on Server when using Host; that doesn't seem to be the issue.
I've tried finding a log file somewhere for Repetier-Server but I can't seem to find one.
Here is an image of the Repetier-Host printer config (you'll notice the green connected image in the top left as well)
Here is an image of the Repetier-Server printer config
And here is an image of the status once I activate the printer on Repetier-Server
For what it's worth, I have a Raspberry Pi with OctoPrint on it that has been working with this printer for over a year without problems. It had the same baud rate, 250000, on it as well.
Any suggestions or ideas on how to fix this?
