Question about dual extruder
Hi ,
I build a machine like BCN3D sigma with dual X,E
My firmware version is 1.0.0 in Ramps-FD.
I meet a problem and can't find why it happens.
When I power on , connected with Repetier-Host.
These are my operations:
1.Home
2.extrude 5mm(Extruder 1) <-- not work
The extruder 1 will not do anything , I'm sure the minimum exturde temperature is arrived.
Buy if I do these operations:
1.Home
3.switch to Extruder 2
4.extrude 5mm(Extruder 2) <-- work
5:switch to Extruder 1
6.extrude 5mm(Extruder 1) <-- work
Or like this
1.Home
2.switch to Extruder 2
3.extrude 5mm(Extruder 2) <-- not work
4:switch to Extruder 1
5.extrude 5mm(Extruder 1) <-- work
6:switch to Extruder 2
7.extrude 5mm(Extruder 2) <-- work
After some test , I'm sure the rule is the extruder will start to work only if extruded on any extruder and do a switch operation.
I'm sure the motors are enabled.(I listened the sound of enable)
I try to trace the code and add some logs , any extrude action contains enable and step , it looks like no problem.
How can I fix this problem?
Thanks for help:D
1.Home
1.Home
Or like this
1.Home
Thanks for help:D
First I would do is in
uint8_t Printer::setDestinationStepsFromGCode(GCode *com)
put some print commands on the case send 0 or send move to know if a move was planned or not. Also do not omit
if(!posAllowed) {
currentPositionSteps[E_AXIS] = destinationSteps[E_AXIS];
return false; // ignore move
at the end of the function. Since you are outside bed it might make that function fail when in parking lot and thus set extrusion to 0.
Thanks for response.
I had checked Printer::setDestinationStepsFromGCode(GCode *com).
I'm sure this function can create new PrintLine , and after this , Extruder's step() has called , but the motor still not work.
I will keep looking for the reason.
I found another problem.
1.G28(Home)
2.M280 S1(set to ditto mode)
3.Extruder 5mm(G90 + G0 E5)
X Axis will do a error moving action.
I found this cause from M280
After PrintLine::moveRelativeDistanceInSteps
destinationSteps[X_AXIS] will be set to a negative integer
After G0 E** is sent , this value will become a new X moving target(currentPositionSteps[X_AXIS]=0 , destinationSteps[X_AXIS]=-XXXX)
I add a code to M280 like this :
Printer::currentPositionSteps[X_AXIS] = Printer::xMinSteps;
The problem seems to be resolved.
Is this a correct modification?
After exchange motor setting between X1 And E1 , the same problem happen on X1 , E1 is work fine.
I think the problem caused from pin of due....
Because of driver socket is not enough , my extruder is connected to Ramps-FD AUX2 with external module.
The pins on AUX2 can be use as analog input or digital pin , maybe cause some problems? I'm not sure...
I want to test on my dual x printer when I get some time. Just to be sure also with last update I did not see problems, but maybe never tested your case.
I found the reason of the problem.
Extruder.cpp line:1781 in enable()
digitalWrite(Extruder::current->enablePin, Extruder::current->enableOn);
change to
HAL::digitalWrite(Extruder::current->enablePin, Extruder::current->enableOn);
Problem will be solved.
I also found the same in line 1785 , 1792 , 1800
I'm not sure if these are bugs.
I had tested the same operation on Mega2560 yesterday , this seems works fine.
But this seems don't work on Arduino Due.
Thanks for help
I think I'm wrong....
I did not solve the problem by this way.
The really reason is I enable all extruder in initExtruder()(default is disable)
But this way still not really solve the problem .
If the extruder is disabled , it can't enable again.
I give up use these pins to drive extruder
These are my setting....maybe someone know why?
use E3 for EXT0 , E4 for EXT1
Board is Arduino Due + Ramps-FD V2.1 connected to AUX2
#define ORIG_E3_STEP_PIN 61
#define ORIG_E3_DIR_PIN 59
#define ORIG_E3_ENABLE_PIN 68
#define ORIG_E4_STEP_PIN 60
#define ORIG_E4_DIR_PIN 58
#define ORIG_E4_ENABLE_PIN 69
Finally I change these pins to another digital pins.
The extruders are all work fine now.
Just no pin can be used for the LCD panel.....
LCD Panel is not the way for the future anyway. Tiny pc like odroid or raspberry with touchscreen and repetier-server is much nicer.
