Jam detection immediate action
Good day
I use Jam detection for a filament runout sensor. JAM_ACTION 1
If the filament runs out the printer will display the Jam detected message but will continue with the print that is still in the buffer and only then will it go to the filament change position. Is there a way for it to act immediately if the runout is detected.
Normally you also have some mm filament available before the motor does not get any filament since the sensor is before the motor.
I understand it is non trivial and may take a long time but the power of such a function would be very beneficial.
If you tell your printer to pause of filament runout/ jam and the actions are instantaneous, it would add to the user experience.
