output synchronised to movement
I am using Repetier for a plotter.
I have now an inkjet head with 8 jets, each controlled by an output.
According to the distance I want to controll these jets.
eg. to write an "E": would be 1mm all 8 jets - then 3mm jet 1,5,8 - then no jet - then .. next letter
How can I synchronise the movement with the letters?
(speed is very low)
do we have a kind of interrupt of each mm?
Thanks for any help!
(speed is very low)
1) I change in Repetier the E Appendix in the G0 command to controll the 8 jets
(eg 255 for 8 outputs ON for the 8 jets)
2) I write in VisualBasic a GC-Code Generator generating the E-Appendix of G0
The code for the above example to make the letter "E" would be:
G0 X1 E255 - go 1mm with all 8 jets to ON to make the first vertical line of the E
G0 X4 E145 - go 3mm with jet 1,5,8 to On to make the 3 arms of the E
G0 X1 E0 - go 1mm and no jets
The code will tricky for letters with diagonal lines like "N"..then the steps must be smaller maybe 0.5mm.
I assume that setting the outputs is fast enough.
Or will stop the motion between the G0 commands?
Make that sense?
G0 X1
M5 S255
G0 X4
M5 S145
G0 X5
M5 S0
Thanks!
