Repetier is throttling down my extruder temperature
I have a problem where my set temperature is 210C. Repetier shows this on the Temperature Curve graph and says "TargetExtr0:210" in the Log. I can see in the Output Extruder graph, the software gives full output power to the Extruder until it reaches around 203C. After that, I can see in the Output Extruder graph, the software throttles down the output power to about 60% and holds it steady there. Because of that, the temperature just sits on 203-204C and my print never starts because the temperature never reaches 210C
What would cause this behavior?
