Hi I do not understand exactly what you mean. But I keep working with the 128.64 screen. mks tft fixes the problem with the screen problem.
I
started writing from a different version without having to start a new
version of 1.0 sd card started after the pause and completely stop the
options do not come up in the menu everywhere I found a problem I do not
have this problem anymore no longer have these options.
Missing line number is just a communication failure and is fixed by resending line 13. Especially on startup sich errors are common.
my repetier host records this way
12:28:37.352 : OpenGL version:4.0.0 - Build 10.18.10.4358
12:28:37.354 : OpenGL extensions:GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_blend_color GL_EXT_abgr GL_EXT_texture3D GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_SGIS_texture_edge_clamp GL_SGIS_generate_mipmap GL_EXT_draw_range_elements GL_SGIS_texture_lod GL_EXT_rescale_normal GL_EXT_packed_pixels GL_EXT_texture_edge_clamp GL_EXT_separate_specular_color GL_ARB_multitexture GL_ARB_map_buffer_alignment GL_ARB_conservative_depth GL_EXT_texture_env_combine GL_EXT_bgra GL_EXT_blend_func_separate GL_EXT_secondary_color GL_EXT_fog_coord GL_EXT_texture_env_add GL_ARB_texture_cube_map GL_ARB_transpose_matrix GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_texture_env_add GL_IBM_texture_mirrored_repeat GL_EXT_multi_draw_arrays GL_SUN_multi_draw_arrays GL_NV_blend_square GL_ARB_texture_compression GL_3DFX_texture_compression_FXT1 GL_EXT_texture_filter_anisotropic GL_ARB_texture_border_clamp GL_ARB_point_parameters GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar GL_EXT_texture_compression_s3tc GL_ARB_shadow GL_ARB_window_pos GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_ARB_vertex_program GL_EXT_texture_rectangle GL_ARB_fragment_program GL_EXT_stencil_two_side GL_ATI_separate_stencil GL_ARB_vertex_buffer_object GL_EXT_texture_lod_bias GL_ARB_occlusion_query GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_non_power_of_two GL_ARB_vertex_shader GL_NV_texgen_reflection GL_ARB_point_sprite GL_ARB_fragment_program_shadow GL_EXT_blend_equation_separate GL_ARB_depth_texture GL_ARB_texture_rectangle GL_ARB_draw_buffers GL_ARB_color_buffer_float GL_ARB_half_float_pixel GL_ARB_texture_float GL_ARB_pixel_buffer_object GL_EXT_framebuffer_object GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_occlusion_query2 GL_EXT_draw_buffers2 GL_WIN_swap_hint GL_EXT_texture_sRGB GL_ARB_multisample GL_EXT_packed_float GL_EXT_texture_shared_exponent GL_ARB_texture_rg GL_ARB_texture_compression_rgtc GL_NV_conditional_render GL_ARB_texture_swizzle GL_EXT_texture_swizzle GL_ARB_texture_gather GL_ARB_sync GL_ARB_framebuffer_sRGB GL_EXT_packed_depth_stencil GL_ARB_depth_buffer_float GL_EXT_transform_feedback GL_ARB_transform_feedback2 GL_ARB_draw_indirect GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_ARB_framebuffer_object GL_ARB_framebuffer_no_attachments GL_EXT_texture_array GL_EXT_texture_integer GL_ARB_map_buffer_range GL_ARB_texture_buffer_range GL_EXT_texture_buffer GL_EXT_texture_snorm GL_ARB_blend_func_extended GL_INTEL_performance_queries GL_INTEL_performance_query GL_ARB_copy_buffer GL_ARB_sampler_objects GL_NV_primitive_restart GL_ARB_seamless_cube_map GL_ARB_uniform_buffer_object GL_ARB_depth_clamp GL_ARB_vertex_array_bgra GL_ARB_shader_bit_encoding GL_ARB_draw_buffers_blend GL_ARB_geometry_shader4 GL_EXT_geometry_shader4 GL_ARB_texture_query_lod GL_ARB_explicit_attrib_location GL_ARB_draw_elements_base_vertex GL_ARB_instanced_arrays GL_ARB_base_instance GL_ARB_fragment_coord_conventions GL_EXT_gpu_program_parameters GL_ARB_texture_buffer_object_rgb32 GL_ARB_compatibility GL_ARB_texture_rgb10_a2ui GL_ARB_texture_multisample GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_timer_query GL_ARB_tessellation_shader GL_ARB_vertex_array_object GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_texture_cube_map_array GL_EXT_gpu_shader4 GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_shader_subroutine GL_ARB_transform_feedback3 GL_ARB_get_program_binary GL_ARB_separate_shader_objects GL_ARB_shader_precision GL_ARB_vertex_attrib_64bit GL_ARB_viewport_array GL_ARB_transform_feedback_instanced GL_ARB_compressed_texture_pixel_storage GL_ARB_shader_atomic_counters GL_ARB_shading_language_packing GL_ARB_shading_language_420pack GL_ARB_texture_storage GL_EXT_texture_storage GL_ARB_vertex_attrib_binding GL_ARB_multi_draw_indirect GL_ARB_program_interface_query GL_ARB_texture_storage_multisample GL_ARB_buffer_storage GL_ARB_debug_output GL_KHR_debug GL_ARB_arrays_of_arrays GL_INTEL_map_texture GL_ARB_texture_compression_bptc GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_robustness GL_EXT_texture_sRGB_decode GL_KHR_blend_equation_advanced GL_EXT_shader_integer_mix GL_ARB_stencil_texturing
12:28:37.354 : OpenGL renderer:Intel(R) HD Graphics 4000
12:28:37.354 : Using fast VBOs for rendering is possible
12:29:14.191 : No start signal detected - forcing start
12:29:14.233 : N1 M110*34
12:29:14.234 : N2 M115*36
12:29:14.234 : N3 M105*36
12:29:14.234 : N4 M114*35
12:29:14.234 : N5 M111 S6*98
12:29:14.239 : N6 T0*60
12:29:14.239 : N7 M20*22
12:29:14.244 : N8 M80*19
12:29:23.261 : Printer reset detected - initalizing
12:29:23.289 : start
12:29:23.378 : N1 M110*34
12:29:23.378 : N2 M115*36
12:29:23.378 : N3 M105*36
12:29:23.378 : N4 M114*35
12:29:23.381 : N5 M111 S6*98
12:29:23.382 : N6 T0*60
12:29:23.382 : N7 M20*22
12:29:23.387 : N8 M80*19
12:29:25.919 : Free RAM:3834
12:29:25.919 : SelectExtruder:0
12:29:25.920 : FlowMultiply:100
12:29:25.920 : ok
12:29:25.921 : ok 2
12:29:25.926 : N9 M220 S100*104
12:29:25.926 : N10 M221 S100*81
12:29:25.926 : N11 M111 S6*87
12:29:25.926 : FIRMWARE_NAME:Repetier_0.92.9 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Core_XY EXTRUDER_COUNT:1 REPETIER_PROTOCOL:3
12:29:25.926 : Printed filament:941.33m Printing time:10 days 3 hours 52 min
12:29:25.926 : PrinterMode:FFF
12:29:25.926 : ok 3
12:29:25.926 : N12 T0*9
12:29:25.957 : T:0.00 /0 B:0.00 /0 B@:0 @:0
12:29:25.957 : ok 4
12:29:25.957 : X:0.00 Y:0.00 Z:0.000 E:0.0000
12:29:25.957 : ok 5
12:29:25.957 : DebugLevel:6
12:29:25.957 : ok 6
12:29:25.957 : SelectExtruder:0
12:29:25.957 : FlowMultiply:100
12:29:25.957 : ok 7
12:29:25.957 : Begin file list
12:29:25.959 : End file list
12:29:25.960 : ok 8
12:29:25.982 : Error:Missing linenumber
12:29:25.982 : Resend:9
12:29:25.989 : ok
12:29:25.989 : Resend: N9 M220 S100*104
12:29:25.989 : Resend: N10 M221 S100*81
12:29:25.989 : Resend: N11 M111 S6*87
12:29:25.989 : Resend: N12 T0*9
12:29:25.990 : Error:Missing linenumber
12:29:25.990 : Resend:9
12:29:25.993 : ok
12:29:25.993 : ok 9
12:29:25.993 : SpeedMultiply:100
12:29:25.993 : ok 10
12:29:25.994 : FlowMultiply:100
12:29:25.994 : ok 11
12:29:25.994 : DebugLevel:6
12:29:25.994 : ok 12
12:29:25.994 : SelectExtruder:0
12:29:26.073 : skip 9
12:29:26.073 : ok
12:29:26.073 : skip 10
12:29:26.073 : ok
12:29:26.073 : skip 11
12:29:26.073 : ok
12:29:26.073 : skip 12
12:29:26.073 : ok
12:29:27.080 : wait
12:29:28.072 : wait
12:29:29.079 : wait
12:29:30.071 : wait
12:29:31.077 : wait
12:29:32.054 : Error:Missing linenumber
12:29:32.054 : Resend:13
12:29:32.056 : ok
12:29:33.061 : wait
12:29:34.068 : wait
12:29:35.060 : wait
12:29:36.067 : wait
12:29:37.058 : Error:Missing linenumber
12:29:37.058 : Resend:13
12:29:37.061 : ok
12:29:38.146 : wait
12:29:39.137 : wait
12:29:40.144 : wait
12:29:41.136 : wait
I started writing from a different version without having to start a new version of 1.0 sd card started after the pause and completely stop the options do not come up in the menu everywhere I found a problem I do not have this problem anymore no longer have these options.
