repetier firmware cant print from SD card
Hi
i used the
the problem is that the display works fine... i can control homing , read the sd card but when i press to print a file from the sd card then the dispaly shows for few seconds below that printer is printing and then goes again to the previous state... like being in stand by mode... (no errors appearing )
The file i had in the sd card has been sliced with cura engine with repetier host 1.6.2 i am using
When i am using the usb cable to send the file to the printer.. it works fine and printed
thanks in advance
i used the
Repetier-Firmware configuration tool 0.92.9 version
to update my previous setup in order to add a LCD screen support with SD cardthe problem is that the display works fine... i can control homing , read the sd card but when i press to print a file from the sd card then the dispaly shows for few seconds below that printer is printing and then goes again to the previous state... like being in stand by mode... (no errors appearing )
thanks in advance
You might also try with host connected to too if there are some messages in log.
i will try all these you suggested me to see what was wrong... thanks
i tried all above but nothing changed
i can print through repetier host but the printer cant print from Sd card
here is the log file from 2 attempts i tried today
12:35:33.120 : File opened:ex28byj_fila.gcode Size:1705140
12:35:33.121 : File selected
12:35:33.295 : Done printing file
12:35:33.295 : N30 M114*20
12:36:12.688 : File opened:ex28byj.gcode Size:1424602
12:36:12.688 : File selected
12:36:12.862 : Done printing file
12:36:12.862 : N44 M114*23
Still cant make it work with Sd card
I tried different sd cards i had but still nothing...
i was trying to print a Gcode file from sd Card (.gcode) and seems that firmware cant do that
i saved my file from repetier host as ''Save for SD print'' and i manage to print the file from SD card
the file now has the extension .gco
i my Delta 3d printer that i a have Marlin firmware i could print the files with the .gcode extension
Am i doing something wrong and i cant print the .gcode files with my repetier firmware based 3dPrinter? or it is just like this? i can use only the .gco extension?
it is not big problem that .. just asking to know
But this is something not so necessary so i am happy that i found the solution to print from sd card with .gco extension
i love the repetier host and repetier firmware.. make the build of custom 3d printers so easy !!
Thanks for the replies / interesting to my problem
Ps : To everyone else reading this.. donate to keep it live (even small donations like me i think it counts )
