Remove Filament
I love the way I can set the fast and slow feed distances for inserting new filament.
However, I do not see a similar option for Remove Filament. Is it possible to either have the Remove Filament option use the same user set distances, but in reverse, i.e. slow rate first followed by fast, or to have separate input options for the remove filament option?
Thanks.
Could you please inform me which file I would need to edit to change the extrude length and text on the button? I am able to edit in Arduino IDE and recompile so can look at achieving this myself. Thanks.
In server for filament change you can write scripts to run for insert and remove filament in addition. This gets run when you select remove/insert so just write your favourite sequence there.
