Dev build End stops compensation?
I had been trying to tweak this problem:
I use Repetier has a CNC machine, the X and Y axis are switched in the Min pins (they are adjustable since CNC jobs don't always start at the corners of the table), but the Z axis is done with an alligator at the router bit and a 2 mm steel plating, they make contact and a signal de-bouncer do the job great; The problem here is the 2mm gap that translates into a Gcode tweak i do every time while modeling, is there a config for it?
So far i had only tweaked:
//This is the back move the firmware does while probing the end stop switches (?)
#define ENDSTOP_X_BACK_MOVE 10
#define ENDSTOP_Y_BACK_MOVE 10
#define ENDSTOP_Z_BACK_MOVE 10
//This is the back move after the Min place has been calculated (?)
#define ENDSTOP_X_BACK_ON_HOME 0
#define ENDSTOP_Y_BACK_ON_HOME 0
Questions:
After the axis has been configured using the Min switch, the ENDSTOP_X_BACK_ON_HOME moves the actual home of that axis? in the software i mean.
Even if i tweak the 2mm gap due to the steel probe i get more than 2mm of real offset (5mm offset), where does those 3 mm come from?
Also even if i do those 5mm after hitting Start print i get another offset, lets say:
1)19mm material + 2mm steel probe = 21mm total.
2)All axis are homed and Z probe has a 2mm offset with the real material.
3)In software a starting depth of 2 mm is selected and a finish depth of 8.5 if selected (Since i only need 6.5mm of carving)
4) Print started but bit wont come close to the 19mm material and also a ~5mm gap is always created betwheen the bit and the material even if the starting depth is changed in the software.
Also after a Kill print the Z axis goes up around 5mm when manual adjustment is done, creating more offset.
I Googled the config variables but no CNC based documentation is available, I'm stuck in a wall since only the Dev has G32 G33 capabilities
Questions:
That would be the first step required here I think. In that case you need to set z probe height so that it is the distance between too bottom and bed when you measure. Now I' not sure if you always have the 2mm from steel plating when measuring or not. If it is not constantly used reduce z probe height by 2mm and set bed coating to 0 or 2 depending on the use of it.
Homing measures the bottom of the printer. Often moves below z<0 are not allowed and blocked especially if you home z on top of your material. In newer dev versions we have modified F30 to this syntax:
- G30 P<0..3> - Single z-probe at current position P = 1 first measurement, P = 2 Last measurement P = 0 or 3 first and last measurement
- G30 H<height> R<offset> Make probe define new Z and z offset (R) at trigger point assuming z-probe measured an object of H height.
You need the second version here.
G30 H19 R2
would assume 19mm material plus 2mm steel plate when measuring, so material starts at z=0 and you can down until z=-19
G30 will do no bed coating correction so you need to add it as R parameter if used.
Am I missing other configs? I feel like I'm missing steps.
Configuration.h
https://drive.google.com/file/d/1-3jL1lMAWzA6z5tEXAE04DfzGvIcUfM-/view?usp=sharing
Also video for ref.
What would be the proper configuration for CNC milling for this case?
That is why you need G30. The error you get is if activating the probe (meaning move it x offset/y offset) results in a position outside your reachable area. In config you have set it 0 but I guess in eeprom you have a different value, so you need to check there or copy config values to eeprom with
M502
M500
What is your z-probe in that case? Would have thought you use the alligator trick also for z-probing. After reading the code I would not z home a cnc at all. Only use the G30 command. Use z homing only if you can measure the bottom height and do not measure the parts top side.
Would this be the correct way to look at the coordinate system in 3D printers?, since 3D printers go from buttom to top?, because the CNC software I use goes from top to bottom (ArtCAM), back in 0.92 Z Min was manually set using Emergency Stop and hitting "Home Z" (since Z min switch was disabled), but since only 1.0 is able to use G33 for the so needed distortion map on my "almost flat" CNC bed and "almost flat" plywood; this Z min and the non negative Z coordinated go beyond my knowledge.
Also keeping in mind that each time i change the router bit my Z-probe height changes, and moving that 2mm steel plating for each of the G33 distortion map would be tedious.
z probe is if you want a reference point measured and other stuff.
Check M119 - z probe must be L before you start G30 or it will also fail. H indicates it already touches so nothing to probe. Maybe you need to invert signal.
I home X, then Y, send a G30 H19 R2, does one probe, goes up and fatal:G30 probing failed.
Back on 0.92 I could use ArtCAM without endstops and could move any axis into negative coordinates at free will, only had to hit emergency stop and all the axis got to cero, but in 1.0Dev (wich i need for distortion map for wood natural curvature) i cant move any axis at free will nor i can make my Z axis go down.
So Z Min of for detecting my bed surface without any kind of material on it, kind of like a empry 3D printer, Z probe is for G29, G30, G33 etc.
And yes, it's like a 3d printer since it is a 3d printer firmware that can be used for cnc:-)
So getting back in the G30 H19 R2 tweak, the Z robe has a 63.400mm height and the material is 19mm thick so for a G30 redefined Z would be G30 H19 R0? since there will be a 0mm offset (tested and it did work, just curious about parameters and that I'm not cheesing this :P).
procedure :
Home z , Home x , home y , then probe .
That´s the way it works for me
do you have endstop at z-max?
what happens when you home z and send G0 Z200 afterwards (without probing)
After homing chaneck M114 to see what firmware thinks where it is. Moving from there 10mm should move 10mm.
1-Home Z, X and Y in that order.
2-Manually move my router bit on top of material.
3-G92 Z0 to redifine current Z position to 0.
4-M114 to check X:0.00 Y:0.00 Z:0.000 E:0.0000
5-G30 H19 R0 wich allow Z negative movements?
6-G33 for my so needed distorsion map.
7-Print *_*
Quote:
"Y in software goes from 250 to 200, but Z axis keeps going down and has no intentions to stop, had to emergency stop, used G0 Z240 and did the same. "
maybe you should post your configuration.h to see whats going wrong with your z-movement, seems you are mixing things
Edit configuration.h:
https://drive.google.com/file/d/1j_EH_qro8-DpE198Tki8JdeVU5QXX9v0/view?usp=sharing
Edit:
So far all if working like magic, only problesm is that G33 does an all axis homing followed by a Z axis falling that does not stop after Zprobe activation followed by a Z axis crash (nor it moves for the Zprobe offsets).
maybe you should check eeprom values if they match the values you wanted to have.
especially check steps for Z-axis.
cannot see unusual Setting in configuration.h on first sight. i just wonder why z-axis homes to max
and doesn´t stop when moving downwards.
as you wrote you set z-max to 150 so if you send G0 Z140 it should just move down 10 mm´s
Bed Measuring Method is set to n * n Bed leveling grid size is 10 probing a 20x20 square doing software correction/rotation.
