Image V7 with Repetier Server connection to Eduroam
Hi everyone,
i am new to this forum so i hope this topic is in the right categorie.
Me and an fellow student are working on an project work to build an xy core 3d printer.
The printer is now built and we are working on the quality, printing speed and connection.
We are using Repetier as firmware and also Repetier Server on an Raspberry Pi 3.
First we installed Debian Jessie as Image and installed the server.
The internet connection was made with the wifi of our university "eduroam" which has an username and password to type in. Also the key management is WPA-EAP.
The problem was that the printer stoped random in the middle of the print when we started the print over the server
After checking the configuration and also the hardware like circuit boards and usb cable there was no solution and we decided to configurate the server new.
Now that we have installed the image V7 with Repetier Server and are trying to get it into the eduroam without any success.
So now my questions.
Does anybody have an idea why the printer stopped random in the middle of a print after starting over the Server?
Can anybody help us that we can integrade our printer in the eduroam wifi?
I have to apologize for my bad english and i appreciate your answers.
Florian
Florian
/usr/local/Repetier-Setup/bin/manageWifiAccess to setup the wifi using network manager. Configs from NetworkManager end up in /etc/NetworkManager/system-connections directory. For me the file contains
[wifi-security]
key-mgmt=wpa-psk
Once you know how to make connection work with network manager (disable server while testing) you can modify manageWifiAccess especially this part:
connectPW)
prepareConnect
nmcli dev disconnect $WLAN &> /dev/null
nmcli connection delete "$P1" &> /dev/null
nmcli dev wifi connect "$P1" password "$P2" hidden "$P3" &> /dev/null
ret=$?
if [ $ret == 0 ] ; then
echo "OK"
else
echo "Failed"
fi
which creates the configuration. You might just need to add a extra parameter for wpa-eap and then you are done.
Stops in the middle are hard to say why. Possible reasons I already saw:
1) Uploading while slicer was not finished writing the file.
2) Linux closed port for some reason
3) Communication errors
4) Printer had problems with power crashing usb connection
We know that you can print for weeks without problems if everything is working stable so you need to find the unstable part. So start logging. If it happens see log for end of print and if there are any hints. Check /var/log/systel to see if linux did something. See /var/lib/Repetier-Server/log/server.log to see if there are any hints in global server log.
Make sure Pi is powered good enough. If you have a display connected you see a energy sign in right top if power gets critical - also it might still work. My pi 3 with 3A power connector still shows the sign from time to time, so it is a bit critical. Sometimes a actively powered usb hub between pi and printer also helps especially if printer draws some current from pi. USb specs and pi allow this but if you are on the edge it might be a problem.
thanks for your answer.
The WIFI now works, but in order to the stops in the middle of the print we decided to get the Raspberry on the LAN of the network from our university.
After quite a really long time the Print stopped again. The AP was disabled and also we made no connection with the WIFI.
I followed the instructions as you gave me and had a look the log.
Unfortunally we haven´t the knowledge in reading the logs. So perhaps i may ask you to have a look on that?
[31704.086616] [<80121c20>] (__wake_up_parent) from [<801080c0>] (ret_fast_syscall+0x0/0x1c)
[31704.086619] ---[ end trace ff3c27833be5c309 ]---
[31704.086731] ------------[ cut here ]------------
[31704.086737] WARNING: CPU: 3 PID: 26683 at fs/sysfs/group.c:237 sysfs_remove_group+0xa0/0xa4
[31704.086740] sysfs group 'power' not found for kobject 'media0'
[31704.086741] Modules linked in: ftdi_sio usbserial bnep bluetooth brcmfmac uvcvideo brcmutil cfg80211 videobuf2_vmalloc snd_usb_audio fb_ili9486(C) videobuf2_memops snd_hwdep fbtft(C) videobuf2_v4l2 snd_usbmidi_lib rfkill syscopyarea videobuf2_core evdev sysfillrect snd_rawmidi joydev videodev sysimgblt snd_seq_device media fb_sys_fops ads7846 hwmon snd_bcm2835 snd_pcm snd_timer snd i2c_bcm2835 spi_bcm2835 bcm2835_gpiomem uio_pdrv_genirq uio fixed i2c_dev fuse ipv6
[31704.086812] CPU: 3 PID: 26683 Comm: mjpg_streamer Tainted: G WC 4.9.35-v7+ #1014
[31704.086814] Hardware name: BCM2835
[31704.086822] [<8010fb3c>] (unwind_backtrace) from [<8010c058>] (show_stack+0x20/0x24)
[31704.086828] [<8010c058>] (show_stack) from [<80455880>] (dump_stack+0xd4/0x118)
[31704.086835] [<80455880>] (dump_stack) from [<8011d344>] (__warn+0xf8/0x110)
[31704.086841] [<8011d344>] (__warn) from [<8011d3a4>] (warn_slowpath_fmt+0x48/0x50)
[31704.086847] [<8011d3a4>] (warn_slowpath_fmt) from [<802edb84>] (sysfs_remove_group+0xa0/0xa4)
[31704.086856] [<802edb84>] (sysfs_remove_group) from [<805022e8>] (dpm_sysfs_remove+0x5c/0x60)
[31704.086864] [<805022e8>] (dpm_sysfs_remove) from [<804f6c44>] (device_del+0x48/0x22c)
[31704.086885] [<804f6c44>] (device_del) from [<7f152868>] (media_devnode_unregister+0x44/0x58 [media])
[31704.086915] [<7f152868>] (media_devnode_unregister [media]) from [<7f1521b0>] (media_device_unregister+0x128/0x140 [media])
[31704.086946] [<7f1521b0>] (media_device_unregister [media]) from [<7f3d736c>] (uvc_delete+0x6c/0x14c [uvcvideo])
[31704.086979] [<7f3d736c>] (uvc_delete [uvcvideo]) from [<7f3d7584>] (uvc_release+0x4c/0x50 [uvcvideo])
[31704.087047] [<7f3d7584>] (uvc_release [uvcvideo]) from [<7f16880c>] (v4l2_device_release+0xd8/0xfc [videodev])
[31704.087103] [<7f16880c>] (v4l2_device_release [videodev]) from [<804f6398>] (device_release+0x3c/0xa0)
[31704.087111] [<804f6398>] (device_release) from [<80457abc>] (kobject_release+0x50/0x84)
[31704.087119] [<80457abc>] (kobject_release) from [<80457b44>] (kobject_put+0x54/0x80)
[31704.087127] [<80457b44>] (kobject_put) from [<804f6744>] (put_device+0x24/0x28)
[31704.087182] [<804f6744>] (put_device) from [<7f168518>] (v4l2_release+0x60/0x84 [videodev])
[31704.087238] [<7f168518>] (v4l2_release [videodev]) from [<802720f0>] (__fput+0x9c/0x1e8)
[31704.087245] [<802720f0>] (__fput) from [<802722ac>] (____fput+0x18/0x1c)
[31704.087252] [<802722ac>] (____fput) from [<8013ab9c>] (task_work_run+0xcc/0xfc)
[31704.087258] [<8013ab9c>] (task_work_run) from [<80121354>] (do_exit+0x370/0xaec)
[31704.087264] [<80121354>] (do_exit) from [<80121b68>] (do_group_exit+0x4c/0xe4)
[31704.087271] [<80121b68>] (do_group_exit) from [<80121c20>] (__wake_up_parent+0x0/0x30)
[31704.087278] [<80121c20>] (__wake_up_parent) from [<801080c0>] (ret_fast_syscall+0x0/0x1c)
[31704.087281] ---[ end trace ff3c27833be5c30a ]---
[31704.124878] Indeed it is in host mode hprt0 = 00001501
[31704.324860] usb 1-1: new high-speed USB device number 20 using dwc_otg
[31704.324945] Indeed it is in host mode hprt0 = 00001101
[31704.554966] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[31704.554975] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[31704.555475] hub 1-1:1.0: USB hub found
[31704.555529] hub 1-1:1.0: 5 ports detected
[31704.874863] usb 1-1.1: new high-speed USB device number 21 using dwc_otg
[31705.005123] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[31705.005138] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[31705.008117] smsc95xx v1.0.5
[31705.108886] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:69:7a:69
[31705.214851] usb 1-1.3: new full-speed USB device number 22 using dwc_otg
[31705.372358] usb 1-1.3: New USB device found, idVendor=0403, idProduct=6001
[31705.372371] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[31705.372379] usb 1-1.3: Product: FT232R USB UART
[31705.372387] usb 1-1.3: Manufacturer: FTDI
[31705.372394] usb 1-1.3: SerialNumber: A50653JG
[31705.380744] ftdi_sio 1-1.3:1.0: FTDI USB Serial Device converter detected
[31705.380942] usb 1-1.3: Detected FT232RL
[31705.381833] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB0
[31705.684851] usb 1-1.5: new high-speed USB device number 23 using dwc_otg
[31705.865646] usb 1-1.5: New USB device found, idVendor=1908, idProduct=2310
[31705.865659] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[31705.865667] usb 1-1.5: Product: USB2.0 PC CAMERA
[31705.865675] usb 1-1.5: Manufacturer: Generic
[31705.865683] usb 1-1.5: SerialNumber: 20100331010203
[31705.866850] uvcvideo: Found UVC 1.00 device USB2.0 PC CAMERA (1908:2310)
[31705.867607] uvcvideo 1-1.5:1.0: Entity type for entity Processing 2 was not initialized!
[31705.867622] uvcvideo 1-1.5:1.0: Entity type for entity Camera 1 was not initialized!
[31705.868190] input: USB2.0 PC CAMERA as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/input/input5
[31706.225960] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[31706.226168] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[31707.708219] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[31707.710027] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x41E1
[31983.437768] ip_tables: (C) 2000-2006 Netfilter Core Team
[31983.464168] nf_conntrack version 0.5.0 (15360 buckets, 61440 max)
[31983.917148] brcmfmac: brcmf_cfg80211_stop_ap: setting INFRA mode failed -7
[31984.827670] brcmfmac: brcmf_cfg80211_stop_ap: setting INFRA mode failed -7
[31985.394234] brcmfmac: power management disabled
[31986.336691] brcmfmac: brcmf_cfg80211_stop_ap: setting INFRA mode failed -7
Can you have an look on that?
Do you need some more informations?
Florian
ftdi_sio ttyUSB0: error from flowcontrol urb
And also this one
[31703.626844] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.626866] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.626881] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.626907] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.626922] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.626937] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.754880] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.754902] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.754920] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.754943] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.754961] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.754977] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.754997] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755012] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755029] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755047] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755063] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755078] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755096] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755111] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755127] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755145] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755160] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755175] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755193] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755208] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755224] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755242] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755258] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755274] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755292] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755308] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755323] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755343] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755357] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755372] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755387] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755402] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755416] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755431] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755445] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755460] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755476] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755490] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755505] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755521] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755535] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755549] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755566] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755580] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755595] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755610] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755624] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755638] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755655] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755668] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755683] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755698] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755713] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755727] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755742] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755756] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755770] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755786] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755799] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755813] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755829] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755843] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755857] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755872] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755886] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755901] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755917] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755930] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755944] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755960] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755974] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.755989] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.756005] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.756018] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.756033] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.756049] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.756062] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.756077] NYET/NAK/ACK/other in non-error case, 0x00000002
[31703.854882] usb usb1-port1: disabled by hub (EMI?), re-enabling...
[31703.854899] usb 1-1: USB disconnect, device number 16
[31703.854905] usb 1-1.1: USB disconnect, device number 17
[31703.855237] smsc95xx 1-1.1:1.0 eth0: unregister 'smsc95xx' usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet
[31703.855332] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[31703.925357] usb 1-1.3: USB disconnect, device number 18
[31703.925545] ftdi_sio ttyUSB0: error from flowcontrol urb
[31703.927019] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[31703.927065] ftdi_sio 1-1.3:1.0: device disconnected
[31703.928556] usb 1-1.5: USB disconnect, device number 19
pi@Felix:~ $ tail -10 /var/log/syslog
Nov 22 06:51:28 Felix avahi-daemon[411]: Received response from host 192.168.0.10 with invalid source port 61948 on interface 'eth0.0'
Nov 22 06:51:28 Felix avahi-daemon[411]: Received response from host 192.168.0.10 with invalid source port 61948 on interface 'wlan0.0'
Nov 22 06:51:44 Felix avahi-daemon[411]: Received response from host 192.168.0.10 with invalid source port 61948 on interface 'eth0.0'
Nov 22 06:51:44 Felix avahi-daemon[411]: Received response from host 192.168.0.10 with invalid source port 61948 on interface 'wlan0.0'
Nov 22 06:52:16 Felix avahi-daemon[411]: Received response from host 192.168.0.10 with invalid source port 61948 on interface 'eth0.0'
Nov 22 06:52:16 Felix avahi-daemon[411]: Received response from host 192.168.0.10 with invalid source port 61948 on interface 'wlan0.0'
Nov 22 06:53:20 Felix avahi-daemon[411]: Received response from host 192.168.0.10 with invalid source port 61948 on interface 'eth0.0'
Nov 22 06:53:20 Felix avahi-daemon[411]: Received response from host 192.168.0.10 with invalid source port 61948 on interface 'wlan0.0'
Nov 22 07:05:13 Felix systemd[1]: Starting Session c12 of user pi.
Nov 22 07:05:13 Felix systemd[1]: Started Session c12 of user pi.
And server log like this:
pi@Felix:~ $ tail -10 /var/lib/Repetier-Server/logs/server.log
2017-07-06 11:22:40: Closing websocket for missing ping
2017-07-06 11:22:56: Closing websocket for missing ping
2017-07-06 11:23:12: Closing websocket for missing ping
2017-07-06 11:23:28: Closing websocket for missing ping
2017-07-06 11:23:44: Closing websocket for missing ping
2017-07-06 11:24:01: Closing websocket for missing ping
2017-07-06 11:24:17: Closing websocket for missing ping
2017-07-06 11:24:33: Closing websocket for missing ping
2017-07-06 11:24:49: Closing websocket for missing ping
2017-07-06 11:25:05: Closing websocket for missing ping
You see here you have a more usable timestamp. Also dmesg doe snot log everything only services starting I think.
In addition please also provide the time of the error, so I know where to look into the log, not that I can read it better. Each komponent decides how and what to log so no one really can read it fully. You can only hope to make some sense from what you read.
So the print stopping was on Nov 21 at 19:14.
So I took the Server logs from starting the print:
2017-11-21 16:54:49: start printjob pistand on printer 01_Proto
2017-11-21 16:54:49: Added timelapse 20171121T165449_pistand
2017-11-21 16:55:49: Reading configuration file ...
Input file: /var/lib/Repetier-Server/printer/01_Dildoser/models/00000037_pistand.layer
Rendering shadows ...6.14843 seconds.
Rendering gcode ...64.4306 seconds.
Number of end triangles: 30096
Number of normal triangles: 2171416
Rendering background ...
Time for raytracing: 15.2028 seconds.
images stored.
Computation time: 88.3188 seconds
2017-11-21 16:55:49: LUA job rendering.render#{"id":13,"image":"/var/lib/Repetier-Server/printer/01_Dildoser/jobs/00000013_pistand_l.png","layer":"/var/lib/Repetier-Server/printer/01_Dildoser/jobs/00000013_pistand.layer","list":"jobs","slug":"01_Dildoser"}
2017-11-21 16:57:18: Reading configuration file ...
Input file: /var/lib/Repetier-Server/printer/01_Dildoser/jobs/00000013_pistand.layer
Rendering shadows ...6.17066 seconds.
Rendering gcode ...65.5643 seconds.
Time for raytracing: 15.1747 seconds.
images stored.
Computation time: 89.3802 seconds
2017-11-21 17:07:34: Video:/var/lib/Repetier-Server/printer/01_Dildoser/timelapse/20171121T153334_300x300/video.mp4
2017-11-21 17:08:34: Closing websocket for missing ping
2017-11-21 19:14:32: error: Reading serial conection failed: End of file. Closing connection.
2017-11-21 19:14:32: Connection closed: 01_Proto
2017-11-21 19:14:33: /usr/bin/ffmpeg -loglevel error -f concat -i input.txt -i /var/lib/Repetier-Server/database/watermark.png -c:v libx264 -filter_complex [0:v][1:v]overlay=10:10 -threads 1 -r 30 -pix_fmt yuv420p -profile:v baseline -level 3.0 -movflags +faststart -b:v 1000k -y video.mp4
2017-11-21 19:14:33: cwd = /var/lib/Repetier-Server/printer/01_Dildoser/timelapse/20171121T165449_pistand
2017-11-21 19:14:35: Connection started:01_Proto
2017-11-21 19:14:35: Reset printer 01_Proto
2017-11-21 19:15:51:
2017-11-21 19:15:54: error: Reading serial conection failed: End of file. Closing connection.
2017-11-21 19:15:54: Connection closed: 01_Proto
2017-11-21 19:15:57: Connection started:01_Proto
2017-11-21 19:15:57: Reset printer 01_Proto
2017-11-21 19:20:32: Activating access point
And also the Syslog:
Nov 21 18:59:34 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:00:12 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:00:22 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:00:34 RepetierServer wpa_supplicant[713]: wlan0: Failed to initiate sched sca
n
Nov 21 19:00:59 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:01:09 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:01:37 RepetierServer wpa_supplicant[713]: wlan0: Failed to initiate sched sca
n
Nov 21 19:01:49 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:02:26 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:02:36 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:02:40 RepetierServer wpa_supplicant[713]: wlan0: Failed to initiate sched sca
n
Nov 21 19:03:14 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:03:24 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:03:43 RepetierServer wpa_supplicant[713]: wlan0: Failed to initiate sched sca
n
Nov 21 19:04:03 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:04:40 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:04:46 RepetierServer wpa_supplicant[713]: wlan0: Failed to initiate sched sca
n
Nov 21 19:04:51 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:05:28 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:05:38 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:05:49 RepetierServer wpa_supplicant[713]: wlan0: Failed to initiate sched sca
n
Nov 21 19:06:18 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:06:52 RepetierServer wpa_supplicant[713]: wlan0: Failed to initiate sched sca
n
Nov 21 19:06:54 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:07:04 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:07:42 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:07:53 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:07:55 RepetierServer wpa_supplicant[713]: wlan0: Failed to initiate sched sca
n
Nov 21 19:08:31 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:08:58 RepetierServer wpa_supplicant[713]: wlan0: Failed to initiate sched sca
n
Nov 21 19:09:09 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:09:19 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:09:56 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:10:01 RepetierServer wpa_supplicant[713]: wlan0: Failed to initiate sched sca
n
Nov 21 19:10:06 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:10:46 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:11:04 RepetierServer wpa_supplicant[713]: wlan0: Failed to initiate sched sca
n
Nov 21 19:11:23 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:11:33 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:12:07 RepetierServer wpa_supplicant[713]: wlan0: Failed to initiate sched sca
n
Nov 21 19:12:10 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:12:21 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:13:00 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:13:10 RepetierServer wpa_supplicant[713]: wlan0: Failed to initiate sched sca
n
Nov 21 19:13:37 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:13:48 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:14:13 RepetierServer wpa_supplicant[713]: wlan0: Failed to initiate sched sca
n
Nov 21 19:14:25 RepetierServer MJPG-streamer [19141]: serving client: 127.0.0.1
Nov 21 19:14:32 RepetierServer kernel: [31621.570029] NYET/NAK/ACK/other in non-error c
ase, 0x00000002
Nov 21 19:14:32 RepetierServer kernel: [31621.570055] NYET/NAK/ACK/other in non-error c
ase, 0x00000002
Nov 21 19:14:32 RepetierServer kernel: [31621.570078] NYET/NAK/ACK/other in non-error c
ase, 0x00000002
Nov 21 19:14:32 RepetierServer kernel: [31621.570103] NYET/NAK/ACK/other in non-error c
ase, 0x00000002
Nov 21 19:14:32 RepetierServer kernel: [31621.570120] NYET/NAK/ACK/other in non-error c
ase, 0x00000002
Nov 21 19:14:32 RepetierServer kernel: [31621.570138] NYET/NAK/ACK/other in non-error c
ase, 0x00000002
Nov 21 19:14:32 RepetierServer dhcpcd[840]: eth0: arp if_readrawpacket: Network is down
Nov 21 19:14:32 RepetierServer kernel: [31621.614714] usb usb1-port1: disabled by hub (
Nov 21 19:14:32 RepetierServer kernel: [31621.614732] usb 1-1: USB disconnect, device n
umber 12
Nov 21 19:14:32 RepetierServer kernel: [31621.614738] usb 1-1.1: USB disconnect, device
number 13
Nov 21 19:14:32 RepetierServer kernel: [31621.615067] smsc95xx 1-1.1:1.0 eth0: unregist
Nov 21 19:14:32 RepetierServer kernel: [31621.615252] smsc95xx 1-1.1:1.0 eth0: hardware
Nov 21 19:14:32 RepetierServer dhcpcd[840]: eth0: carrier lost
Nov 21 19:14:32 RepetierServer avahi-daemon[440]: Interface eth0.IPv6 no longer relevan
t for mDNS.
Nov 21 19:14:32 RepetierServer avahi-daemon[440]: Leaving mDNS multicast group on inter
face eth0.IPv6 with address fe80::96c5:4333:2403:f1ca.
Nov 21 19:14:32 RepetierServer avahi-daemon[440]: Interface eth0.IPv4 no longer relevan
t for mDNS.
face eth0.IPv4 with address 10.10.143.11.
Nov 21 19:14:32 RepetierServer avahi-daemon[440]: Withdrawing address record for fe80::
96c5:4333:2403:f1ca on eth0.
Nov 21 19:14:32 RepetierServer avahi-daemon[440]: Withdrawing address record for 10.10.
143.11 on eth0.
Nov 21 19:14:32 RepetierServer avahi-daemon[440]: Withdrawing workstation service for e
th0.
Nov 21 19:14:32 RepetierServer NetworkManager[442]: <info> devices removed (path: /sys/
devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1:1.0/net/eth0, iface: eth0)
Nov 21 19:14:32 RepetierServer NetworkManager[442]: <info> get unmanaged devices count:
0
Nov 21 19:14:32 RepetierServer kernel: [31621.656879] usb 1-1.3: USB disconnect, device
number 14
Nov 21 19:14:32 RepetierServer kernel: [31621.657051] ftdi_sio ttyUSB0: error from flow
control urb
Nov 21 19:14:32 RepetierServer kernel: [31621.658563] ftdi_sio ttyUSB0: FTDI USB Serial
Nov 21 19:14:32 RepetierServer kernel: [31621.658593] ftdi_sio 1-1.3:1.0: device discon
nected
Nov 21 19:14:32 RepetierServer kernel: [31621.660298] usb 1-1.5: USB disconnect, device
number 15
Nov 21 19:14:32 RepetierServer kernel: [31621.764823] WARNING: CPU: 3 PID: 20928 at fs/
Nov 21 19:14:32 RepetierServer kernel: [31621.764826] sysfs group 'power' not found for
kobject 'event1'
Nov 21 19:14:32 RepetierServer kernel: [31621.764828] Modules linked in: ftdi_sio usbse
Nov 21 19:14:32 RepetierServer kernel: [31621.764943] CPU: 3 PID: 20928 Comm: mjpg_stre
Nov 21 19:14:32 RepetierServer kernel: [31621.764946] Hardware name: BCM2835
Nov 21 19:14:32 RepetierServer kernel: [31621.764963] [<8010fb3c>] (unwind_backtrace) f
Nov 21 19:14:32 RepetierServer kernel: [31621.764973] [<8010c058>] (show_stack) from [<
Nov 21 19:14:32 RepetierServer kernel: [31621.764982] [<80455880>] (dump_stack) from [<
Nov 21 19:14:32 RepetierServer kernel: [31621.764989] [<8011d344>] (__warn) from [<8011
Nov 21 19:14:32 RepetierServer kernel: [31621.764995] [<8011d3a4>] (warn_slowpath_fmt)
Nov 21 19:14:32 RepetierServer kernel: [31621.765006] [<802edb84>] (sysfs_remove_group)
Nov 21 19:14:32 RepetierServer kernel: [31621.765017] [<805022e8>] (dpm_sysfs_remove) f
Nov 21 19:14:32 RepetierServer kernel: [31621.765030] [<804f6c44>] (device_del) from [<
7f1c01cc>] (evdev_disconnect+0x28/0x50 [evdev])
Nov 21 19:14:32 RepetierServer kernel: [31621.765044] [<7f1c01cc>] (evdev_disconnect [e
vdev]) from [<805989a8>] (__input_unregister_device+0xc0/0x160)
Nov 21 19:14:32 RepetierServer kernel: [31621.765053] [<805989a8>] (__input_unregister_
device) from [<805992d0>] (input_unregister_device+0x58/0x80)
Nov 21 19:14:32 RepetierServer kernel: [31621.765079] [<805992d0>] (input_unregister_de
vice) from [<7f3e16a0>] (uvc_status_cleanup+0x40/0x44 [uvcvideo])
Nov 21 19:14:32 RepetierServer kernel: [31621.765114] [<7f3e16a0>] (uvc_status_cleanup
[uvcvideo]) from [<7f3d731c>] (uvc_delete+0x1c/0x14c [uvcvideo])
Nov 21 19:14:32 RepetierServer kernel: [31621.765147] [<7f3d731c>] (uvc_delete [uvcvide
Nov 21 19:14:32 RepetierServer kernel: [31621.765230] [<7f3d7584>] (uvc_release [uvcvid
Nov 21 19:14:32 RepetierServer kernel: [31621.765289] [<7f16880c>] (v4l2_device_release
Nov 21 19:14:32 RepetierServer kernel: [31621.765299] [<804f6398>] (device_release) fro
Nov 21 19:14:32 RepetierServer kernel: [31621.765308] [<80457abc>] (kobject_release) fr
Nov 21 19:14:32 RepetierServer kernel: [31621.765315] [<80457b44>] (kobject_put) from [
Nov 21 19:14:32 RepetierServer kernel: [31621.765381] [<804f6744>] (put_device) from [<
Nov 21 19:14:32 RepetierServer kernel: [31621.765440] [<7f168518>] (v4l2_release [video
Nov 21 19:14:32 RepetierServer kernel: [31621.765449] [<802720f0>] (__fput) from [<8027
Nov 21 19:14:32 RepetierServer kernel: [31621.765457] [<802722ac>] (____fput) from [<80
Nov 21 19:14:32 RepetierServer kernel: [31621.765465] [<8013ab9c>] (task_work_run) from
Nov 21 19:14:32 RepetierServer kernel: [31621.765472] [<80121354>] (do_exit) from [<801
Nov 21 19:14:32 RepetierServer kernel: [31621.765479] [<80121b68>] (do_group_exit) from
[<8012cc34>] (get_signal+0x370/0x6d4)
Nov 21 19:14:32 RepetierServer kernel: [31621.765489] [<8012cc34>] (get_signal) from [<
8010b2cc>] (do_signal+0x74/0x3e4)
Nov 21 19:14:32 RepetierServer kernel: [31621.765498] [<8010b2cc>] (do_signal) from [<8
010b824>] (do_work_pending+0xb8/0xd0)
Nov 21 19:14:32 RepetierServer kernel: [31621.765506] [<8010b824>] (do_work_pending) fr
om [<801080e8>] (slow_work_pending+0xc/0x20)
Nov 21 19:14:32 RepetierServer kernel: [31621.765510] ---[ end trace ff3c27833be5c301 ]
Nov 21 19:14:32 RepetierServer dhcpcd[840]: eth0: deleting address fe80::96c5:4333:2403
:f1ca
Nov 21 19:14:32 RepetierServer dhcpcd[840]: eth0: deleting route to 10.10.140.0/22
Nov 21 19:14:32 RepetierServer dhcpcd[840]: eth0: deleting default route via 10.10.140.
1
Nov 21 19:14:32 RepetierServer kernel: [31621.834824] ------------[ cut here ]---------
Nov 21 19:14:32 RepetierServer kernel: [31621.834843] WARNING: CPU: 3 PID: 20928 at fs/
Nov 21 19:14:32 RepetierServer kernel: [31621.834846] sysfs group 'power' not found for
kobject 'input3'
Nov 21 19:14:32 RepetierServer kernel: [31621.834848] Modules linked in: ftdi_sio usbse
Nov 21 19:14:32 RepetierServer kernel: [31621.834938] CPU: 3 PID: 20928 Comm: mjpg_stre
Nov 21 19:14:32 RepetierServer kernel: [31621.834940] Hardware name: BCM2835
Nov 21 19:14:32 RepetierServer kernel: [31621.834959] [<8010fb3c>] (unwind_backtrace) f
Nov 21 19:14:32 RepetierServer kernel: [31621.834969] [<8010c058>] (show_stack) from [<
Nov 21 19:14:32 RepetierServer kernel: [31621.834978] [<80455880>] (dump_stack) from [<
Nov 21 19:14:32 RepetierServer kernel: [31621.834985] [<8011d344>] (__warn) from [<8011
Nov 21 19:14:32 RepetierServer kernel: [31621.834991] [<8011d3a4>] (warn_slowpath_fmt)
Nov 21 19:14:32 RepetierServer kernel: [31621.835002] [<802edb84>] (sysfs_remove_group)
Nov 21 19:14:32 RepetierServer kernel: [31621.835012] [<805022e8>] (dpm_sysfs_remove) f
Nov 21 19:14:32 RepetierServer kernel: [31621.835022] [<804f6c44>] (device_del) from [<
80598a2c>] (__input_unregister_device+0x144/0x160)
Nov 21 19:14:32 RepetierServer kernel: [31621.835031] [<80598a2c>] (__input_unregister_
Nov 21 19:14:32 RepetierServer kernel: [31621.835058] [<805992d0>] (input_unregister_de
Nov 21 19:14:32 RepetierServer kernel: [31621.835093] [<7f3e16a0>] (uvc_status_cleanup
Nov 21 19:14:32 RepetierServer kernel: [31621.835127] [<7f3d731c>] (uvc_delete [uvcvide
Nov 21 19:14:32 RepetierServer kernel: [31621.835208] [<7f3d7584>] (uvc_release [uvcvid
Nov 21 19:14:32 RepetierServer kernel: [31621.835266] [<7f16880c>] (v4l2_device_release
Nov 21 19:14:32 RepetierServer kernel: [31621.835276] [<804f6398>] (device_release) fro
Nov 21 19:14:32 RepetierServer kernel: [31621.835285] [<80457abc>] (kobject_release) fr
Nov 21 19:14:32 RepetierServer kernel: [31621.835292] [<80457b44>] (kobject_put) from [
Nov 21 19:14:32 RepetierServer kernel: [31621.835347] [<804f6744>] (put_device) from [<
Nov 21 19:14:32 RepetierServer kernel: [31621.835404] [<7f168518>] (v4l2_release [video
Nov 21 19:14:32 RepetierServer kernel: [31621.835412] [<802720f0>] (__fput) from [<8027
Nov 21 19:14:32 RepetierServer kernel: [31621.835420] [<802722ac>] (____fput) from [<80
Nov 21 19:14:32 RepetierServer kernel: [31621.835429] [<8013ab9c>] (task_work_run) from
Nov 21 19:14:32 RepetierServer kernel: [31621.835436] [<80121354>] (do_exit) from [<801
Nov 21 19:14:32 RepetierServer kernel: [31621.835443] [<80121b68>] (do_group_exit) from
Nov 21 19:14:32 RepetierServer kernel: [31621.835452] [<8012cc34>] (get_signal) from [<
Nov 21 19:14:32 RepetierServer kernel: [31621.835460] [<8010b2cc>] (do_signal) from [<8
Nov 21 19:14:32 RepetierServer kernel: [31621.835468] [<8010b824>] (do_work_pending) fr
Nov 21 19:14:32 RepetierServer kernel: [31621.835472] ---[ end trace ff3c27833be5c302 ]
Nov 21 19:14:32 RepetierServer kernel: [31621.835492] ------------[ cut here ]---------
Nov 21 19:14:32 RepetierServer kernel: [31621.835498] WARNING: CPU: 3 PID: 20928 at fs/
Nov 21 19:14:32 RepetierServer kernel: [31621.835501] sysfs group 'id' not found for ko
bject 'input3'
Nov 21 19:14:32 RepetierServer kernel: [31621.835502] Modules linked in: ftdi_sio usbse
Nov 21 19:14:32 RepetierServer kernel: [31621.835576] CPU: 3 PID: 20928 Comm: mjpg_stre
Nov 21 19:14:32 RepetierServer kernel: [31621.835578] Hardware name: BCM2835
Nov 21 19:14:32 RepetierServer kernel: [31621.835586] [<8010fb3c>] (unwind_backtrace) f
Nov 21 19:14:32 RepetierServer kernel: [31621.835593] [<8010c058>] (show_stack) from [<
Nov 21 19:14:32 RepetierServer kernel: [31621.835600] [<80455880>] (dump_stack) from [<
Nov 21 19:14:32 RepetierServer kernel: [31621.835605] [<8011d344>] (__warn) from [<8011
Nov 21 19:14:32 RepetierServer kernel: [31621.835612] [<8011d3a4>] (warn_slowpath_fmt)
Nov 21 19:14:32 RepetierServer kernel: [31621.835618] [<802edb84>] (sysfs_remove_group)
from [<802edbbc>] (sysfs_remove_groups+0x34/0x44)
Nov 21 19:14:32 RepetierServer kernel: [31621.835625] [<802edbbc>] (sysfs_remove_groups
) from [<804f62c0>] (device_remove_attrs+0x60/0x7c)
Nov 21 19:14:32 RepetierServer kernel: [31621.835632] [<804f62c0>] (device_remove_attrs
) from [<804f6d10>] (device_del+0x114/0x22c)
Nov 21 19:14:32 RepetierServer kernel: [31621.835640] [<804f6d10>] (device_del) from [<
Nov 21 19:14:32 RepetierServer kernel: [31621.835648] [<80598a2c>] (__input_unregister_
Nov 21 19:14:32 RepetierServer kernel: [31621.835669] [<805992d0>] (input_unregister_de
Nov 21 19:14:32 RepetierServer kernel: [31621.835703] [<7f3e16a0>] (uvc_status_cleanup
Nov 21 19:14:32 RepetierServer kernel: [31621.835736] [<7f3d731c>] (uvc_delete [uvcvide
Nov 21 19:14:32 RepetierServer kernel: [31621.835803] [<7f3d7584>] (uvc_release [uvcvid
Nov 21 19:14:32 RepetierServer kernel: [31621.835859] [<7f16880c>] (v4l2_device_release
Nov 21 19:14:32 RepetierServer kernel: [31621.835867] [<804f6398>] (device_release) fro
Nov 21 19:14:32 RepetierServer kernel: [31621.835875] [<80457abc>] (kobject_release) fr
Nov 21 19:14:32 RepetierServer kernel: [31621.835882] [<80457b44>] (kobject_put) from [
Nov 21 19:14:32 RepetierServer kernel: [31621.835937] [<804f6744>] (put_device) from [<
Nov 21 19:14:32 RepetierServer kernel: [31621.835993] [<7f168518>] (v4l2_release [video
Nov 21 19:14:32 RepetierServer kernel: [31621.836001] [<802720f0>] (__fput) from [<8027
Nov 21 19:14:32 RepetierServer kernel: [31621.836007] [<802722ac>] (____fput) from [<80
Nov 21 19:14:32 RepetierServer kernel: [31621.836014] [<8013ab9c>] (task_work_run) from
Nov 21 19:14:32 RepetierServer kernel: [31621.836020] [<80121354>] (do_exit) from [<801
Nov 21 19:14:32 RepetierServer kernel: [31621.836026] [<80121b68>] (do_group_exit) from
Nov 21 19:14:32 RepetierServer kernel: [31621.836033] [<8012cc34>] (get_signal) from [<
Nov 21 19:14:32 RepetierServer kernel: [31621.836042] [<8010b2cc>] (do_signal) from [<8
Nov 21 19:14:32 RepetierServer kernel: [31621.836049] [<8010b824>] (do_work_pending) fr
Nov 21 19:14:32 RepetierServer kernel: [31621.836052] ---[ end trace ff3c27833be5c303 ]
Nov 21 19:14:32 RepetierServer kernel: [31621.836055] ------------[ cut here ]---------
Nov 21 19:14:32 RepetierServer kernel: [31621.836060] WARNING: CPU: 3 PID: 20928 at fs/
Nov 21 19:14:32 RepetierServer kernel: [31621.836063] sysfs group 'capabilities' not fo
und for kobject 'input3'
Nov 21 19:14:32 RepetierServer kernel: [31621.836064] Modules linked in: ftdi_sio usbse
Nov 21 19:14:32 RepetierServer kernel: [31621.836135] CPU: 3 PID: 20928 Comm: mjpg_stre
Nov 21 19:14:32 RepetierServer kernel: [31621.836137] Hardware name: BCM2835
Nov 21 19:14:32 RepetierServer kernel: [31621.836144] [<8010fb3c>] (unwind_backtrace) f
Nov 21 19:14:32 RepetierServer kernel: [31621.836151] [<8010c058>] (show_stack) from [<
Nov 21 19:14:32 RepetierServer kernel: [31621.836158] [<80455880>] (dump_stack) from [<
Nov 21 19:14:32 RepetierServer kernel: [31621.836163] [<8011d344>] (__warn) from [<8011
Nov 21 19:14:32 RepetierServer kernel: [31621.836170] [<8011d3a4>] (warn_slowpath_fmt)
Nov 21 19:14:32 RepetierServer kernel: [31621.836176] [<802edb84>] (sysfs_remove_group)
Nov 21 19:14:32 RepetierServer kernel: [31621.836182] [<802edbbc>] (sysfs_remove_groups
Nov 21 19:14:32 RepetierServer kernel: [31621.836189] [<804f62c0>] (device_remove_attrs
Nov 21 19:14:32 RepetierServer kernel: [31621.836196] [<804f6d10>] (device_del) from [<
Nov 21 19:14:32 RepetierServer kernel: [31621.836204] [<80598a2c>] (__input_unregister_
Nov 21 19:14:32 RepetierServer kernel: [31621.836225] [<805992d0>] (input_unregister_de
Nov 21 19:14:32 RepetierServer kernel: [31621.836259] [<7f3e16a0>] (uvc_status_cleanup
Nov 21 19:14:32 RepetierServer kernel: [31621.836292] [<7f3d731c>] (uvc_delete [uvcvide
Nov 21 19:14:32 RepetierServer kernel: [31621.836359] [<7f3d7584>] (uvc_release [uvcvid
Nov 21 19:14:32 RepetierServer kernel: [31621.836415] [<7f16880c>] (v4l2_device_release
Nov 21 19:14:32 RepetierServer kernel: [31621.836423] [<804f6398>] (device_release) fro
Nov 21 19:14:32 RepetierServer kernel: [31621.836431] [<80457abc>] (kobject_release) fr
Nov 21 19:14:32 RepetierServer kernel: [31621.836438] [<80457b44>] (kobject_put) from [
Nov 21 19:14:32 RepetierServer kernel: [31621.836493] [<804f6744>] (put_device) from [<
Nov 21 19:14:32 RepetierServer kernel: [31621.836549] [<7f168518>] (v4l2_release [video
Nov 21 19:14:32 RepetierServer kernel: [31621.836556] [<802720f0>] (__fput) from [<8027
Nov 21 19:14:32 RepetierServer kernel: [31621.836563] [<802722ac>] (____fput) from [<80
Nov 21 19:14:32 RepetierServer kernel: [31621.836570] [<8013ab9c>] (task_work_run) from
Nov 21 19:14:32 RepetierServer kernel: [31621.836576] [<80121354>] (do_exit) from [<801
Nov 21 19:14:32 RepetierServer kernel: [31621.836582] [<80121b68>] (do_group_exit) from
Nov 21 19:14:32 RepetierServer kernel: [31621.836589] [<8012cc34>] (get_signal) from [<
Nov 21 19:14:32 RepetierServer kernel: [31621.836597] [<8010b2cc>] (do_signal) from [<8
Nov 21 19:14:32 RepetierServer kernel: [31621.836605] [<8010b824>] (do_work_pending) fr
Nov 21 19:14:32 RepetierServer kernel: [31621.836608] ---[ end trace ff3c27833be5c304 ]
Nov 21 19:14:32 RepetierServer kernel: [31621.836710] ------------[ cut here ]---------
Nov 21 19:14:32 RepetierServer kernel: [31621.836716] WARNING: CPU: 3 PID: 20928 at fs/
Nov 21 19:14:32 RepetierServer kernel: [31621.836719] sysfs group 'power' not found for
kobject 'media0'
Nov 21 19:14:32 RepetierServer kernel: [31621.836720] Modules linked in: ftdi_sio usbse
Nov 21 19:14:32 RepetierServer kernel: [31621.836792] CPU: 3 PID: 20928 Comm: mjpg_stre
Nov 21 19:14:32 RepetierServer kernel: [31621.836794] Hardware name: BCM2835
Nov 21 19:14:32 RepetierServer kernel: [31621.836801] [<8010fb3c>] (unwind_backtrace) f
Nov 21 19:14:32 RepetierServer kernel: [31621.836808] [<8010c058>] (show_stack) from [<
Nov 21 19:14:32 RepetierServer kernel: [31621.836815] [<80455880>] (dump_stack) from [<
Nov 21 19:14:32 RepetierServer kernel: [31621.836821] [<8011d344>] (__warn) from [<8011
Nov 21 19:14:32 RepetierServer kernel: [31621.836828] [<8011d3a4>] (warn_slowpath_fmt)
Nov 21 19:14:32 RepetierServer kernel: [31621.836836] [<802edb84>] (sysfs_remove_group)
Nov 21 19:14:32 RepetierServer kernel: [31621.836844] [<805022e8>] (dpm_sysfs_remove) f
Nov 21 19:14:32 RepetierServer kernel: [31621.836865] [<804f6c44>] (device_del) from [<
Nov 21 19:14:32 RepetierServer kernel: [31621.836894] [<7f152868>] (media_devnode_unreg
Nov 21 19:14:32 RepetierServer kernel: [31621.836925] [<7f1521b0>] (media_device_unregi
Nov 21 19:14:32 RepetierServer kernel: [31621.836958] [<7f3d736c>] (uvc_delete [uvcvide
Nov 21 19:14:32 RepetierServer kernel: [31621.837025] [<7f3d7584>] (uvc_release [uvcvid
Nov 21 19:14:32 RepetierServer kernel: [31621.837081] [<7f16880c>] (v4l2_device_release
Nov 21 19:14:32 RepetierServer kernel: [31621.837089] [<804f6398>] (device_release) fro
Nov 21 19:14:32 RepetierServer kernel: [31621.837098] [<80457abc>] (kobject_release) fr
Nov 21 19:14:32 RepetierServer kernel: [31621.837105] [<80457b44>] (kobject_put) from [
Nov 21 19:14:32 RepetierServer kernel: [31621.837160] [<804f6744>] (put_device) from [<
Nov 21 19:14:32 RepetierServer kernel: [31621.837216] [<7f168518>] (v4l2_release [video
Nov 21 19:14:32 RepetierServer kernel: [31621.837224] [<802720f0>] (__fput) from [<8027
Nov 21 19:14:32 RepetierServer kernel: [31621.837231] [<802722ac>] (____fput) from [<80
Nov 21 19:14:32 RepetierServer kernel: [31621.837238] [<8013ab9c>] (task_work_run) from
Nov 21 19:14:32 RepetierServer kernel: [31621.837244] [<80121354>] (do_exit) from [<801
Nov 21 19:14:32 RepetierServer kernel: [31621.837251] [<80121b68>] (do_group_exit) from
Nov 21 19:14:32 RepetierServer kernel: [31621.837258] [<8012cc34>] (get_signal) from [<
Nov 21 19:14:32 RepetierServer kernel: [31621.837267] [<8010b2cc>] (do_signal) from [<8
Nov 21 19:14:32 RepetierServer kernel: [31621.837275] [<8010b824>] (do_work_pending) fr
Nov 21 19:14:32 RepetierServer kernel: [31621.837278] ---[ end trace ff3c27833be5c305 ]
Nov 21 19:14:32 RepetierServer kernel: [31621.854746] Indeed it is in host mode hprt0 =
00001501
Nov 21 19:14:32 RepetierServer dhcpcd[840]: eth0: removing interface
Nov 21 19:14:32 RepetierServer kernel: [31622.054688] usb 1-1: new high-speed USB devic
e number 16 using dwc_otg
Nov 21 19:14:32 RepetierServer kernel: [31622.054805] Indeed it is in host mode hprt0 =
00001101
Nov 21 19:14:32 RepetierServer kernel: [31622.284789] usb 1-1: New USB device found, id
Nov 21 19:14:32 RepetierServer kernel: [31622.284798] usb 1-1: New USB device strings:
Nov 21 19:14:32 RepetierServer kernel: [31622.293526] hub 1-1:1.0: USB hub found
Nov 21 19:14:32 RepetierServer kernel: [31622.293610] hub 1-1:1.0: 5 ports detected
Nov 21 19:14:33 RepetierServer kernel: [31622.604684] usb 1-1.1: new high-speed USB dev
ice number 17 using dwc_otg
Nov 21 19:14:33 RepetierServer kernel: [31622.734952] usb 1-1.1: New USB device found,
Nov 21 19:14:33 RepetierServer kernel: [31622.734962] usb 1-1.1: New USB device strings
Nov 21 19:14:33 RepetierServer kernel: [31622.742818] smsc95xx v1.0.5
Nov 21 19:14:33 RepetierServer kernel: [31622.826863] smsc95xx 1-1.1:1.0 eth0: register
Nov 21 19:14:33 RepetierServer kernel: [31622.924689] usb 1-1.3: new full-speed USB dev
ice number 18 using dwc_otg
Nov 21 19:14:33 RepetierServer kernel: [31623.083489] usb 1-1.3: New USB device found,
Nov 21 19:14:33 RepetierServer kernel: [31623.083499] usb 1-1.3: New USB device strings
Nov 21 19:14:33 RepetierServer kernel: [31623.083503] usb 1-1.3: Product: FT232R USB UA
RT
Nov 21 19:14:33 RepetierServer kernel: [31623.083507] usb 1-1.3: Manufacturer: FTDI
Nov 21 19:14:33 RepetierServer kernel: [31623.083511] usb 1-1.3: SerialNumber: A50653JG
Nov 21 19:14:33 RepetierServer kernel: [31623.091660] ftdi_sio 1-1.3:1.0: FTDI USB Seri
Nov 21 19:14:33 RepetierServer kernel: [31623.091771] usb 1-1.3: Detected FT232RL
Nov 21 19:14:33 RepetierServer kernel: [31623.092579] usb 1-1.3: FTDI USB Serial Device
Nov 21 19:14:33 RepetierServer kernel: [31623.394679] usb 1-1.5: new high-speed USB dev
ice number 19 using dwc_otg
Nov 21 19:14:34 RepetierServer kernel: [31623.585263] usb 1-1.5: New USB device found,
Nov 21 19:14:34 RepetierServer kernel: [31623.585272] usb 1-1.5: New USB device strings
Nov 21 19:14:34 RepetierServer kernel: [31623.585276] usb 1-1.5: Product: USB2.0 PC CAM
ERA
Nov 21 19:14:34 RepetierServer kernel: [31623.585280] usb 1-1.5: Manufacturer: Generic
Nov 21 19:14:34 RepetierServer kernel: [31623.585284] usb 1-1.5: SerialNumber: 20100331
010203
Nov 21 19:14:34 RepetierServer kernel: [31623.585977] uvcvideo: Found UVC 1.00 device U
Nov 21 19:14:34 RepetierServer kernel: [31623.586479] uvcvideo 1-1.5:1.0: Entity type f
Nov 21 19:14:34 RepetierServer kernel: [31623.586488] uvcvideo 1-1.5:1.0: Entity type f
Nov 21 19:14:34 RepetierServer kernel: [31623.586789] input: USB2.0 PC CAMERA as /devic
es/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/input/input4
Nov 21 19:14:34 RepetierServer systemd[1]: Stopping mjpg_streamer for picam...
Nov 21 19:14:34 RepetierServer systemd[1]: Starting mjpg_streamer for picam...
Nov 21 19:14:34 RepetierServer systemd[1]: Started mjpg_streamer for picam.
Nov 21 19:14:34 RepetierServer startAllCams[26656]: Webcam does not support MJPG - usin
g slower YUYV instead!
Nov 21 19:14:34 RepetierServer startAllCams[26656]: Best resolution: 640 x 480 at 30
Nov 21 19:14:34 RepetierServer startAllCams[26656]: /usr/local/bin/mjpg_streamer -i "/u
sr/local/lib/mjpg-streamer/input_uvc.so -d /dev/video0 --fps 30 -q 85 -r 640x480 -y " -
o "/usr/local/lib/mjpg-streamer/output_http.so -p 8080 -w /usr/local/share/mjpg-streame
r/www" -b
Nov 21 19:14:34 RepetierServer MJPG-streamer [26677]: starting application
Nov 21 19:14:34 RepetierServer MJPG-streamer [26677]: enabling daemon mode
Nov 21 19:14:34 RepetierServer dhcpcd[840]: eth0: adding address fe80::96c5:4333:2403:f
1ca
Nov 21 19:14:34 RepetierServer NetworkManager[442]: <info> (eth0): carrier is OFF
Nov 21 19:14:34 RepetierServer startAllCams[26656]: enabling daemon modeforked to backg
round (26680)
Nov 21 19:14:34 RepetierServer MJPG-streamer [26680]: MJPG Streamer Version.: 2.0
Nov 21 19:14:34 RepetierServer NetworkManager[442]: <info> (eth0): new Ethernet device
(driver: 'smsc95xx' ifindex: 6)
Nov 21 19:14:34 RepetierServer NetworkManager[442]: <info> (eth0): exported as /org/fre
edesktop/NetworkManager/Devices/5
Nov 21 19:14:34 RepetierServer MJPG-streamer [26680]: Using V4L2 device.: /dev/video0
Nov 21 19:14:34 RepetierServer MJPG-streamer [26680]: Desired Resolution: 640 x 480
Nov 21 19:14:34 RepetierServer MJPG-streamer [26680]: Frames Per Second.: 30
Nov 21 19:14:34 RepetierServer MJPG-streamer [26680]: Format............: YUYV
Nov 21 19:14:34 RepetierServer MJPG-streamer [26680]: JPEG Quality......: 85
Nov 21 19:14:34 RepetierServer MJPG-streamer [26680]: TV-Norm...........: DEFAULT
Nov 21 19:14:34 RepetierServer NetworkManager[442]: <info> (eth0): device state change:
unmanaged -> unavailable (reason 'managed') [10 20 2]
Nov 21 19:14:34 RepetierServer MJPG-streamer [26680]: www-folder-path...: /usr/local/sh
are/mjpg-streamer/www/
Nov 21 19:14:34 RepetierServer MJPG-streamer [26680]: HTTP TCP port.....: 8080
Nov 21 19:14:34 RepetierServer MJPG-streamer [26680]: username:password.: disabled
Nov 21 19:14:34 RepetierServer MJPG-streamer [26680]: commands..........: enabled
Nov 21 19:14:34 RepetierServer MJPG-streamer [26680]: starting input plugin /usr/local/
Nov 21 19:14:34 RepetierServer MJPG-streamer [26680]: starting output plugin: /usr/loca
l/lib/mjpg-streamer/output_http.so (ID: 00)
Nov 21 19:14:34 RepetierServer NetworkManager[442]: <info> (eth0): preparing device
Nov 21 19:14:34 RepetierServer NetworkManager[442]: <info> (eth0): created default wire
d connection 'Wired connection 1'
Nov 21 19:14:34 RepetierServer NetworkManager[442]: <info> devices added (path: /sys/de
Nov 21 19:14:34 RepetierServer NetworkManager[442]: <info> locking wired connection set
ting
Nov 21 19:14:34 RepetierServer NetworkManager[442]: <info> get unmanaged devices count:
1
unavailable -> unmanaged (reason 'unmanaged') [20 10 3]
Nov 21 19:14:34 RepetierServer kernel: [31623.886257] smsc95xx 1-1.1:1.0 eth0: hardware
Nov 21 19:14:34 RepetierServer kernel: [31623.897015] smsc95xx 1-1.1:1.0 eth0: ha
Nov 21 19:14:34 RepetierServer dhcpcd[840]: eth0: waiting for carrier
Nov 21 19:14:34 RepetierServer kernel: [31623.985927] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
Nov 21 19:14:34 RepetierServer NetworkManager[442]: <warn> (eth0): device not down after timeout!
Nov 21 19:14:34 RepetierServer kernel: [31623.998738] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Nov 21 19:14:34 RepetierServer MJPG-streamer [26680]: serving client: 127.0.0.1
Nov 21 19:14:36 RepetierServer dhcpcd[840]: eth0: carrier acquired
Nov 21 19:14:36 RepetierServer kernel: [31625.459189] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Nov 21 19:14:36 RepetierServer kernel: [31625.460412] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x41E1
Nov 21 19:14:36 RepetierServer NetworkManager[442]: <info> (eth0): link connected
Nov 21 19:14:36 RepetierServer dhcpcd[840]: eth0: adding address fe80::96c5:4333:2403:f1ca
Nov 21 19:14:36 RepetierServer dhcpcd[840]: eth0: IAID eb:69:7a:69
Nov 21 19:14:36 RepetierServer ModemManager[436]: <warn> Couldn't find support for device at '/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1': not supported by any plugin
Nov 21 19:14:36 RepetierServer dhcpcd[840]: eth0: rebinding lease of 10.10.143.11
Nov 21 19:14:36 RepetierServer dhcpcd[840]: eth0: NAK: from 192.168.0.1
Nov 21 19:14:36 RepetierServer dhcpcd[840]: eth0: soliciting an IPv6 router
Nov 21 19:14:36 RepetierServer dhcpcd[840]: eth0: soliciting a DHCP lease
Nov 21 19:14:36 RepetierServer dhcpcd[840]: eth0: offered 10.10.143.11 from 195.37.39.2
Hope this was right now.
Florian
Linux closed the connection so server close dit as well.
Linux log also shows this
EMI happens when the usb mass it not correctly buffered or so. I'm no electrican but talked with one knowing that usb has special termination chips to prevent EMI. So something with that is causing the pi to disable serial causing the stop, but I can't say whos fault this is.Just that it is some electronic problem detected by linux.
thanks for replying.
Sorry I have to bother you again.
After trying some things to exclude the reasons for closing the usb port (new SD Card, new Raspberry, new power adapter, new USB cable, measuring the current, etc.). I´ve looked for other reasons, so i looked after the cpu usage of the pi. It´s by 100% after a while (Screenshot following).
After researching the internet i got the information that the RPI3 does overclocking the CPU by nearly 50% of CPU usage. Could it be that the overclocking of the CPU runs the RPI3 unstable and after a while he switches of the USB Ports?
Also I can´t explain why the CPU has an usage of 100% while no printing event operates.
Florian
100% for server while idle is not normal, but there are some things that can cause longer operations, especially if you have several gcodes. If you change settings in printer that affect speed calculations all gcodes get reparsed. I also have seen browsers with connection problems reconnecting in very fast frequency which can also add a good load on cpu. If you are using our image there is also the x server with a browser accessing the server. If you have no display on pi you should not start it. Edit the last lines of /home/pi/.bashrc to not call the x server and reboot. That reduces load and memory usage at least.
ich melde mich nochmal, habe gerade nochmal geschaut und bemerkt dass Ihr ja eine Deutsche Firma seit.
Ich hoffe es ist in Ordnung, wenn ich auch Deutsch weiterschreibe um Missverständnisse zu vermeiden.
Das Problem tritt leider auch bei einem anderen Drucker mit Arduino auf. Es heißt ja dass 90% aller Probleme 50 cm vor dem PC sitzen bzw. hier vor dem RPI. Leider bin ich komplett ratlos zur Zeit mache ich irgendetwas flasch?
Jetzt kommt mir noch eine andere Frage hinzu. Da wir die Pro Lizenz verwenden und diese jetzt auf 2 RPI installiert haben stellt sich mir die Frage ob die Lizenzen gewertet werden, die gerade in Verwendung sind?
Schöne Grüße
Florian
Licenses activated are counted. In register tab you can any time deactivate a license to free it's counter. In case of severe problems we can also do this for you if that caused you to run out of licenses.
Found this thread:
https://github.com/raspberrypi/linux/issues/897
they have same emi problems. At the end it indicates that a kernel version might cause this problems. So maybe you can check what kernel you have on pi and see if you can update it. Also I did not like the end of the thread giving no real answer what the solution is except kernel version.
