Possible to turn down gap fill amount?
I am having a problem where any place gap fill is used too much filament is extruded. The result is noticeable bumps in each layer wherever gap fill was used while everything else is flat. If I turn off gap fill, it looks perfect except gaps where gap fill would have been used. Is it possible to turn down the amount of filament used on gap fill commands? Does anyone else have this problem?
This also results in artifacts in the side walls from when the nozzle bumps into the blobs caused by gap fill.
Here is another example. I had to abort the print because the nozzle was scraping so bad. https://i.imgur.com/NLHkpTP.jpg
Is your extruder calibrated, so you are not overextruding/oozing ?
I am pretty sure it is calibrated well. All solid layers are almost perfect with no over extrusion causing bumps.
1.3 Dev fixed it. Running perfectly now.
