x axis reversed motion without any apparent changes
Hi can anyone help?
I Have a Sunhokey 3d printer, it has been working for the
last 3 years perfectly.
I redesigned the extruder carriage to give it more
strength and stability in an attempt to improve surface finish. Apart from the
extruder and the x axis limit switch (which I had to unbolt for ease of access)
I didn’t touch the wires only to move some out the way. On reassembly the x axis
move to the right when pressing left in the Manual screen and left when
pressing right. When selecting “X home” the carriage moves in the opposite
direction (away from the limit switch) counts 200mm and stops or crashes into
the end. All other functions seem to work as before.
I changed the X axis direction in “printer settings” which did correct the motion direction but the “X home” function still ran away from the limit switch.
Anyone know how to solve my problem?
What mystifiers me is that all the motor plugs on the board are keyed but I know I didn't disconnect any plugs or wires. C'est la vie!
Well anyway thankyou for your input and time.
