Repetier-host can connect to printer, but Repetier-Server cannot
Hello,
I'm trying to connect Repetier-Server to my printer, but I'm having little luck in it.
I have an i3 with the Repetier 0.92 firmware running on an Arduino Due with a RADDS shield, and I have tried it with a Raspberry Pi (armel) and a Pine64 (armhf 64) as controllers, but haven't succeeded. I even tried to reinstall a lower version of the Server (0.80). The connection works fine when using Repetier-Host directly (at 115200 baud, using Repetier protocol, on the armhf 64). Before running the Repetier-Server, I made sure that no other process was using the USB port (reboot + checking with lsof).
This is the output of the M115 gcode:
21:54:07.749 : FIRMWARE_NAME:Repetier_0.92.9 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1 REPETIER_PROTOCOL:3
21:54:07.753 : Printed filament:10.00m Printing time:0 days 4 hours 3 min
Any ideas? I can't see anything abnormal in the Linux logs, and can't find a log for Repetier-Server...
Thanks!
Thanks!
You see server trying to connect in /var/lib/Repetier-Server/logs/server.log.
Repetier-host was working because it was being run under my own user account (which has access to /dev/tty*).
Thanks a lot for the help and all your awesome work!
I would appreciate it alot
Thank You...
sudo adduser repetierserver tty
should do the trick. That is also run when installing the server, but seems like linux rejected that for some reason.
